Question about KitchenAid KGRC608LSS Gas Kitchen Range
I need to replace inside glass on kitchenaid oven model kgrc608
reg501
  • 413 Answers
SOURCE: How to replace inside glass on KitchenAid KERC608 Type 30P Range
Open the door fully and with a small screw driver, look closely at the hinge area on the oven cavity. There you will see a small lever that will rotate down and lock the door in place. Once in the lock position, begin closing door, you will feel the door 'catch' then lift the door off of the oven.
Posted on Jun 16, 2008
  • 116 Answers
SOURCE: The interior glass on the
The inner glass is replaceable. The door will have to be removed from the range (see your user manual) and disassembled. Most repair shops can do the replacement for you at a nominal charge if you take the door in to them.
Posted on Jul 28, 2008
SOURCE: Interior Range Window cracked - How to Replace
It is simple enough not to need a manual.
1- open the door, then pull outwards. The door mounts slide right out.
2- lay flat on a towel on the floor. Remove screws on the inside of the door.
3- remove each piece and layer of the door and glass panels. Set them aside in order so you know how it goes back together
4- replace broken inner glass panel
5- put each piece back together, install screws
6- slide door (mounts) back into their homes on the front of the range
It is surprisingly simple. All you need is a #2 Phillips screwdriver and a bit of patience.
Tip: make sure to clean each glass panel while you have the door apart. Use a razor blade for those stubborn burnt on stains.
Posted on Nov 19, 2008
  • 77 Answers
SOURCE: Inside oven door glass broken
I would guess that you could not. It is a safety glass and has a special gasket material. Although you may be able to buy the door as cheap or cheaper than just the glass plus the install. Hope this helps. Have a great day.
Posted on Apr 17, 2009
SOURCE: Kitchen aid double convection oven - glass needs cleaning!
Had to remove the screws on the BOTTOM of the outside door, then panel came off after all the screws (inside oven door included) were off...
Reversed the order to put back on.. Cleaned (all) three glass pieces nicely... Now after reading the problems with the self cleaning part (doors getting stuck!) - I'm afraid to try mine!
Posted on Jan 22, 2010
Control panel works, no error code, fan runs but oven won't heat?Can't find pilot light info in manual. kgrc608
there is no pilot light on this model. It could be the bake igniter. May also be the control board. I would go with the igniter since they fail more often (even if glowing) than any other component.
Aug 20, 2014 | KitchenAid KGRC608LSS Gas Kitchen Range
Cracked inner oven glass window
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Jan 16, 2011 | KitchenAid Ovens
Interior door glass cracked on my KitchenAid oven
thers the inner most glass then some inner glass packs then the outer determine waht u need take ur model and go to sears.com go to there parts direct or parts research link lookup ur model find the part number and a normal price ........anyways u are gonna have to take the door off and replace it, kinda hard to describr just have to get acesss inside and replace the glass... might need service might be cheaper if u have a local repair shop for u to take the door off and bring it in to them... to get that dooor off most have lil flappers or metal locks open the door fully inspect down by the hinge pulll those flappers back towards glass then move door to brooil position 3/4 way closed and lift striaght up... hope this helps reply or rate me if posible k thanks
Jan 27, 2010 | KitchenAid KGST307 Gas Kitchen Range
Burnt on stains on the inside glass door of my kitchenaid oven
DeBruce Polish should remove those types of problems and also render the surface more "Cleanable". This stuff really works on glass anomalies.
Check out debrucepolish.com.
DEBRUCE METHOD on You Tube
Apr 11, 2009 | KitchenAid 32 in. KECC508 Electric Cooktop
GE oven - cracked inside window
solved. replacement glass was about $50 and repair time was a few screws and 20 minutes.
Jan 05, 2009 | KitchenAid KGRT607 Gas Kitchen Range
I have a Kitchenaide Gas Range. KGST307 Inside glass on the oven door broke.. need to replace. is it easy to do? going to order glass online.. I did call some local repair people.. looking at a $200.00 to $250.00 bill to fix... NOWAY............ I can buy the glass and do it myself... Need some help if it can be done..... Any Help is COOL!! Thanks TED... 425-549-0150 WA. 98014
Aug 19, 2008 | KitchenAid KGST307 Gas Kitchen Range
Broken inside glass door on my electric KitcherAid glass top range
sounds like you may have thermal breakage. does your oven have the self-clean option? you can have the glass replaced easily. i wouldn't use the self-clean option for now.
Aug 02, 2008 | KitchenAid KGST307 Gas Kitchen Range
Jun 16, 2008 | KitchenAid Kitchen Ranges
Apr 06, 2008 | KitchenAid KGRT607 Gas Kitchen Range
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
KitchenAid KGRC608LSS Gas Kitchen Range Logo
43 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
