Question about Carrier Heating & Cooling
50TC-D28A1A6A0A0A0 ROOF TOP UNIT - Carrier Heating & Cooling
2 Suggested Answers
SOURCE: seal for roof top ac unit
I just spoke with the mechanic at my RV dealership and he said the sticky side goes on the a/c unit. You only have to turn it on it's side to do this. Just wait 1 hour after re-installing the unit on your RV before turning it on.
Posted on Jul 24, 2009
AAON unit on roof is vibrating causing a continuous humming sound over top floor units
condenser fan motor may be out of balance, go look to see if the unit is shaking.
could also be overcharged with refrigerant
make sure the unit is level on the roof
Apr 08, 2011 | Heating & Cooling
When set at coojest setting, water begins to pool on roof of my motor home
It is normal for water to come out of your unit. On some units there is a drain line if you take the top off of the unit you will see the line hooked to the condenser side (cold) of the unit. But most units just let water run out on the roof and run off. Your unit may have settled or if you have applied a sealant on your roof you may have changed the flow of the discharged water. The water is moisture that condenses from the air inside your rv. This should not cause you any problems unless you have a leak in your roof.
Aug 08, 2010 | Dometic Rooftop RV Air Conditioner
Was given a roof top ac for a popup camper need help
Make and model of unit should be on base of roof assy, please reply with that so we can be sure we have right wiring info for you. Although they are pretty common, let's be sure.
Jul 30, 2010 | Dometic Rooftop RV Air Conditioner
Can the outside unit in a split system be located higher than the
The outside unit is on the roof. If possible,get a ladder and get on top and you should see unit. To clean unit,remove screws on the sides, remove top cover.If coils are dirty, spray with a garden hose to clean.
Feb 23, 2010 | Dometic Rooftop RV Air Conditioner
How difficult / expensive is it to install a heat strip in a Dometic roof top AC? The unit I have has a mark on the knob for heat, but I suspect it was never installed.
Fairly easy. The only thing that you must figure out is how many amps the heat strips will draw. Make sure the fuses and the breaker switch can handle them. And be aware your electric bills will shoot up.
Oct 20, 2009 | Dometic Rooftop RV Air Conditioner
Roof Top air conditioner makes too much noise
Hello; Those roof tops can be noisy. Are you able to determine what is causing it? The fan? The A/C pump? Over tume, the vibration isolators that are rubber cushions the pump is mounted on, get weathered and hard and they no longer absorb the vibrations of the running pump. Those are easily chked and changed. The next point of excessive noise is the unit as a whole is tranmitting the combination of all the vibrating parts including its own housing. Here too we have a remedy. The roof unit has a seal between it and the camper roof around the hole it is fitted in. The seal is foam rubber and reasonably thick enougth to serve a purpose more than to seal out water and air. After and over time this seal ends up crushed from the weight of the a/c unit. Then the A/c unit comes in contact and is actually resting on yhe roof with what is now a very flat hard gaske. The roof unit is now vibrating the roof. This is as destructive as it is annoying. Ok? Now let's get rid of 80-90% of the noise. Check and replace compressor vibration isolator mounts. There are 4 bolts holding down the A/C unit. Sccess them from the inside by removing the ceiling trim and cover.There should be one on each corner. Bolts removed, one person push up on the unit and another on top lifting the unit. There are wires going to the unit and those may need to be disconnected. Clean the roof and the a/c where yhe seal goes.You can get a new seal from camping world or rv supply. Have your measurements, Unit make and model when you go.Assembly is just backtracking. On assembly, thinhs to pay attention to are:
Put the new seal on the A/C unit, not on the roof. It takes two people to ligft and set the unit back into the hole and center it in the hole. Don't slide it on the seal. lift it if it hs to be moved or the seal may roll over..
The wiring disconnected earlier must be dealt with and put in place for reconnecting.
Now start the bolts that hold the unit down.
Make sure-- Unit is centered
Wires can be reconnected
The four hold down bolts have their washers.
Someone go topside and verify the seal is properly in place. Measureing the for corners fo even height is one way to ck and looking under the unit is another. Now tighten the four bolts evenly. corner to cross corner. measuring again will help confirn its pulled down evenly. Pull it down no more than 1/4 to 5/16 of the seal thickness. Wire it up and put the trim and plastics back on and light it off. (run it and ck for noise and vibration. NOTE!!! The A/C unit cannot touch any solid part of the roof. Reason it was centered. Always ck the unit before each trip as you would any other psrts on the exterior of the camper. Good Luck Angie.
Sep 15, 2009 | Dometic Rooftop RV Air Conditioner
Coleman 1300, condensation buildup inside unit, ceiling wet
Check for plugged drains under cover on roof, sticking out at base of unit usually. It should be running off roof.
Aug 04, 2009 | Heating & Cooling
My roof top RV air conditioner is dripping water inside my RV
Check run-of on roof & see if it's been reduced lately, it may just be a plugged drain at base of unit on roof.
Jul 29, 2009 | Dometic Rooftop RV Air Conditioner
Seal for roof top ac unit
Apr 17, 2008 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
37 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
