Question about Vehicle Parts & Accessories
How to program a crimestoppers remote for the rs3-g3
2 Suggested Answers
SOURCE: How to program a crimestopper remote control model
To program this remote-
1) Open hood or ground GREY wire @ pin #7 on 12 pin connector coming from Crimestopper control module usually located under dash.
2) Turn key to on position.
3) Press red programming button coming from module 4 times, after a few seconds the parking lights on vehicle should flash 4 times.
4) Press button #1 pause, #2 pause, #3 pause, #4 pause on the remote you are programming, the lights should flash after ever button push. After all four codes (buttons) are learned, the unit will exit code learning mode. If not, turn off key and close hood. Hope this helps......BUZZ
Posted on Mar 07, 2011
How to hook up cool start rs3 g4
Crimestopper should be able to supply that information.
Mar 09, 2014 | rs3g4 cool start g4 series 1-way remote...
Remote starter
you have to get the exact remote as your old remote and it will tell you how to program it
Nov 12, 2013 | 2-Way Remote Starter
Crimestopper SP501 car alarm/remote starter will not respond. The 2 way one doesn't work, the sidekick does.
You need to program your crimestopper sp-501 key fobs, you need to program both the 2-way and the 1-way key fobs, during the same key fob program session. First find your valet button/switch, when you have found it, turn your ignition on and press the valet button four times, if you have a toggle type switch for a valet switch, toggle it up and down four times, when its in remote key fob program mode, it will honk your horn 4-times followed by 4-parking light flashes. Once your have done this press the lock button on the 2-way key fob, horn will honk and the 2-way will sing a little song to confirm programed, then press the lock button on the 1-way key fob the horn honk will be your confirm programed. turn ignition off this will exit you from program mode. then shut all doors and test key fobs for operation functions....hope this helps you out
Dec 03, 2011 | 2006 Hyundai Sonata
Hi: I have a crimestopper sp300 my old LCD remote was broken so I order a new one but I can set up because is not a override bottom on the main device,I want to know what's the right valet swicht wire...
Most valet switches are just a simple normally-open momentary push button like this:
http://www.radioshack.com/product/index.jsp?productId=2062508
Jul 01, 2011 | CrimeStopper SP300
How to program a crimestopper remote control model #chx433tx
Mar 07, 2011 | 4-Button Remote Start/Keyless Entry with...
Crimestopper Car starter buttons on remote are too sensitive.
wrap a wide rubber band around the remote button that way if it gets bumped it won't send the signal
Jan 09, 2010 | 2-Way Remote Starter
I have a crimestopper security system and the remote 1 way EZ Start remote (cs-34 II TX) battery keeps dying. How do I repair
if the battery keeps dying on your remote it probably has a bad contact somewhere inside you could order a new one from www.crimestopper.com you would have to have your unit model number for them to help you that is located on the unit under your dash
Oct 28, 2009 | Crimestopper CS34II Remote 4but rs1304...
How do I program the CS34-II TX remote starter?
the remote is universal so it can work for many so this is what you have to do look under your driver side dash get the model number off of the unit and go to www.crimestopper.com and then support tab where you will find a manuals click on that and there will be another spot that says manuals click on that and then find the model number you fund under your dash all this info was given to me by the tech support from crime stopper's and you can find that number on the same page
Oct 15, 2009 | Crimestopper CS34II Remote 4but rs1304...
Vehicle Parts & Accessories Logo
102 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
