Question about Mitsubishi WD-73732 73" Television
Picture lighting / color going bad
I have a WD62927. The change bulb indicator is NOT on. However, my picture has a "halo" type lighting effect around light colors and skin tones. It comes and goes but it seems to get worse after the tv is on for a little while than when the tv is just turned on. Any suggestions on what it is and what do I need to do to get it fixed?
Thanks
The lamp change indicator is not on. Picture colors are off (ie. showing wrong colors); light colors seems to be more affected (i.e. darker parts of the picture seem fine). Some time the right half of the picture flicker badly. The left half also flicker but less frequently. Problems come but some time, I have to turn off the TV and cool it down to get the problem to go. It usually come back within 15 minutes.
  • liem Jan 13, 2009
    Someone posted a solution that an IC on the main board need to be checked Would you please elaborate and answer the following questions:
    1. How do I locate this IC?
    2. How one tests this IC?
    3. How does one replace this IC?
    4. What kind of equipments needed for the above tasks?
    It seems that the problem is serious and Mitsubishi needs to be contacted. Is this problem common enough among Mitsubishi DLP rear projection TVs that I may have a chance to get Mitsubishi to cover the cost of this repair?
    Thanks,
    Liem.
  • liem Jan 14, 2009
    Turn off to cool down the TV doesn't help.
    Reset set it help the flickering problem but the "halo" problem remains. All light color portions of the picture become greenish.
    Thanks.
    PS. The problem starts in the last several days.
    Guru:
  • 829 Answers
Hi , Do you have any magnetic device kept next to the monitor for ed : Speakers plz keep this away from the PC , What happens is it degoses the image and some mistic colors are seen, If its yes the n after you remove the device you need to spray the degos to re stabilize the image.
Posted on Jan 14, 2009
  • Milind Shetti
    Milind Shetti Jan 14, 2009
    Degoss the image and should work fine
    Sergeant:
  • 378 Answers
Just the capacitors and ic on the board getting overheated and giving you this problem and they need to be replaced by a professional tecnician after checking the proper voltages of the circuit board.
Posted on Jan 11, 2009
  • 10,594 Answers
How since long this problem started?
You can unplug TV from AC outlet for few minutes and then power up and check picture result.
  • Shahid Electronics
    Shahid Electronics Jan 14, 2009
    I need few info, does TV shows same halo effect on all inputs, like cable, dvd etc or shows different picture results?
    How old is this TV? Though lamp light is not on yet you can give try to replace lamp to check picture result.
    Sniper:
  • 88 Answers
This is a problem with the DMD driver board (the board that has the actual DLP chip on it). This DLP chip has thousands of tiny little mirrors on it that move to reflect the correct colors at the correct time up on the screen. The DMD board will need to be replaced.
This is a costly repair and requires precision alignment of the DLP chip. A qualified repair technician should be able to give you a good estimate. It may be just as economical (and less work) to replace the entire light engine.
Hope this helps, please rate my solution.
  • Derrel Stratton
    Derrel Stratton Jan 11, 2009
    The only part which can affect half of the screen at times is the DLP chip. Upon heating up (or overheating), the DLP chip on the DMD board is failing. This is also the only component that can cause the picture to have an "out of focus" look to it. Again, this is the DLP chip on the DMD board (driver board) and it looks much like an older TV that has convergence issues or halos.
    Sergeant:
    Novelist:
  • 326 Answers
Its the bad ic on the main board which has to be checked and replaced.to clear the problem.
    Top Expert:
  • Mitsubishi Master
  • 77,201 Answers
I don't think this is a back light issue, I do think it is a main circuit board issue, most likely failing capacitors, the better after it cools is a dead give-away.
The color on my tv is turning green. It's not totally green but it's becoming green. No matter how I adjust the colors it remains the same with too much green. You can't see the true colors...
It is very common for the color of the lamp to change as it nears the end of it's life. Depending on the bulb itself you may see yellow, green, or blue shifts (I have even seen red/orange). This is due to the diminishing output of the bulb and while you can make some adjustment you will eventually hit the point of failure. The bulb could in fact last several more weeks or even months depending on your use and environment. It is probably a good time to start searching for a replacement now so you can replace it as soon as it dies or just replace it now if the color is too bad to be worthwhile.
May 23, 2011 | Philips Magnavox 9P6034C 60" Rear...
Originally got blinking lights to indicate a bad bulb. Had a spare bulb that I installed. Now a very loud noise from color wheel and only a black and white picture.
Bad color wheel is cause of noise and black and white picture in tv, please replace color wheel to solve the issue.
Required color wheel is available in SamsungParts for $120
Thanks.
May 13, 2011 | Samsung HLM507W 50" Rear Projection HDTV
I'm not sure what the model number is, it is a post on Craigs List, says that it is a 50" big screen in great condition with a brand new bulb that costs $180, but has a bad "light engine", they are asking...
If it has a $180 bulb and a light engine, it is probably not a flat panel but a projection type.
It is likely the LCD or DLP mirror module is bad (the set will have one or the other, not both). I haven't had to change one of these before, but the labor is probably moderate (find the part between bulb and lens/mirror assembly, unplug cable(s), unscrew, replace, adjust focus if necessary). I suspect the part itself would be rather expensive - see if you can get the part number and search for it on the internet before you buy.
Some sets use a spinning color wheel in the light engine; a failure here would cause odd color effects. It would be a cheap fix, but given that the bulb was just changed in an attempt to solve the problem, I expect the color wheel is not at fault.
Sep 22, 2010 | Televison & Video
I have a sony kdfe50a10 that has a great picture in the middle but has a yellow halo all around it. I replaced the bulb about a year ago. Does anyone have the same problem.
It may be the color wheel or the light engine. Do you hear any whiring noise - more than usual from the TV? If so its possible the color wheel bearings are going out.
Dec 10, 2009 | Sony Televison & Video
Double Blue Halo Effect and Blurry Blue Picture
thats a problem with the Blue CRTs coolant needing replacement. If you look directly into the blue and green CRTs while its playing you should notice a bunch of crud inside the lens indicating that the coolant needs replacement. You can get the coolant replacement kit for a phillips at the following link which includes the coolant and instructions
http://servicemanuals.vstore.ca/
Aug 05, 2009 | Philips 60P8341 60" Rear Projection...
Phillips magnavox 55" projection
The coolant needs to be changed in the CRTs ( picture tubes) this is a very common problem with all phillips and magnavox rear projections. Changing the coolant will restore the color and brightness and stop the halo effect. You can get the phillips CRT coolant kit at the following link and it includes all the coolant and the step by step instruction CD with pictures. Its actually a fairly easy job. Heres the link its listed under the repair Kit category.
Oct 14, 2008 | Televison & Video
Philips - Magnavox Model # 9P6034 C103 Picture problems? Please Help
1 5 oz bottle should be enough for each tube. The small picture is caused by bad opto-couplers on the large signal board. Let me know if you need more info on the couplers and where to get them
May 15, 2008 | Televison & Video
Phillips Model 60pp920217f
No. your problem is related to the coolant in the green CRT has congealed with bacteria and needs to be changed. Thats what causes the halos and general poor picture and color quality. The blue should be changed also. The red for some reason doesnt seem to be affected by the bacteria problem. This is a common problem that happens with all projection TVs phillips and magnavox TVs
May 12, 2008 | Televison & Video
Need tv help
The sympton for contaminated CRT coolant is objects having a halo effect on the effected CRT color. The Blue and green are the CRTs most often contaminated. But to answer the question changing coolant does help. You can look into the crt with it turned on to see if the coolant is congealed. Just be carteful not to touch any components as you look into the CRT lens.
Feb 20, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox Projection
What is model number? A magnavox 51MP392 is a CRT rear projection type and doesn't use a bulb (unless he was refering to the CRT's as bulb). And they are prohibitively expensive.
Jan 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
Mitsubishi WD-73732 73" Television Logo
47 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
