Question about Health & Beauty
How do I change the batteries on the boreem jia 6021
4 Suggested Answers
SOURCE: Boreem Jia Scotter - Model ID and manual?
how do i change the battery on my boreem jia series electric scooter
Posted on May 22, 2011
SOURCE: I need the manual for
I too have a problem with a Jia 601s in that I have the owners manual but replacement parts do not match existing scooter
Posted on Jul 10, 2011
  • 14585 Answers
SOURCE: Can I charge my boreem jia battery by jump start charging from my car battery?
If the battery is 12 volts and has a high amps(50+) out put , yes. If it is milliamps, no.
Posted on Jul 03, 2015
Jia heng lighter watch parts and configuration of components?
Jia Heng Butane Lighter Watch Battery Replacement
The battery replacement for the Jia Heng Butane Lighter Watch is fairly easy. The clock face actually gets removed from the lighter body. The only tools you will need are jewelers Phillips and slotted screwdrivers; Phillips and slotted.
Remove band by compressing spring pin with slotted screwdriver by pushing in the pin. These are standard watch band pins.Remove back 4 screws to remove backThe clock face is help on by 2 screws removed from the open back, there are at the 11 and 4 o'clock orientation when looking at the back.The front will drop off.Remove the plastic alignment spacer.Replace the 377 button battery.Put it back together by reversing the process.
Attached pictures
Front
Back
Clock face screws
Plastic alignment spacer
Battery placement
Oct 02, 2016 | Watches
Boreem gas scooter tankman needs flywheel housing ...basically one whole side of motor cause this cover same piece in which one of motor mounts ***** is...asking proper way to search this part
Boreem Tankman Scooter Parts - Boreem Parts - All ...
www.monsterscooterparts.com/trsc/rec-brands/boreem/boreemtankman
  1. Cached
Items 1 - 16 of 16 - 12 Volt 1.0 Amp (1000 mA) 3-Prong QL-080414-B1201500H Battery Charger. ... 8mm 05T Chain 20 Tooth Drive Sprocket for 49cc & 52cc Gas Scooter Engines. ... Select your model below to view all known compatible parts including tires, tubes, pull starts, wheel assemblies, and much more!
Neoscooters: Boreem Scooter Parts, Boreem Gas Scooter ...
www.neoscooters.com > ... > Boreem Scooter Parts
  1. Cached
  2. Similar
Boreem parts and acccessories for Boreem Gas scooters. Chargers ... Boreem Ironman XR Scooter Parts. Boreem ... Boreem Tankman Scooter Parts. Boreem ...
Boreem Pocket Bike Parts Parts - Tankman Parts - Scooter ...
www.scooterpartssale.com/index.php?main_page=index_bike...id...
  1. Cached
  2. Similar
Products 1 - 28 of 208 - Parts catalog - Carry with chinese made Boreem Pocket Bike Parts Tankman Parts.
Mar 26, 2016 | Miscellaneous
What color wires connect toggle to ignition on boreen jia electric scotters?
black is negative, red is positive to controller, yellow is ignition on
Oct 25, 2013 | 12 Volt 12ah Ebike Electric Scooter...
Boreem Jia series Instructions onhow to replace the battery
unhook positive cable then the negitive cable, pull out, then put new one in. hook the negitive cable up first then the positive cable.
Jan 09, 2013 | ATVs
I have a Boreem 49cc, new battery but lights, horn etc don't work?
Your alternator might be bad. Check if your alternator is functioning well.
Apr 13, 2012 | Cars & Trucks
Aug 23, 2009 | Cycling
Health & Beauty Logo
44 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
