Need cable tv for sony trinitron bbe
I have connected a cable and tried putting menu,channel set up, auto program, cable on but nothing happens.what do i do?
    Genius:
  • Televison & ... Master
  • 2,432 Answers
Have you been select ' cable ' at the settings of your tv. then where did you hooked up the cable box at the tv ?.have you been tried to reset the cable box.
Posted on Dec 04, 2012
  • 3 Answers
SOURCE: Can't set up the channels on my TV
Some models require two buttons to be pressed together for menu access - usually at the bottom or side.
Posted on Feb 12, 2008
  • 84 Answers
SOURCE: Sony trinitron XBR2 32 " can't seem to get the cable working on it
You can hook up to either aux or vhf not converter. then with remote use ant button to select the one you are connected to. then do the auto search. Also can you get to 3 by pushing 3 and ent on the remote?
Posted on May 18, 2008
  • 4234 Answers
SOURCE: doesn't get all cable channels
With the menu set to cable signals, the autoprogram should catch all of the cable channels. The Cable Channel option allows you to use either channel 3 or 4 as the "cable" channel. This is when you have an external box that you use to tune in cable rather than the TV directly. The easiest way here is to autoprogram the TV while playing a VCR tape. That will insure that channel 3 is included.
Does the autoprogram fail?
Dan
Posted on Aug 20, 2008
  • 86 Answers
SOURCE: Can't figure out how to turn on cable on Sony Trinitron TV
Setting Up the TV
After you have finished connecting your TV, you can use Auto Program to set up your
channels. During Auto Program, the TV will automatically search for available channels and
program receivable channels.
(Make sure CABLE is connected on coaxial and you are not using any other connections such as cable box, hdtv or satellite antenna)
1 Press to turn on the TV. The Initial Setup screen appears.
2 Press on the remote control or on the TV front panel to start Auto Program, or press
to exit.
To perform Auto Program again
Press .
2 Press g to highlight Channel Menu.
3 Press f to highlight Cable. Press to select.
4 Press F or f to highlight On or Off according to how you connected your TV. Press to
select.
5 Press f to highlight Auto Program. Press to search for channels.
6 After Auto Program finishes, press to exit.
To reset the TV to factory settings
Turn the TV on.
2 Hold down on the remote control.
3 Press and release the POWER button on the TV front panel. The TV will turn itself off,
then back on.
4 Release .
✍ When you start Auto Program wait until it is finished; otherwise it will skip over channels that are
available. Perform Auto Program again to program receivable channels.
✍ The Initial Setup screen appears each time you turn on the TV until you perform Auto Program.
Initial Setup
Auto Program [CH+]
[CH–]
First please connect
cable/antenna
Exit
Posted on Jan 17, 2009
  • 4 Answers
SOURCE: Sony Trinitron XBR TV, picture-in-picture got
A solution I found for our KV-32XBR200 was to press Setup on top of the set, then select the "Demo" item with TV/Video. The text overlay apparently banished PIP. Verified this twice, as I'm at this page because our remote can only turn PIP on :-).
Posted on Feb 17, 2011
My tv's channels are only up to ch 35, and we have cable tv connection. I cant utilize my cable connection cause my tv's only programmed up to 35. do we have a way to program it to go up to more than 35?...
I assume you have analog cable TV service and no cable box. Press MENU button on your TV remote. Go over to CHANNEL SETUP. There are four arrow buttons and a button in the middle of the arrow buttons on the TV remote control. Use these arrow buttons to go up, down, left and right. Use the button in the center to select. TV On-screen menu has Video, then Audio, then Channel Setup.
Cable can be set to ON or OFF, you want to set it ON to get cable channels.
Go down to AUTO PROGRAM and select it, press button in the center of arrow keys.
A short delay while available channels are searched so be patient. After Auto Program finishes, press MENU to exit. You can perform Auto Program whenever required.
You can also add or skip channels manually. You will discover more options in the TVs menus.
Feb 24, 2011 | Sony FD Trinitron WEGA KV-36FS320 36" TV
Can't get it to auto tune
Hello
To set the TV to autotune do the following.
1 Press "Power Button" to turn on the TV. The Initial Setup screen appears
2 Press CH UP button on the remote control or on the TV front panel to start Auto Program, or press CH DOWN button to Exit.
When you start autoprogramme, wait until it is finished; otherwise it will skip over channels that are available. If it happens so, perform autoprogram again by turning on the power button.
The initial set up screen appears each time you turn on TV until you perform auto program.
1 Press "Menu" button.
2 Press"=>"to highlight Channel Menu.
3 Press "Down arrow button" to highlight Cable. Press "+" button to select.
4 Press "Up Arrow button" or 'Down arrow button"to highlight On or Off according to how you connected your TV. Press "+" to select.
5 Press "Down arrow button" to highlight Auto Program. Press [+] to search for channels
6 After Auto Program finishes press "Menu button" to exit.
1 Turn the TV on.
2 Hold down [Reset key] on the remote control.
then back on.
4 Release [Reset] key.
Ok.
Jan 20, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How do I tune a sony trintron without a remote
Hello
You can autotune your Sony TV without a remote control. Fist connect it to an external antenna or cable whatever may be, to its antenna socket at the back side.
[1] Press POWER button on the TV to turn it on. The Initial Setup screen appears.
[2] Press CH+ button on the remote control or on the TV front panel to start Auto Program, or press CH-- button to exit.
1 Press"MENU" button on the front panel of your TV.
2 Press "RIGHT ARROW button to highlight Channel Menu.
2 Press DOWN ARROW BUTTON to highlight CABLE or ANTENNA AND PRESS [+} to select.
4 Press UP arrow or DOWN arrow to highlight On or Off according to how you connected your TV. Press [+] to select.
select
5 Press DOWN arrow button to highlight Auto Program. Press [+]to search for channels
6 After Auto Program finishes, press MENU button to exit.
OK
Dec 18, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Got rid of cable, how do I change from set channel 3 to open channel choices.
1 Press menu
2 Press right arrow to highlight Channel Setup Menu.
3 Press down arrow to highlight Cable. Press + to select.
4 Press up arrow or down arrow to select On or Off according to how you connected your TV. Press .
5 Press down arrow to highlight Auto Program. Press + to search for channels.
6 After performing Auto Program, press menu to exit.
This should pull in all of your over the air channels
Dec 02, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Setting Up the TV
to exit.
Press .
select.
Turn the TV on.
then back on.
4 Release .
Initial Setup
Auto Program [CH+]
[CH–]
cable/antenna
Exit
Jan 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
TV won't "talk" with satellite cable
Try to see if you have 5volts for your EEPROM. If the voltage is normal try to replace your EEPROM or try to reprogram it. Your EEPROM is corrupted so that's why it will not store data.
Dec 01, 2008 | Sony KV-35S42 35" TV
No signal
Check is RF Antena/ Cable connected? If yes, go to TV Menu and select Auto-Program. TV will start tuning and search all available channels on cable/ on-air. If there is no channel reception, TV has defective Tuner. If you know basic electronics knowledge, replace the Tuner or contact nearest Sony repair shop.
Jun 04, 2008 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Sony TV snow at startup
Bad solder connection in tuner.....replace with new or rebuild.
............................T.
Mar 09, 2008 | Televison & Video
Lost remote reset chanels
the great thing about sony is you dont need the remote to do menu functions. there is a flip down panel in the front that has the menu, cursers, and select buttons. just select the tab you need in the menu (channels) select the type of input (cable :on/off) then auto program. be sure to have the VCR off so not to program the channel 3 only.
Jan 22, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
