How do I adjust the margin for the epson TM-L90 receipt machine
When the receipt prints out it has a 1 inch border on the left side.
CompuGuy44
  • 432 Answers
SOURCE: Borders outside printable area
Adjust the margins in the software you are using.
Posted on Jun 26, 2007
SOURCE: 1 inch of left margin left even on the self test
Try using the "manual" width calibration. With the printer on, press and hold the green button. It will flash once, then twice, e.g. the sequence:
after the 5th flash, let go of the button. The printer will begin drawing rectangles which get wider and wider. Press the green button once (don't hold it) to indicate "when" the width is appropriate. However, I found the width was best calibrated when I let the printer draw rectangles right until the edge (where it automatically stops).
Posted on Jul 08, 2008
jarifa
  • 30 Answers
SOURCE: The print cartridge cradle cannot move.
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
749
Posted on Feb 27, 2009
SOURCE: Epson TM-U220D Receipt Printing Problem
mau download driver epson tm-u220d ga ada...
klo mau cari dimana yah
Posted on May 11, 2009
SOURCE: Epson TM-U375
The Print head ribbon cable is 99% of the problems on printing! Don't worry about any cable coming from the unit to the machine itself. Now there is a Platen bar that the ink ribbon presses on to print. So if is light on one side or both you can adjust that! Go from the back side or the unit, you should see a black box thing. On each side is adjustments, stick a flat head, small, screwdriver in there and turn it. Be careful!!! You do not want to turn to hard it is plastic and will strip!!! That will adjust your platen bar.
If any more problems let me know! I work on these everyday!! Welch Systems Inc. Peoria, IL
Posted on Mar 08, 2010
Will not print longer receipts. How do I fix this problem
PDF]TM-T70II Brochure - Epson
www.epson.com/alf_upload/pos/pdfs/.../brochure_tm-t70ii.pdf
EpsonThe TM-T70II prints receipts and graphics at the same fast ... Print technology, the TM-T70II can print ... It also offers Serial, Ethernet and USB options ... long-lasting autocutter and all-front access. ... are easy to use and do not affect print ... Space-Saving Thermal Printer with Easy All-Front Access ... Epson Dark Gray (EDG).
Epson C31CD38A9971 TM-T70II Front-Access Thermal ...
www.newegg.com > ... > Receipt Printer > Epson America
Newegg(Do not use your browser's "Refresh" button). ...... Streamline your POS system withEpson's space-saving TM-T70II printer. ... Ethernet and USB options, enabling flexible mobile and web-based receipt printing. ... including drop-in paper loading, long-lasting autocutter and all-front access. ... Color, Epson Dark Gray (EDG).
Epson TM-T70II Series - Epson
www.epson.co.uk > Home > Retail
EpsonEpson TM-T70II thermal receipt printer for barcode, ticket printing is for ... The latest innovation in Epson's long line of receipt printers are its series of smart ... same
Jan 27, 2016 | Epson T70II - SPACE-SAVING - PUSB & USB -...
Automatic paper adjustment
Goto File, Page Set Up, Margins.
Be sure "Marigns" is in the "Inches" setting.
Enter 3.0 inch in two boxes; Topp, & Bottom.
Good Luck,
Aug 04, 2009 | Epson LQ 580 Matrix Printer
I print borderless several times & found white border both side
This is because the image is of a different aspect ratio than the paper. That is, if your image's dimension is 8x12 inch and you are trying to print it on an 8x10-inch paper, the printer will adjust the longer side to 10 inches. Hence the shorter side will become less than 8 inches. This will lead to white border on the shorter side. If you try to adjust this, the longer side will fall out of the paper and hence in the print, this portion will be cut.
So please understand that this is normal. One option to prevent this is to crop the image to fit the paper size.
Apr 13, 2009 | Epson Stylus Photo R200 InkJet Printer
Oct 21, 2008 | Epson TM-U220 Matrix Printer
An extra cut about 1 inch after the invoice is printed
Go into printer friendly setup, then select the receipt printer and choose the option 'Cut at this station'. Make sure it is unchecked. Your problem solved ;)
Aug 10, 2008 | Epson TM T88 Thermal Printer
Printing Borderless at 42" width?
Set the roll size to 44 inch, set your left margin to 0 (in your preprint software), experiment. With margins set at 0, using Onyx Productionhouse 7.3, the 9800 will print approx 41.8 inch image on 42 inch roll 43.8 on 44, etc. This is considered borderless printing. No matter what size roll you tell the printer it has in it, it will print to about an eighth to a sixteenth of an inch short of the paper's actual edge (that's the left side of the roll paper coming out of the printer - the right side of the print). If you load, for example, a 36 inch roll, tell the printer its a 44 inch roll, and send a 40 inch wide print, with a left margin of 0 it will print around 35.8 inches, cutting off the image just before it would overprint and get ink on the machine (1/8 - 1/16inch before the edge of your 36 inch stock). It is possible that these tollerances will be different depending on what software you send your images with... hope this helps!
May 08, 2008 | Epson Stylus Pro 9800 InkJet Printer
??????????? printer doesn't stop printing, help!
Turn off the printer. Hold down the power on button for 20 secounds. Did that clear it up Pete ??
Jul 01, 2007 | Epson TM-L90
26 people viewed this question
jasbo
jasbo
