Question about Ovens
Why will my Garland master 200 convection oven will not heat up?
2 Suggested Answers
SOURCE: kitchenaid KEBC177 electric convection oven will not heat
This is a design flaw in the Kitchenaid convection ovens. I can help fix this problem if you have a built in oven (I don't know if the parts are located in the same place for stand alone ovens). First it is not a FUSE that has blown rather it is the thermostat in the rear of the oven. (Part #4452223) This small part cost about $37 US and after shipping it will cost you about $47. I tried to get an estimate from an electrician as to what they would charge for the part and to come out and fix the oven an the price was about $90 for the part and anywhere between $100 and $170 more for the service call + repair! After a day of frustration I decided to tackle the problem myself.
The very first thing you must do is shut off the circuit breaker to the oven and put a very large sign on the panel that reads DO NOT TOUCH! That is 220 volts to that oven and while most panels have just the oven ont circuit you dont want anyone reactivating that circuit by mistake!
The next part requires a little work. Find the side panel screws (usually located in the oven door) and remove the two panel flanges that cover the 2 or 4 mounting screws that keep the oven in the wall. Now go underneath the oven and find the power junction box, take off the cover and disconnect the wires that run from the oven. Remember which goes where. Next remove the little nut that holds the electical conduit cable to the junction box then loosen the wires. Once this is done you can now slide the oven out and get to the thermostat.
This part requires a little elbow grease. Find a platform or table that fits just under where the stove will slide out and slide the oven on top of the table or whatever for support. In the back of the oven there will be a sheet metal panel that covers the thermostat and other wires, remove the 5 or 6 screws that hold this panel on and put the panel aside. Almost in the middle of the oven's back you will see a little black device with two wires running out of it (one red the other white or yellow). It will have the part number on its front, remove the wire and notice that the thermostat is half red and half white (remember this for the new part will have the same markings) the red wire goes onto the lead coming from the red markings. When you have the new part simply put the new one in (remember: the red side to the red wire), attach it to the back of the oven, replace the sheet metal cover and slide the oven back into place securing it with the screws. Viola! you are done! Turn on the power and then test the oven (I used the broil setting to warm it up then switch to a temperature setting). The entire process took me about an hour and I am NOT a handyman!
For about $50 and a little work you will save yourself from $150 to $250. Not to mention the repairmen won't have a clue as to what the problem is or who will attempt to sell you a new front panel or perform other unnecessary work.
Posted on Dec 09, 2008
I have a Garland Mater 200 electric oven and the fan continues to run even with the door open. Is there a switch / sensor that controls that?
https://www.manualslib.com/manual/55869/Garland-200.html?page=103#manual
This web site had a manual that may answer you question. It seems that here is a heat/cool switch. The cool switch is designed to function to cool the oven down by running the fan with the door open. If you close the door, it will heat so the door has to stay open.
Aug 20, 2017 | Garland Ovens
Oven cooks too fast and burns the food
My electric oven, Garland master 200 only reach a maximum of 250* and I only saw 1 of 3 elements turn red
Dec 14, 2012 | Garland Convection Oven - MCO-NAT Gas
Model TE2B garland does the fan run to move
The fan runs to circulate the heat inside the oven for more even and faster cooking...That is how a convection oven works :)
Jan 14, 2010 | Garland Convection Oven - MCO-NAT Gas
My garland air deck will not heat up
I own a large repair company we charge these fees for our tech. ability I often give you people free advise but when you insult our techs try to figure it out yourself then you will know why we chargey the way I would not give you free advise you would not say thank you
Dec 31, 2008 | Garland M-1 GL Gas Single Oven
GARLAND CONVEC. OVEN - CONVEC. NOT RUNNING
it sounds to me like the door switch is not making. if you take off the bottom panel the switch is to your rightat the bottom. make sure that you kil power first brfore you remove the panet.
Dec 22, 2008 | Garland Convection Oven - MCO-NAT Gas
Ovens Logo
21 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
