Question about Refrigerators
How do I stop the fridge from leaking water underneath (lg multi air flow gr-389sqf)?
2 Suggested Answers
  • 400 Answers
SOURCE: lg multi air flow gr-349sqf
It sounds like the defrost element is faulty and is causing a leakage to earth when the unit comes onto defrost cycle. Check the defrost element in the freezer compartment behind a panel cover.
Posted on Mar 10, 2009
Lg gr 389sqf ice
What's the problem? Not making ice? Making too much ice and won't cut off? Freezes too much??? Need a little more info.
Mar 04, 2014 | LG Refrigerators
Wondering if you can help. My LG Multi Air Flow No Frost Fridge Freezer (Model No: GC2999BUA) is leaking quite a lot of water every couplo of days or so? Any ideas what this could be?
The drain will be blocked it need to be cleared with some warm water and then put a curtain wire down drain to clear. I cant find a picture with that model number.
Jun 07, 2011 | Refrigerators
LG GR-389sqf, trips main switch
where is the fuse for this fridge as there is no power to motor.
Jan 18, 2011 | LG Refrigerators
LG model GR-620RW leaking water inside at back top
the drain hole (freezer) is blocked,
Apr 08, 2009 | LG Refrigerators
Lg multi air flow gr-349sqf
Mar 10, 2009 | Refrigerators
Freezer working fine but fridge isn't
Either the damper that the air flows up through is closed or the return air flow vents are blocked with clear ice.
Do you feel the air come out all the way at the top of the duct assembly when the freezer door is opened (but it then stops when the door is closed)?
If so, then it sounds like your return air flow vents are clogged. These are located to the left and right of the duct assembly in the rear/bottom of the refrigerator section. Sometimes you may have to slowly pour hot water into these vents to get the clear ice to thaw. The water should go down into the freezer section behind the evaporator and then out the drain in the back.
If you do not get the air to flow out the top of the duct assembly then the damper is staying shut. This could be either a bad damper in the duct assembly or the main board my not be sending voltage to the damper. Hope this helps.
Dec 31, 2008 | LG LRFD22850ST French Door 22.4 Cu. Ft....
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
