Question about Sanyo DVW-7200 DVD/VCR
VHS tape will not eject.
My VHS tape will not eject. What can I do?
  • Louie  Role
    Louie Role May 11, 2010
    Hi and welcome to FixYa,
    Almost always, problems of this nature would indicate either a slipping or cut belt. Try unplugging the VCR fro about 10 minutes, press the eject button while plugging it back in. Should this not be corrective, the top cover would have to be removed to manually turn the gears/mechanism to extract the tape. This method however would allow a portion of the tape to slack and therefore possible have creases thereafter.
    Pls post back result(s). Good luck and Thank you for using FixYa.
You might have to unplug the player for about 1 to 2 minutes then the tape should automatically eject once you plug back into the oulet.
Posted on Jun 28, 2009
    Brigadier General:
  • 6,966 Answers
Initially, the top cover must be removed. Theis would allow you to:
  • manually eject the tape by turning the worn gear/mechanism. The only problem would be slack on the tape causing creases;
  • check/replace belt(s).
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
Posted on Jan 13, 2009
Have unit hooked up, but cannot get the vhs casset tape e to remain in player, keeps ejecting.
Typically a VHS tape has a button on the underside that unlocks when pressed inside the VHS player. The wheels unlock and move the tape in the VHS. If this doesn’t happen, the tape will eject.
Oct 26, 2017 | Televison & Video
Vhs player wont eject the tape?
If your Emerson TV is an older unit, the VHS player may have worn out
Jul 10, 2013 | Televison & Video
The elctromagnetic tape may be jammed inside. Open the front access to the VHS and inspect for some jams such as toys (if you have kids). You can try grabbing the VHS tape with something while pressing the eject button. Sometimes it needs some assistance to overcome the jam. Good luck!
Sep 15, 2011 | Televison & Video
Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
May 21, 2009 | Panasonic PV-7400 VHS VCR
My Panasonic Omnivision VHS won't eject
take the top off and eject it manualy, there is nothing else u can do with replacing a part, (small white spring loaded, ) probabaly
May 09, 2009 | Zenith ZHX-313 System
TAPE WILL NOT EJECT
Try unplugging the player from electrical power for several minutes. Plug the player back in and try to eject the tape.
Feb 26, 2009 | RCA VR639HF VHS VCR
VCR keeps ejecting the tape
It needs Belts/Idler/Pinch roller.. If you UNPLUG IT, remove the cover you can wind the tape back manually....When you can get a DVD player.
Sep 28, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
Vhs eject will not release tape.
I had a suggestion that did work. Reach into the VHS compartment with left hand and press down toward the back of the tape. With the right hand press the eject button a few times and the tape did come out. I would not buy a Samsung product again. No help from their 800 tech support. No more playing the VHS side of the player. Lynn
Jul 12, 2008 | Samsung DVD-V8600 DVD Player/VCR
Sony SLV-D300P DVD/VHS Player Tape Eject Problem
no reset, the infred led inside the unit are bad and need to be replaced common problem, they are located on the ends of the tape mech.
Dec 04, 2007 | Sony SLV-D300P DVD Player/VCR
Why does the VCR ejects my tape?
The VHS PlayPak adaptor uses 1 AA battery. When you place your VHS-C tape into the adaptor and close the cover, you will hear the motor running and the red piece on the adapter will move inside. Check the placement of the battery and make sure the clear shrink-wrap has been removed from the battery.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Televison & Video Logo
693 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
