Question about Toshiba 32A33 32" TV
Sound/picture doesn't work until warms up.
When I tap the front above the on/off switch it starts working.
  • thill1 Feb 04, 2009
    I have the same issue, takes about 3 minutes for sound and picture to turn on. I read to spray the switch, is that the main on/off button on the front of the TV? and if it is do I just spray around this button and hope that it pentrates into the switch behind??
  • 227 Answers
Go to radio/tv supply and get a can of contact cleaner and spray the switch. Be sure the spray is safe for plastic.
Posted on Jan 11, 2009
What will be the problem if i have a taping noise when i start my car until it gets warm mitsubishi 380
A tapping noise that starts out cold and goes away when warm is usually caused by a valve lifter inside the engine. The lifter may be worn/leaking down and will be noisy until it fills with oil pressure. You can try an oil additive ( Lucas Oil Additive ) available at most part stores works very well with noisy lifters. Another noise that can happen cold and go away when warm is an exhaust manifold leak. However, this is normally a ticking type sound rather than a tapping sound.
Jan 19, 2016 | Mitsubishi Cars & Trucks
When I try to start my 1994 WR250, 2 stroke, it takes a million kicks, or 3 or 4 good pushes down a steep hill, popping the clutch. When I do get it started, once it warms up it will idle, and start back...
Sounds like a combination of leaking fuel tap and old fuel.
When you park it overnight or longer, pull the fuel hose off the carb , and drain the carb bowl.
So when you next ride it, reconnnect the fuel line, turn on the fuel tap long enough to fill the carb, 10 secs,then turn it off to start the bike, turn it back on when the bike starts.
even if you replace the fuel tap this process can help.
I have a 91 wr still sitting under the house from younger times, and yes very good bike
Aug 13, 2011 | Yamaha WR 250 F Motorcycles
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital...
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital temperature on the climate control is not correct. When it states that it is below 30 degrees on the ext and it is warm outside the air wont be cold. Once it starts going above 30 degrees the air gets colder. Today the blower stop working all together. Was told it maybe the climate control unit was bad. You can hear the door opening/shutting when you switch the temp from cold to hot. But there was no heat blowing out whatsoever in the winter time. Could you please give me your opinion on whether or not it is the climate control unit or something else?
Jul 11, 2011 | 2000 Pontiac Grand Prix
I have an old tv, a small one, that works OK when you first turn it on, then after 5 or ten minutes the picture goes black. But, the picture will come on briefly if you lightly tap on the top of the TV (or...
There's a solder connection, probably on the CRT board that s going bad. It's an easy fix but if you're not trained to be working on CRT tvs I suggest finding someone who is. Good luck
Mar 05, 2010 | Zenith Televison & Video
Tapping nosie in lower crankcase when starting 2.5L engine
Probably just a hydralic lifter tapping when cold. Change the oil in it and let it warm up before taking off. Be sure and use the correct oil, 10w/30 or whatever the manual says for your climate.
May 22, 2009 | 1995 Jeep Wrangler
Canon EOS 40D shoots on its own.
Sounds like a software issue, try to upgrade or reload the firmware.
I hope it helps :)
Oct 26, 2008 | Canon EOS 40D Digital Camera
Picture fails
sounds like a high voltage issue, it will have to go in, i dont recommend self servicing that. may sound strange but Ive seen several tvs go by way of spouse having a plant above or near the tv, that person watering it and a few hours later mad spouse sitting in front of a busted tv that sounded just like that. also I had a cat that sprayed one and it did that. just a couple ideas for ya.
Jul 12, 2008 | Philips Televison & Video
Toshiba 32A33 32" TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
