Question about Acer n30 Pocket PC
ACER n30 PDA - RENEW THE BATTERY?
Can anybody help? I am having trouble with the battery life on my Acern30. I have bought a longer life battery but cannot find how the PDA comes apart. There are 4 thin screws on the corners of the back panel, but when removed nothing happens? Thanks in anticipation.
  • Tony Norris Jun 24, 2007
    Hi, due to the delay in receiving an answer to my paid question, I was forced to pay a company to replace the battery for me.
    Thanks for trying though.
  • 944 Answers
There is a lot of very confusing information about this battery pack and PDA - many companies are selling the battery without instructions and many reviewers/users claim that there is no way to replace the battery. Acer makes no mention of this either way and didn't seem too keen to answer the question. The screws that you mention appear to be the ones as at least one company is selling the battery with a screwdriver included that appears to be the one for the four thin screws. Just make sure there are no other screws hiding under a sticker or similar - running a stylus over any stickers should reveal any potential screws that may have to be removed (almost certainly opening the case will void the warranty if still an issue) Another company is also selling an "unmarking case opening tool" which is essentially a small plastic spatula - therefore I believe that when the screws are out you should be able to push something gently into the gap between the shells, popping it open - from photos it would appear that the small groove between the shells in the corners are the places to start. BE gentle and careful with this as the possibility of damage is there, but once one part of the shells start to separate you should be able to see clearer what is holding them together. If you want a bit more info then try e-mailing these guys; http://www.pdasmart.com/pda-battery-center/battery_ACER_ACER-N30_battery_center.htm They should be able to help as they do sell the battery and are well respected. Hope this helps and good luck :) - if you are in any doubt about doing it yourself then i recommend finding a repair shop near you, although I cannot believe it is too complicated to open. if there is any confusion about actually swapping the battery once the case is open, please post back with a photo of the inside and I hope we can help, but i think it should be easy enough once you are in - make sure you ground yourself properly and touch as little as necessary when inside.
Posted on Jun 21, 2007
SOURCE:
I own a Lenovo Mini Wireless Mouse (Model number N30). It has been working fine since the last 4 months I have owned it. However, I noticed today that the small light on the top of the mouse is blinking...
It's indeed the low batteries indicator. I have a Lenovo N30 myself.
I suggest you use a good pair of rechargeable AAA batteries.
They last longer than regular alkaline.
Best regards.
Source: Lenovo N30 User's Manual. Own experience.
Feb 17, 2011 | Lenovo Mini Wireless Laser N10 Mouse
Acer N30 PDA charging problem
My PDA n30 is not a year old yet - when I put it to sync and charge everything looks fine but when I unplug it does not stay charged - it blacks out straightaway.
Please help
Jun 09, 2009 | Acer n30 Pocket PC
Pin allocation in 26 pin connector?
try- http://pinouts.ru/PDA/acer_n30_pinout.shtml John
Apr 09, 2009 | Acer n30 Pocket PC
Need new charger and battery and new pen
ebay is your best bet...
Try www.ebay.com and on the search space, copy and paste on the following ebay Auction IDs (just paste the number I give you):
Battery:
eBay Auction ID: 270215466248
Description:
1.5A Battery for Acer N30 N-30&Yakumo 1038006/PS1020#1
Approx. 7GBP = 13USD
Stylus (pack of 3):
eBay Auction ID: 280204418443
M509 3 pcs stylus touch pen for acer N30 N 30 PDA
Approx 1.5GBP = 3USD
Universal Travel Charger:
eBay Auction ID: 270216695513
Travel Charger for Acer N30 (UK/EU/US/OZ Charger)
Approx 7GBP = 13USD
These prices do not include shipping which may vary depending on your location... (these items usually ship from Hong Kong).
PS: these are auctions so the designated items may only be available for a limited number of days...
Hope this helps
Mar 03, 2008 | Acer n30 Pocket PC
Hp rx1950 battery life.
I have the same problem, after I did the hard reset and installed no programs, this power problem disappeared. But once i installed any programs, PDA battery life became no longer than 2 days, which is strange.
Jan 06, 2008 | HP iPAQ rx1950 Pocket PC
Acer n30 will not turn on
Trya hard reset, mine was off for 6+ months and wouldnt charge. After a couple of hard resets - bingo, fully charged battery.
Oct 31, 2007 | Acer n30 Pocket PC
Acer N30 battery problem (even new battery does not last enough)
try checking your power saving options, you can drop down the backlight a little lower to extend battery life. Also you can lower down the volume of the system sound and check if the bluetooth is on, then turn it off. Recharge it and then check if the battery life extends. You also need to occasionally soft-reset the n30
Oct 21, 2007 | Acer n30 Pocket PC
My n30 can't charge, but turns on under charging
hi, I had the same problem so i checked some other forums. I then found the answer. While your acer is plugged in, hard reset it, this switch is on the bottom of the machine. Switch the hard reset thing to the left for five secs, then back to the right. The green light should start flashing! You just fixed you acer!
Jul 28, 2007 | Acer n30 Pocket PC
Acer n 30 doesn't make phone calls
do you want to use the N30 over WAP/GPRS, dial-up land land line or a GSM modem. The N30 does not have any kind of modem or cellular capability built-in, only 'blue tooth' so depending on your requirements you will have to obtain a sutable external device. You are not compelled to use a mobilephone hand set though.
Jul 09, 2007 | Acer n30 Pocket PC
Acer n30 Pocket PC Logo
263 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
