Question about HP Officejet Pro L7680 All-In-One Printer
I have an HP L7680 all-in-one. It just started printing in a mirror image. What can I do to correct this?
  • Anonymous Feb 11, 2009
    My printer just began printing in a mirror image...and no one touched any printer settings....at least not intentionally!
    Jan Nichols
  • HP Master
  • 419 Answers
Sorry to correct... This is partly true but the key problem is because the driver has a bug in it...
Solution is posted here:
http://www.fixya.com/support/t1641997-mirror_image_printing
Posted on Feb 13, 2009
    Scholar:
  • 97 Answers
thats becoz the mirror image as be enabled on the printing preferances of the printer settings. go to the printer icon under printer and faxes, turn off the mirror image,,,,,,,,,,,
Regards,  raj_p5983
Posted on Jan 23, 2009
I have HP Office Jet L7680 All-in-one printer, for unknown reason it keeps printing the "mirror image" of a document I'm trying to print
Try this...
Go to <Start> <Printers> Right click on your printer and select properties. On the "advanced" tab uncheck "Print Mirror Image". I know the path works for other printers, but I can't validate it for you that model.
Source: http://h30434.www3.hp.com/t5/Other-printing-questions/Printing-in-mirror-image/m-p/19203/highlight/true#M1817
I am an HP employee. I do not represent HP on this site.
Aug 24, 2010 | HP Officejet Pro L7680 All-In-One Printer
I have a HP Officejet Pro L7680 All-in-One It appears to print the text in a reverse mode (just like Koranic Text). What should I do for the text to come out normal (readable)?
The image is mirrored in the printer options. Find the check mark next to "Mirrored" and uncheck it.
On the same tab of the driver you have also "Inverted" option.
Both options are usuable for press release. Mirrored images are printed on transparancy and used for preparing the drums of the typographic machines. The Inverted image is for preparing photopolymer stamps.
Aug 05, 2010 | HP Officejet Pro L7680 All-In-One Printer
Can you use mirror image when copying? I have a HP L7680
The copy function does not support mirror images. I'd scan it and manipulate a mirror image with photo software and then just print it.
Oct 30, 2009 | HP Officejet Pro L7680 All-In-One Printer
Print mirror image gel printer GX700
The mirror image setting is in the printer properties/ printing preferences. You can either go to control panel/printers/properties, or when you press print, and the window pops up, in printing preferences you can choose the mirror image setting.
Oct 13, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet J5780 now prints in mirror image. I
Go to printing preferences and change the mirror image option to off and then try printing again. Use this figure as a guide:
Sep 08, 2009 | HP Officejet Pro L7680 All-In-One Printer
Mirror image printing
When you first click on print a window opens with boxes at the bottom. If you choose printing preferences another box will open where you can turn off mirror image printing.
Jul 24, 2009 | HP Officejet Pro L7680 All-In-One Printer
How print iron on transfers
Yes, you need to "MIRROR" the image. Go to printer properties and select the ADVANCED TAB. Click on the MIRROR setting then print onto the transfer paper. The image should print out backwards like you are looking at it in a mirror. When you iron it onto a shirt, it will come out correct.
Jun 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
Started to print in reverse
Check the printer preferences for the "Mirror Image" option and un-check it - this is used for printing Iron-on transfers for T-Shirts.
I hope that solves your Problem, If so kindly accept it.
Thank You, Arjun.
Apr 02, 2009 | HP Officejet Pro L7680 All-In-One Printer
Mirror Image printing
This is caused by an early driver version provided with the printer.
Download the latest version from the HP website, unplug your printer from your computer then uninstall your existing driver. Once that's successfully completely install the new driver version.
Unfortunately this doesn't always resolve the problem straight away so you may need to repeat this.
To check if you've resolved the problem:
- Go to START > Printers & Faxes
- Locate your L7780 printer
- right click and choose "printing preferences"
- choose the "Two-Sided (Duplex) printing" printing shortcut
- click on the "Advanced" tab
- look at the setting for "Mirror Image"... If you've succeeded this should now be set to "Off"... If it's "On" you still have a problem.
The problem itself is caused by some duff default settings which seem to stick whenever you've done anything that uses the "Two-Sided (Duplex) printing" Printing shortcut provided in the printing preferences.
In particular I've seen this crop up with PDF files...
The new driver does seem to resolve this but a further work around is to define a new duplex setting that has the correct "Advanced" settings and has "Mirror image" set to Off.
This solution also works for the K5400, L7580, L7680, etc...
Feb 04, 2009 | HP Officejet Pro L7680 All-In-One Printer
Prints in mirror image
Go into Printer preferences and turn off mirror image.
Jan 11, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All-In-One Printer Logo
113 people viewed this question
Ben Johnson
