Question about Procom ML300HGA Heater
Replacement knob part #MB16002 for Pro-Com heater model #MN300HGA
I have a Pro-Com heater model #MN300HGA and need a replacement knob part #MB16002. Where can I find one? btw, the knob has a serious design flaw in that there is a flat metal piece that fits into a slot on the base of the knob that allows you to light and adjust the temperature when the knob is depressed. It is made so that it both comes out of the slot and bends too easily so the knob doesn't work properly and therefore makes the heater unusable. I really just need the little metal piece that fits in the slot and not the entire knob but that doesn't seem to be a separate part. Any suggestions/help/ways to fix or order would be much appreciated.
justaplumber
  • 98 Answers
SOURCE: need to find replacement knobs for gas control
Need to know model and make
Posted on Dec 23, 2007
SOURCE: ProCom blueflame heater pilot light difficult to light
Holding the button down enables gas to go to the pilot. When it lights you will see the flame touching two rod like devices. The small one is the igniter. The second one is a thermocouple. A thermocouple is a bimetalic device (2 disimilar metals) that when heated produce a small curren, this current in turns keeps the valve open for the gas to flow when you let go of the button. This is a safety feature. If the flame goes out on the pilot the thermocouiple cools and closed the valve shutting off the gas so you don't go boom! It sounds like the thermocouiple is bad or missaligned. If it is missaligned it will take longer to get hot enough to hold the valve open. Another thought would be the flame is not shooting out far enough (not enough gas pressure, clogged oriface on pilot(previous writer, leak but you get the idea. In my manual it had a picture of how the flame should look hitting the thermocouple. Good luck. My problem is I assumed that the regulator on my construction heater was the correct size. Maybe not. I have not had any luck getting the pilot to light at all. I hope I have not damaged the internal regulator.
Posted on Jan 17, 2009
  • 188 Answers
SOURCE: Control knob
You should be able to get a new knob from Master Parts. You can contact them online at www.masterparts.net or by calling 800-446-1446.
Posted on Jul 08, 2009
  • 2557 Answers
SOURCE: Nothern Hyd sold me a Natural Gass only Pro Com
nothern hyd should suppy this part they should also tell you as this is there mistake
Posted on Mar 09, 2010
  • 23 Answers
SOURCE: I just installed a brand
Is the pilot light a nice blue colour, is it noisey only at start up. Could be air mixture on pilot and pressures not set correctly
Posted on Dec 15, 2010
What is the part number for the control knob for the Bernzomatic Patio Heater model # PH3250N?
Bernzomatic does not provide nor sell replacement parts for their products - they consider them disposable.
If the plastic knob is the only piece you need, Amazon sells a few replacement knobs for patio heaters. I searched Amazon with the terms:
replacement knob patio heater
Nov 01, 2017 | Pool & Spa
Need the switch for a maxiheat oh 107c
I replaced "Off - Low - Med - High" knob on Maxi Heat oil filled heater Model OH-107c with a Camco 00913 Knob (Purchased at Amazon.com for $7.03 including shipping - http://www.amazon.com/gp/product/B000KKOE4I/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1) - Blue insert fits snug - Had to remove 3 small tabs on cover that are related to 'stops' for original knob. Five minute repair and heater works again. (Side Note: I called manufacturer and they told me the heater had been discontinued for 9 years so they had no parts).
Apr 29, 2012 | Heating & Cooling
Where can I find a replacement base board thermostat knob ? The knob is beige. SEKNOBI KIN SE- Knob-I IV Knob F / S22. Regulates a base board heater.
Dayton Heaters are a product of Grianger Industrial Supply. The have locations all across the US & Mexico or you can find them online http://www.grainger.com/Grainger/wwg/start.shtml
Hope this helps you find the replacement knob.
Apr 12, 2011 | Dayton Electric Heater
Need a control knob for : dyna-glo pro propane heater. model # rmc-tt 30dgp-01, # rmc-tt30dg, #rmc-tt30gd. serial: # 09 005720
Contact GHP Group Inc, (877) 447-4768 to order a replacement regulator - MAKE SURE YOU HAVE THE PROPER HEATER MODEL NUMBER. Replacement Part Number: S2TT0001B for the RMC-TT30DGP.
Replacement cost including shipping is a couple bits over $21.
When talking to the technician on the phone, he cautioned me against rapidly opening the tank valve, which hammers the regulator (the replacement one is more robust than the original), kinda' like how water-hammer can cause damage to water pipes and/or water appliances. Open the tank valve gently, don't just whip it open (like I used to), your regulator will last a lot longer that way.
Because of the press-fit and pins used in the regulator construction & assembly, self-repair is not possible or recommended since the regulator may not seal correctly afterwards.
Dec 17, 2010 | Garden
I have a lasko model 5362. the lower control knob is cracked. i need a replacement. please advise.
That model is under recall. DISCONTINUE USE
Also models 5132, 5345, 5364, 5420, 5532, 5534, 5566. For recall information see:
http://www.laskoproducts.com/recall/recall_heater07.html
or call Lasko Products toll free any time at 1-800-984-3311 to receive a free replacement heater.
Dec 03, 2010 | Lasko Heating & Cooling
Replacement knobs??
contact grainger.com. they can get any Dayton part.
Feb 24, 2010 | Dayton Electric Heater
Missing control knob help....
Here is the customer service website to contact them about ordering another knob for your unit.
http://www.fahrenheatpro.com/products/FN_AboutUs.htm
Jan 02, 2009 | Fahrenheat Electric Convector Baseboard...
Time control knob for bravetti platinum pro convection oven
Thanks for allowing me to help you. The replacement knob is available from the following link:
www.euro-pro.com/europro/productdetail.aspx?pid=1D76CC6A-4A86-4D6B-8120-7DB204F16DF4(Euro-Pro+Base+Catalog)
You can also get a user's manual if you need one.
If you found my assistance valuable, please give me an appropriate rating. Thanks for using FixYa!
Oct 19, 2008 | Euro-Pro EP278 Bravetti Platinum 1500...
The knob on the bottom dial of the toaster oven has cracked and fallen off. Can i get a replacement knob so that I cAn turn the toaster oven on
To get new knob for my Euro-Pro K4245 I went to www.euro-pro.com and put model number in for parts search and they have knob for $1. It appears all three knobs are the same.
Apr 16, 2008 | Euro-Pro K4245 Toaster Oven with...
Procom ML300HGA Heater Logo
257 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
john h
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
