Question about Bose SoundDock digital music system Docking Station for iPod - White (35703)
Bose IPod Docking Station Remote not working
I did just change the battery, thinking that would solve the problem, but still NOTHING . . . Any ideas?
  • 5 more comments
  • Anonymous Jan 13, 2009
    i just bought a new battery too, and the remote still doesn't work.
  • Anonymous Jan 24, 2009
    Same thing changed the battery, and still NO results. Can anyone give advise or help solve the problem(remote problem, receiver problem, or unit problem)?
  • MHERDA Feb 28, 2009
    VOLUME CONTROL ON REMOTE WORKS BUT THE REST OF THE FEATURES ON THE REMOTE ONLY CAUSE THE BOSE UNIT LIGHT TO FLASH BUT NO CHANGE ON IPOD. BOSE IS SENDING OUT A NEW REMOTE TO START TROUBLE SHOOTING THR PROBLEM.
  • Anonymous Mar 21, 2009
    remote control will not work this the ipod.
  • will123456 Apr 10, 2009
    I had the same problem and tried the solution suggested by adlerpsy I didn't have a can of air so used a bicycle pump! it worked a treat. Thanks adlerpsy
  • westfall513
    westfall513 Feb 08, 2012
    Using a hair dryer - no heat - and blowing around the grill for a minute or so worked. I am not sure where the remote sensor is, but I leaned the Bose so that light reflects off of what's behind the grill and you can see what appears to be one or two areas that look like the sensor. Concentrate the air on them, problem solved.
  • Malcolm Petrie
    Malcolm Petrie May 30, 2016
    I used the small brush tool on a dyson cordless vac. So that's what it is used for :-)
    Worked perfectly, many thanks for the tip.
I had the same problem. Very frustrating. Tried everything. Discovered the solution. The device that the remote control sends a signal to is located inside the grill of the SoundDock. The receiving device has a lens (which we can't see since it is hidden inside the grill). It can get dust on it that interferes in the signal being received and the remote can then only adjust the volume up and down but no other feature. I sprayed my grill with a can of air. Not being sure exactly where the device is, I sprayed the entire grill, being careful to spray from six inches or so from the grill. Just like that - the remote then was immediaely fully functional and I have ever since been able to use all of the remote's functions. Steve
Posted on Mar 21, 2009
Battery in Nano won't charge while in Bose docking station.......any ideas?
Posted on Mar 19, 2009
To expand on lskhn's solution. If the light is not coming on and the battery has alread been changed it may be the connection. I fixed mine by folding aluminum foil three thicknesses and slid the battery in on top making a better connection to the lead that goes to the flat of the battery. I was able to hold the foil in the right distance with excess and then removed the excess once the battery sled was in place.
Posted on Dec 09, 2010
  • mikeylikes Dec 26, 2010
    Take the battery out and with your fingernail stretch the spring out a little so it will push the battery up more. Did the trick when the remote wasn't working out of the box brand new.
Very cheap replacements on e.bay about £7 last time i looked
Posted on Jan 22, 2009
Have you tried another Ipod in the dock? I tried another Ipod and everything worked perfectly, seems like it is an Ipod issue and not a Sounddock issue on mine
Posted on Aug 15, 2011
Hey...dnt worry....I had the same problem
The Bose Remote is light sensitive...and it does not work with a lot of ambient light.....try switching the lights of ur room and see!!,:)
-Rohit
Posted on Jun 01, 2011
  • 3 Answers
Some time the connection to the battery is bad maybe try a metal shim to make the connection more solid.
had same problem replaced batter no change started to press the play pause hard and managed to push the battery closer to the metal.
Posted on Oct 28, 2009
  • Alexander Kahn Oct 18, 2013
    I must have been drunk when I wrote this... It makes almost no sense lol
  • Alex Kahn
    Alex Kahn Jul 15, 2014
    Bah!
    New Friend:
Found the same problem and worked out the ipod wasn't in the cradle properly, it was playing sound but no control from the remote (RWD, FFD etc) just wiggled it in the cradle a bit and it works fine now..
Posted on Nov 13, 2012
I popped the grill off after using a hair dryer on cool didn't do the trick and cleaned the sensor(surrounded by black foam material) with Vodka. Works like it's supposed to now.
Posted on Apr 25, 2010
IPOD works fine;but it,s unresponsive in the Bose docking station/speaker system. Remote has fresh battery. Only used a couple times. Thoughts?
I had the same problem and once I reset the ipod it started working again. Don't know if this will work for you but it worked for me, Hope it helps.
Aug 28, 2010 | Bose SoundDock iPod Digital Music system...
Bose sounddock portable problem
You can now order a new PCB for the Bose Sounddock PORTABLE at http://www.chargeconverter.com/store/sounddock/portable_repair
Jul 11, 2010 | Bose SoundDock Portable Digital Music...
Bose Sound Dock remote control - only volume works
My remote worked perfectly until I changed the battery. The original battery was CL 2032 and I replaced it with DL 2032. After replacing the battery, only the volume control works. The off button will only fade the sound while the button is depressed. Release the button, and the volume returns to the original level and the unit remains On.
None of the other buttons work.
If you've found a solution, please post it here.
Oct 03, 2009 | Bose SoundDock® (Black) Docking Station...
Bose Docking Station incompatibility with IPOD Touch
You need to reset your ipod. You can go online to find out how to do this. I had to do it with mine and then it worked perfectly.
Aug 08, 2009 | Bose SoundDock digital music system...
Bose sound dock - no sound comes through it but my ipod works with the ear plugs so it's not my ipod
I had this problem for the pat two days. Believe it or not I took my Ipod touch of the dock. Shut the power off to the Ipod to reset it. Also the power to the docking station. turned everything back on. Put the Ipod back into the docking station and heard the beep.. and hit play and it was working again. Not sure but shutting Ipod off does act like a reset.
Jul 19, 2009 | Bose SoundDock digital music system...
Bose docking station problem. Remote will not work on either my ipod touch or I Phone. The volume buttons work on the remote but the skip and pause/play buttons do not. The Bose is brand new and straight...
If it is brand new. It is under warranty. Go back to the store where it was purchased and tell them the problem. They should replace it with another new one. Have them show you how to use it on all of the functions on your Bose Docking Station. Make sure you tell them about the ipod Touch and the iPhone.
Jun 07, 2009 | Bose SoundDock digital music system...
Does the new bose dock station charge the new ipod touch (32g)?
The new SoundDock II charges your new iPod touch and is fully compatible all iPods and the iPhone 3G. Also the SoundDock Portable will do this. But..
Better news-> Call Bose. They can upgrade the 30-pin connector to charge via USB-only and function with the remote as well. $99. This will make your iPod touch 100% compatible and somewhat future-proof your SoundDock. If the SoundDock was purchased within 90 days (at full retail price), they will do the upgrade for a smaller fee or even free I think.. (new 1 year warranty given with repair/mod) btw- This is an Apple issue, not a Bose issue. All 3rd party iPod connection devices had to make this change at some point.
May 31, 2009 | Bose SoundDock digital music system...
i have the same problem with the old docks not charging my ipod touch and yes new bose docks and ihomes charge the 32g ipod touch
May 15, 2009 | Bose SoundDock digital music system...
I have an ipod touch 8G I purchased a Bose soundock II. The sound is great but the remote only controls the volume. I cannot change tracks, move through playlists and when I hit the off button on the Bose...
Bothe the docking station and the remote are useless I recommend you buy a universal remote control.For the Ipod switching off-it does'nt switch off reason being it has it's own battery and does not depend on the electrical power of the docking station.
Mar 06, 2009 | Apple Bose SoundDock Series II Digital...
Bose docking statoin
They both use the same speakers, my personal opinion deems they are both the same. However the second SoundDock charges via USB pin, so it is future proof for future iPods.
Dec 09, 2008 | Bose SoundDock digital music system...
Bose SoundDock digital music system Docking Station for iPod - White (35703) Logo
14,132 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
