No signal on my bush 320GB satellite HD digital tv recorder
Can not get a signal when i pug my tv recorder in,, but no problems with my tv signal
I have a signal while watching TV
But when i try to record it states no signal
Posted on Mar 17, 2013
SOURCE: Connecting to a Satellite reciver
I solved the problem with my DVD recorder. I attached a cable from the loop out on the back of the FTA receiver to the RF in on the back of the recorder. All I was missing was the signal from the satellite. Everything is working fine now.
Thanks
JimCee
Posted on Mar 24, 2008
SOURCE: I have a hd set top box set up to my plasma tv. I
If you connect the main aerial into the digi box,then a fly lead out of the digi box into your dvd,then from the dvd take a fly lead into your tv,hope this helps
Posted on Aug 11, 2009
SOURCE: Hi, I have the dvr3006 dvd recorder, my tv is a
The dvd possibly only has an analog tuner so you would not be able to get a digi signal
Posted on Sep 24, 2009
  • 64 Answers
SOURCE: Can this vx530 DVD/VCR record digital signals from
No,you can not unless you use a separated converter box.There is no way to get the digital signal out of the tv to be recorded.
Posted on Feb 14, 2010
SOURCE: Recorder has stopped decoding SD digital TV but analogue TV is OK
Dry joint - faulty capacitor on the PC board of the decoder. Found by wiggling the components and resoldering
Posted on Apr 18, 2010
Tevion tdr930
The TDR930 does not have a digital tuner. It handles the PAL and NTSC video signals. You need to connect it to a set top box and then record on the Line In (composite video) input. The set top box could be a cable, satellite or digital-to-analog OTA converter. Since the DVD recorder can't record HD signal, the regular SD output converter box connected to an antenna will be good.
I wish that I had better news for you.
Jan 04, 2014 | Televison & Video
How can I change the resolution to 720px and above on this television????
What is your signal source and cable type? If your signal is being transmitted by a composite video cable, you need to upgrade the cable to component video or HDMI. (The cable you use depends on the device providing the signal.)
Next you need to set the set top box to an HD signal, if it has that feature. The steps will vary depending on the source. Please add a comment with the source for specific steps. (If you have cable, internet TV or satellite TV, you may need to contact your provider to enable HD programming. Many services charge an extra fee for HD content.)
I hope this helps.
(The source really does matter. My DVD recorder only records SD content. Even though I have the TV set connected to the unit with a component video cable, I don't get HD signal from those recordings or from the Digital-to-Analog OTA converter box that feeds the recorder.)
May 20, 2013 | Dynex DX-L42-10A 42 in. LCD TV
Will my westinghouse tv work in the uk in conjuction with a bush hd freesat box?
Both the tv and the Bush HD freesat box was bought in the Euoupean union?Wright?Yes,it will work together with no problems,both the tv and Bush HD freesat box both are recieving the same tv incomming broadcasting signal in PAL signal frequencies will be compatible.
Oct 27, 2011 | Westinghouse TX-47F430S 47 in. LCD TV
Can I use a HD receiver as input for the Toshiba XS35? Will it record HD signals? Will it record anything if the receiver is HD? I want upgrade my exisitng Bell Canada TV receiver box to HD - can I...
Yes you can record any TV show HD or SD, however it depends on what connections you use and what the recorder does with the input signals. You can record HD shows but not in HD resolution if you connect using composite video (yellow RCA cable) you just get a down-converted resolution, probably 480. You must use a HDMI or a component video connection for HD BUT if the recorder cannot record HD video, it should just record it in SD resolution but it should record the input signal. DVD is not HD, you would have to go to Blu-ray for HD and there are not many Blu-ray recorders around. The hard drive has the potential to record in HD but the recorder would have to process HD signals and you would have to connect with HDMI or component video. I would say your Toshiba will record an HD show but in SD resolution. I don't think the recorder has an HDMI input or a component video input. Just composite and S-video inputs. To actually record in HD you should look at another recorder.
Mar 19, 2011 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
My VIP722 DVr keeps showing that I have a complete loss of signal. This goes for awhile and can receive no HD channels. By going to DVR I can then go to guide and get SD channels only. But then after...
Hello this is Nick Franta with DISH Network.
What error message are you receiving on your screen? There should be a 3 digit number in the top right of the message. Has there been any bad weather in the area which may have affected the signal?
If you haven't been advised to already, I would suggest doing a hard reset of the receiver by unplugging it from the outlet for 10 seconds. When you plug it back in the receiver will reboot itself for you. If you are still getting errors hit the menu button then 6-system setup, 1-installation, 1-point dish, and then hit check switch and then test. All your satellites should show green. If not we would need to send a tech out to address the issue.
Hope this helps!
Jan 12, 2011 | DISH Network 311 DTV Receiver
Feb 07, 2010 | Panasonic Televison & Video
Recording problem between dvd vcr recorder combi and hd lcd tv
Aparently its the wire!!! as your sawpping the scart so yeah change the wire and you be a happy person!
Jun 17, 2009 | Grundig GU19WDT 19 in. LCD TV
Hooking up DVC/VCR to HD cable box/TV
Hi Seve.
Not sure what is meant by 'HD cable box'.
If you mean a DSD (Digital Satellite Decoder), then the built-in firmware prevents recording (of composite video signal).
In our country the SP requires that you buy a dedicated 'Explora' decoder which allows recording.
HD cable technology may have introduced similar anti-piracy measures.
{reminder to me: Google "HD cable TV" :)
Oct 06, 2017 | Televison & Video
Reciever Not Recording
Turn off the receiver, unplug the receiver, wait 30 seconds, plug it back in, and go through the setup again. This hard restart clears the memory and restarts the DVR software(clears any software glitches) This should fix this problem assuming that your satellite signal is good. Check that during the resetup. Most transponders will show between 70 to 100 signal strength. (Minimum is 70 for error free reception) Several transponders will show 0 as they are dead on the satellite, and not a receiver problem) If your satellite signal is in the 70's or less, you either live in Maine or you may need to realign the dish or something is blocking the signal like a tree or bush growing that is partially blocking the signal causing the signal to drop out(partial recordings)
Mar 04, 2007 | Directv HR10-250 DTV Receiver
Televison & Video Logo
150 people viewed this question
Top Televison & Video Experts
Electro Med Services...
