Question about Conair Health & Beauty
My conair mt3 fell apart
I need to know how to reinstall the blades
SOURCE: fell apart..help please!!!
The larger white pieice that has holes in it should be connected between both the spring and the smaller razor, The bottom of the larger white peice has to be able to fit in the peice of medal that moves in a circular motion inside the top part.
First, Try to make the hooks of the spring go in pretty securly inside the small holes. The flat side of the white peice has to be connected to the flat side of the smaller razor. They should kinda snap together on the top hole. I had to gently place the parts together and push the larger white peice in the medal by placeing the larger razor peice right on top and pressing down really hard. You might hear some snapping but the peices should all connect together and the large medal peice should connect to the black groves and press hard. Hold in place while putting the screws back in.
Posted on Jul 09, 2008
triloberto
SOURCE: Conair GMT200 Assembly
Hey dude i had the same problem n_n. Attach the screws in place and try to screw one by one gently. Soon this pressure will keep the spring tighten (instead your finger's pressure) then it will be easier to reassemble the component. I know you'll fix it n_n.
Posted on Jun 07, 2009
SOURCE: HOW TO CHANGE BLADES ON CONAIR HCT 426 HAIR TRIMMER
digram on how to replace my blade in my hair trimmer conair hc3180v
Posted on Jul 27, 2009
  • 32 Answers
SOURCE: My conair HC318D came apart near the blades. How
it is designed to come apart for replacement. Look at page 3 of manual for instructions.
http://www.conaircanada.ca/en/pdf/ibs/en_HC318DWXCSC.pdf
Posted on Feb 04, 2010
SOURCE: I can't find the manual
their is 2 long wires with a l shaped hook on the the smalles blade that goes on the bottom the points of those wires go in the holes in the bottom of it which is a white thing with 2 groves in it make sure the blade is facing away from where the screws go the take the plastic pad and put it in the 2 holes of the top blad the set it on their facing the same direction the push down till its flush the put the 2 screws back in
Posted on Feb 28, 2011
Can the mirror be replaced on an a BE103 ?
My mirror is not like the picture shown. I have a True Reflections mirror by Conair with two sides and changes shades for what kind of light I want, I just wanted to know what are the two whit things that fell out of the mirror when I took it apart to change the bulb? There are two squares that appear to be batteries of some kind and the two things that fell out were near them. but I have no idea where they were.exactly or it they are necessary. Can anybody help me figure that out? Thanks! J. Burke
Sep 12, 2013 | Conair Chrome Double Sided Lighted Makeup...
The top fell off
you can download the manual at this website and see if you can find an answer to your problem
http://www.conair.com/cnt_ib.php?action=filter&type=category
Feb 13, 2013 | Conair Cpc225 Chrome Clipper Kit 21pc...
I can't find the manual of my Conair GMT 170X. I took the blades apart to clean and lube and now I don't know how to put the spring assembly back together with the blade. Please help
Dec 17, 2010 | Conair GMT 170 CS Beard Trimmer
Plug in charger fell apart - need to replace
Hello. Go directly to the manufacturer. Here is the phone information
Mar 28, 2010 | Conair GMT200TD
May 20, 2009 | Conair GMT200TD
Feb 01, 2009 | Conair HCT-426 Hair Trimmer
Cleaning Conair Simple Cut haircutter
Go to a Sally Beauty supply and purchase a can of the blade wash. It is relativly inexpensive. You dip your blades into ths special wash and it cleans the blades and keep them sharp and is safe. DO NOT take the heads apart, Let the pros do that but blade cleaner you immerse them in and trust me it is what we pros use.
Jan 20, 2009 | Conair HC91CS 10 Pc. Haircut Kit Hair...
Fell apart..help please!!!
Jun 21, 2008 | Conair GMT182CS
Conair hc318d reassembly
i have hc318d clipper it been use two time and havent use it in a year so was going to use it last nite and the small blade fell out. i try to put it back in and it want hold keep falling out
Dec 17, 2007 | Conair HC100RCS Hair Trimmer
Health & Beauty Logo
57 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
