Question about Wolff Sunquest Pro 24RS 220 Volts
I can't find the starter on my older Sunquest pro 24rs tanning bed
Two of the bulbs are not lighting up on the bottom half of my tanning bed, and i've switched the bulbs around so the bulb wasn't the problem and the two bulbs are right beside eachother. My research says it's the starter, but i can't find the starter.
4 Suggested Answers
sharktooth12
  • 38 Answers
SOURCE: My Sunquest, Pro 24RS.
The problem could stem from a ballast. If you've ruled out the starter and the wiring, the ballast is the only thing left I can think of.
Posted on May 31, 2011
SOURCE: Where do I find replacement trim profile for my Sunquest Pro 16 SE tanning bed
Ebay has several:http://compare.ebay.com/like/350311266168?_lwgsi=y&ltyp=AllFixedPriceItemTypes&var=sbar
Posted on Mar 02, 2012
ballast is about the only thing left its hard to check anything electrical without a volt meter it could also be the bulb holder
Posted on Feb 09, 2013
Tanning bed manuals
twist carefully 90 degrees until the inner contact socket lines up with the outer bracket at each end and you hear a faint click then slide out you will see the slot 2-3 mm when it lines up repeat for each tube re assemble in reverse order https://www.youtube.com/watch?v=Zko7FCY3n_U
Jul 20, 2014 | Wolff Sunquest Pro 24RS 220 Volts
1987 sca 24 series 1tanning bed manual
I have 1987 SCA-24 series 1 wolffsystems tanning bed how do I change the bulbs or where can I get owners manuel?
May 29, 2014 | Wolff Sunquest Pro 24RS 220 Volts
Sunquest pro 16 se
You may have a wire burned out going to that set of ballasts/bulbs. Have a trained technician to check and repair this.
Feb 08, 2013 | Wolff Sunquest Pro 24RS 220 Volts
How to remove and install ballast in sunquest 24 taining bed
I have a question for someone who knows about a Sunquest 24 r tanning bed? Involving bottom bulbs not lighting at all?
Feb 02, 2013 | Wolff Sunquest Pro 24RS 220 Volts
I lost my tanning bed hinges to my sun quest pro 24 rs.
You are better off buying new hinges. Call manufacturer.
Sep 21, 2012 | Wolff Sunquest Pro 24RS 220 Volts
Wolff sunquest bottom lights dont turn on
There should be a cord that goes from the top of bed to the bottom section of the bed in the back of the bed. Make sure the cord is plugged in all the way and is not broken. This cord could be bad, the plugs may be bad, the cord could be missing entirely. A connection to the plugs could be burned out inside the top or bottom sections or at the main power relay.
Sep 18, 2012 | Wolff Sunquest Pro 24RS 220 Volts
Wiring home tanning bed
If you are installing a bed in your home for the first time, you should have a trained technician to do it, or bad results can happen. Be sure the voltage is correct to the bed - very important. All local wiring codes should be followed for safety - you don't want to kill anyone or the bed.
Sep 02, 2012 | Wolff Sunquest Pro 24RS 220 Volts
2003 SUNQUEST PRO 24RS MANUAL TANNING BED
I Have a m2 24rs8 tanning bed. I loved it . I have moved it was in storage for 2 1/2 years. Moved to a new house. I hooked my bed up. the only thing it does kinda turn the fan on. what have I done wrong....It is on a 20amp bracker. Wire is 12 2 with ground. HELP PLEASE
Aug 25, 2012 | Wolff Sunquest Pro 24RS 220 Volts
Wolff Sunquest Pro 24RS 220 Volts Logo
115 people viewed this question
Top Wolff Health & Beauty Experts
Steve
NOEL
NOEL
Are you a Wolff Health and Beauty Expert? Answer questions, earn points and help others
