Question about Dryers
Wexford platinum series fan slow work
MODEL# CT-370RTF RUN SLOW
Paeroa
  • 457 Answers
SOURCE: SLOW--SLOW--SLOW
Its slow beccause it sounds like it needs cleaning out lot of things might be slowing it up like Viruses sounds like heaps in there. Go here and download the Trial its Tuneup Utilities 2007 http://www.tune-up.com/ you have a thirty day trial but it will let you clean your machine out do everything scan and all in the end you could be the winner you see.
Posted on Sep 10, 2007
SOURCE: Kenmore 90 Series Washer has slow spin cycle
Washing machine won't spin, seems locked up, when i turn the spin cycle on you can hear the machine trying to spin but it won't budge....... any suggestions???
Posted on Dec 28, 2007
shastalaker7
  • 1515 Answers
SOURCE: voltage to evap fan 94v not working runs slow @ 120v
Hi, I deal with evaporator motors on a day to day basis.If the motor is running but not up to full speed, the inner windings of the motor are going out. If the motor runs as you say, is it getting only 94 volts to it? If this is the case, check the incoming voltage to the unit itself. Check to see on the schematics what is between the motor where you may be loosing your voltage. Defrost thermostat, or timer. Check power to the timer first and get back to me. The defrost thermostat supplies power to the fan when the evaporator temperature gets cold enough and the contacts will close and send power to one side of the motor. If it is going bad, it will cause you to loose part or all of the voltage. If you have a meter, check this. It is round and sealed with 2 terminals on it. If it is cold enough, you can check the leads to ground and see if you are getting less then 120 volts coming out the motor side. If so, replace the thermostat. Please keep me posted.
Sincerely,
Shastalaker7
PS Be safe around electricity. Also, this defrost stat snaps around a evap. line.
Posted on Dec 28, 2009
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Washer 80 Series Agitates slow
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
  • 248 Answers
SOURCE: need manual for elite platinum slow cooker model
kitchen.manualsonline.com
Posted on Oct 09, 2010
I have a Wexford Premium Tower fan model CT-181 THTF. I need a working remote and an owners operators manual. It seems to be working great/
Does this look like your Remote??
eBay: 323110383235
It ain't cheap at $40 USED and this is from a "Thrift Store"... ya sure.
"Wexford 44" VFD LCD TOWER Fan Remote Control MODEL CT-408RTFV1"
A
Apr 04, 2018 | Televison & Video
Spontaneously stops working and then comes on after 5 minutes. Why?
Sounds like the magnetron is overheating. There is an automatically-resetable thermal circuit breaker attached to the magnetron. Most likely your problem is caused by either a cooling fan that is not running, or is running too slow (caused by gummed-up bearings). In some over-the-range (OTR) microwave ovens, the exhaust fan is run at a slow speed to cool the magnetron, and if it's bearings get gummed up, it won't run on the slow speed. But if it's a new OTR microwave, then the exhaust fan may be pointing the wrong way. (It is rotatable, depending on the installation). For example, if it is pointing up, but you don't have an exhaust vent over the microwave, then the air has nowhere to go, and the magnetron will overheat.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Oct 16, 2014 | Microwave Ovens
Lost manual of Platinum Slow Cooker 4.5 l Digital KD0591 (SR7117075)
Here is the list of manuals on the manufacturers website. Hopefully there is one that is like, or similar to your model.
4 7 Quart Slow Cookers Instruction Manuals at Crock Pot com
Aug 06, 2013 | Rival SCVC600-SS 6-Quart Slow Cooker
Why are the fans not coming on in my 1999 deville
99 Deville - have you checked the large fan fuse(s) under and behind the main fuse/relay box ?? (I think this holds for 99 - 2000+ moved the maxi-fuses to the underhood box on the passenger side.)
Also, are your relays on a mount down near the fans ? Some have had trouble with the wiring/sockets there. 2000 or later moved the relays up to the fuse box itself. There are 3 - Fan 1, Fan 2, and a series/parallel (S/P) relay for slow and fast speeds.
Fans run in SLOW at 224 degrees F, FAST at 236 degrees F if there is no air conditioning or DEFROST function set. In the city or heavy traffic the gauge will go to the first tick mark past 12:00 and the fans come on. As the coolant lowers to 213 degrees F the fans turn off and the cycle repeats.
IF you set an air conditioning function, then fans run in SLOW all the time.
If your fans will not run under any conditions, check the large fuses in the underhood fuse/relay box, as well as the small fuses for the fan relays - there are 3 relays: Fan 1, Fan 2, and S/P (series/parallel): the fans are relay set to series operation (voltage drop) for Slow speed, parallel operation (full voltage) for Fast.
Mar 24, 2012 | 1999 Cadillac DeVille
Looking for a manual for 3.5qt. platinum classic model #pchc-35s
Try Googling (platinum)(pchc-35s)(manual) without parens.
Jan 05, 2012 | Crock Pots & Slow Cookers
I have a Toshiba laptop with a Windows 7 operating system, a few years old. It recently started randomly shutting down - after 10 minutes or so of use, it would just go dead. It's also extremely slow,...
Hi.
the first thing i would check is to make sure there is no dirt or dust stopping the fan from running because if the fan is not running it will heat up and shut down or if the fan is running slow it will shut down.
and for running slow i would do a good clean up get rid off stuff thats not needed anymore.like music,pictures,the more your harddrive has on it the longer it will take to load and run.
Oct 21, 2017 | Toshiba Satellite L455-S5975 Series Laptop...
Processor fan slow
There is usually something in the BIOS settings that control the speed of the fan at certain temperatures. check those. Set it on auto if you can
Jun 05, 2008 | Intel Motherboard
Dryers Logo
89 people viewed this question
Top Dryers Experts
