Question about Technics Audio Players & Recorders
Technics sa-eh50 fault code f61
Fault code F61 appears when i switch on the Reciever?
marsrover
  • 682 Answers
SOURCE: Fault code
speaker cord connector problem:-
remove all speaker connectors and insert it one by one each time until you find the bad one and change its connector with a new one.
(you must play something and listen).if all above does not work you will have problem in power supply and need to fix.
Posted on Apr 04, 2008
  • 336 Answers
SOURCE: stereo system technics sc-dv150 showing fault f61 how do i
f61 is a bad voltage code. I will probably need an output ic or a voltage ic.
Posted on Oct 16, 2009
  • 1121 Answers
SOURCE: Repeated F61 fault code on Panasonic Home cinema
fans dirty. clean-it with a soft small brush and vacuum cleaner
Posted on Feb 16, 2010
heavyice
  • 374 Answers
SOURCE: panasonic surround sound system model # sa-ht95
Error code ' F61 ' on most Panasonic models indicate that the built-in diagnostics has sensed a fault at the output stage. This would normally refer to a failed output amplifier IC (?P/N RSN704D66P?). In some instances, the fault could also be triggered by:
  • strands of Speaker wires inadvertently touching each other;
  • faulty speakers;
  • failed Cooling Fan of the output IC.
Options then are:
  • consider a DIY (do-it-yourself) repair only if familiar with electronic components & circuitry, use of a DVM/VOM and a soldering iron. Access to a Service manual would be an advanatge;
  • seek the services of an authorized service center specially if the unit is still under warranty;
  • consider other options based on downtime, cost of repair, parts of availability, age of unit and prices of comparable but newer models.
Good luck
Posted on Mar 06, 2010
gopakumarg43
  • 74136 Answers
SOURCE: f61 technics hifi fault
What is the problem you faces with this device? Provide more details please.
Posted on Jun 06, 2012
Error Code F61. Do I need a new fan?
it is fault of cooling system, and sound output error, if fan is disconnected or not running F61 comes on screen then nothing happends, power sound ic is the main cause of the device, not only cleaning works, may need to change the the power sound out put ic.
Nov 02, 2015 | Panasonic Sa-pt750 Multi 5 Dvd Player...
Sa-ht545 error code f61- comes up upon statrting
F61 just equal 'power fault'
Generally a fault with either audio power amp ic (IC 501) or power supply ic IC 502.
As both said ICs get very got first remove bottom steel grill and with the power off and capacitors drained (shorted together with a low ohms resistor or leave unit powered down for a few hours) resolder the ICs legs if there are any signs of cracks aka dry solder joints.
Hope that helps.......
Jul 09, 2008 | Panasonic Audio Players & Recorders
Technics f61
Look for bad solder connections on the amp IC's and voltage regulators...common problem on these.
Dec 08, 2013 | Audio Players & Recorders
F61 Error on SA-HT930 Panasonic
As sugested by many experts.I replaced the ic no rsn311w 64d,still the error code f61 appears.Now where is the fault.?
this is for the Panasonic sa-ht 880.
Aug 28, 2012 | Panasonic sa-ht930 Home Theater Audio...
F61 cd stereo system SA-AK640
F61 is an Error Code,more specifically a Fault in the Power Amp,the Stereo will need to be sent into Panasonic for Repairs.
Jan 09, 2011 | Panasonic SC-AK640 Shelf System
Stereo system technics sc-dv150 showing fault f61 how do i
Oct 15, 2009 | Audio Players & Recorders
I WHAT IS FULT OF F61 IN SA-AK177
HELLO
F61 means a protection code which normally means there is a fault with the audio output IC. Check all your cables for shorts etc, and try hooking it back up. If the error is still there you'll have to put it in for service.
ALL THE BEST!
Sep 01, 2009 | Panasonic Audio Players & Recorders
Panasonic stereo SA-PM28 displays fault code F61 then switches off
Hi dearnley1
The error code your unit is presenting relates to either a speaker cabling fault or a fault speaker. Sometimes, it is neither, and may be a fault inside the unit. Needless to say the unit is in protection moe to prevent more damage occurring. Check you speaker wiring for any short circuits or frayed wires. If all appears to be ok, disconnect the wires from the unit and see if it turns on and stays on then. If it still presents f61 with speakers and cable disconnected, then I am afraid that you may need to take the unit to a Kenwood service center near to you for an inspection . Good luck
regards
Graeme
Apr 06, 2008 | Audio Players & Recorders
Panasonic sa-ak25
the problem is F61 is speaker protection mode on.
fault with your audio power amp section.
i can help you.
nuwan.
Oct 09, 2007 | Sony MHC-G100 Shelf System
91 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
