Question about Plumbing
Delta touch 2.0 faucet starts slow
Faucet will flow slowly then speed up sometimes if left running
arealplumber
  • 33 Answers
SOURCE: low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Posted on Dec 05, 2008
arealplumber
  • 33 Answers
SOURCE: DELTA MODEL 470-WH LOW WATER FLOW AT KITCHEN FAUCET
This could be a couple of things.
  1. First remove the aerator from the wand and make sure you have plenty of flow with it off.
  2. If there is flow clean or replace the aerator.
  3. Remove the wand and look between the hose connection and the wand there should be a screen between them. Remove the screen and clean or replace.
  4. Make sure hose is kinking under the sink.
If you need a diagram of the faucet with part numbers here is the link:
Delta 470
Hope this helps!
  • 35 Answers
SOURCE: slow running tap
If you have recently turned off your water supply you may have disturbed some sediment in the water lines causing this problem.....Unscrew the airator at the end of the faucet and there is a screen inside( take note how this screen is in place). This should give you water pressure back!
Posted on Dec 19, 2008
faceofftech
  • 185 Answers
SOURCE: My Kohler single lever pull-out faucet stopped
Fix a kohler faucet
most likely the gasket broke inside the lever, you have to replace it.
shut the water off from the angle stop (valve under the sink) both hot and cold.
use an allen wrench ("L" wrench) to remove the tiny screw around the lever, >>>>before you do that place a rag covering the drain for if you drop it<<<< after that pull the lever out, that will show the inside of the faucet. use an adjustable wrench to remove the actuator from the base. when you get that part out you should be able to see the damage to the gasket. At that point you need a phillips screwdriver to get the gasket out and back in >>>>take the damaged gasket to the hardware store<<<< and get a replacement you may have to change more than one. after you get all the gaskets in place, reinsert the actuator and don't forget to tight it up with the adjustable wrench. center it so it would dispense the same amount of hot and cold water, replace the lever reinsert the tiny screw with the "L" wrench. turn on water from angle valves and test faucet.
that should do it and save you about 300 bucks
if it works for you don't forget to rate me
Posted on Apr 28, 2010
  • 349 Answers
SOURCE: Poor hot water pressure form Delta single lever faucet
it can be adjust take handle off and remove locking collar first turn water off,
it has a metal or plastic ball with a shaft for the handle it may have spun or a washer may be bad under it,
you can get a replacement at lowes or Home depot to replace it if this is the problem .
Posted on May 05, 2010
My delta touch faucet only let a trickle of water run I have replaced the batteries, it is a model 19922 sssd dst
Have you unscrewed and checked the aerator? It could have trapped debris built up inside thus preventing efficient flow.
Nov 02, 2014 | Plumbing
I just installed a new shower with no tub. I have water to my delta fixture but no water out the head. I used shark bite connectors and did not solder the fittings
Are your walls still open? I assume they are as you'd be unlikely to close them up without having had tested your water flow. Here is what I would do.
1.) use the orange plastic C shaped release tool to depress the white plastic ring on the shark bite fitting that you have on the delta side of the Delta-ShowerHead connection.
2.) Carefully and slowly turn water on and see if water is exiting the fixture where you expect it to.
IF yes, water is coming out of the delta fixture then you know the flow problem is somewhere between the delta fixture and your shower head.
IF no, water is not coming out the delta fixture then you need to re-access how you connected the supply lines to the delta fixture.
Oct 24, 2014 | Delta & Single Handle Shower Faucet
Delta 2467 water flow has gotten very slow. Do I have to remove the whole faucet from under the sink, or is there a way to clean it out from up above. Already replaced the faucet cartridges and the...
Hi, i would suggest to check the faucet and make some adjustment for proper water flow and if you already replaced the faucet then this problem should not occur , i have had same problem and i had called A-General for this and they fixed easily all issues ,please take some help http://www.a-general.com
Jul 22, 2011 | Delta Faucet Delta 2457 Orleans Two Handle...
Need help Have new house with 2 handle delta faucets, everything worked fine yesterday till I shut water off to install hot water heater now 2 different sinks have no flow hot or cold. Checked lines down...
Try opening all of your faucets in the house including the two that don't work. then go around the house and shut off one faucet at a time. Sometimes the air that gets trapped in a system will do weird things. I had a similar experience and finally the faucet started sputtering and then full water flow... still can't figure it out.
Mar 07, 2010 | Delta 3555RB-216RB Victorian Double-Handle...
Machine fills too slowly and continues to fill in whole cycle
Remove the water filler hoses at the machine and test the flow of each one. If very slow, check the inlet screens on the faucet ends for plugging and make sure the faucets furnish full flow. The hoses themselves can sometimes become restricting of flow--replace them if so. Next, check the inlet solenoids on the machine for proper flow and shutoff when the power to them is stopped. They may or may not be cleanable--replace them if they are trouble. Hope this helps!
Jan 10, 2010 | Admiral AW22 Top Load Washer
Our delta kitchen faucet with the sprayer and faucet all in one started losing pressure 48hours ago and it is down to a trickle now. We have taken it all apart and can't find a blockage. Any ideas?
Point your water line into a bucket and turn the water on at the wall. If you get a good flow, we'll go back to the faucet. No kinks in the supply lines, right? The reason I ask is this was reminiscent of a recent problem where my friend could get hot water to the faucet, and it would slowly go down to a trickle. The problem was that the supply hose had a bit of a kink in it, and got choked off when the line got hot.
OK, good flow into the bucket. Sometimes the supply lines can delaminate, and choke the water off as well. Since you have a sprayer faucet combo, make sure that the flex hose that dispenses the water, and has the weight on it to retract the nozzle back up doesn't have a kink either. Remove the spray nozzle, and try the faucet, holding onto the hose. It's possible that the spray selector could have a problem, so check the spray head and diffuser. With the water on, push the sprayer button, and see if the problem might be there. Remove the aerator on the end of the sprayer, and check the screens for pluggage. My guess is that the issue is in the spray head.
Best regards, --W/D--
Aug 12, 2009 | Delta Plumbing
No hot water flow from faucet/shower
change the cartridge it is bad or defective.
Jul 20, 2009 | Delta & Single Handle Shower Faucet
Low flow hot water in Delta Shower
If your water heater is old or has been recently replaced, it will slough off debris that will get caught in the hot water supply side of the faucet. You have to disassimble the faucet and use a dental pic to remove the debris from it. This is a real common occurance. You can also try to flush out that side by removing the parts and then slowly turning on the water without the parts inside. Be careful not to flood your bathroom when you do this. But usually you have to dig it out. I have spent as high as 3 hours digging the liner from the dip tube of a water heater out of a faucet.
Apr 05, 2009 | Delta & Single Handle Shower Faucet
Plumbing Logo
55 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
