Question about Video Game Consoles & Games
My sanyo ce32ld33b wont show my ps3 on hdmi but my sky is fine, any solutions?
4 Suggested Answers
  • 118 Answers
SOURCE: my ps3 wont show on my tv anymore. what do i do?
not to worry it is very simple
1. if u are using hdmi port and it is connected to hdmi in your tv
setting might have been changed
1. take out ur nomal av output wire which is given by sony , plug it on to a normal tv (rgb) now u can see the display (if not try mannual swithch off the ps3 and on for 3 to 4 times) u will get the display
2. now go to settings (video settings) there is a option called video output u can change it to AUTOMATIC
3.NOW COME OUT of it and switch off
4. now pug into ur hdmi port it will work
Posted on Mar 16, 2010
  • 1139 Answers
SOURCE: my ps3 work fined at first with the three prongs
You need to reset the resolution, try these steps :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Posted on Aug 23, 2010
  • 839 Answers
SOURCE: my ps3 has its hdmi cord hooked in but it wont
You can fix this problem easily... Without having much technical knowledge...... you can do this easily with the help of repair guide....
Click here to download repair guide
Posted on Jan 03, 2011
I have a goodmans TV is having issues, sky box works fine through the hdmi but, ps3 no display or sound through the same port, my ps4 gets pic but no sound, both consoles have been tested on other tvs
1.Put your PS3 on standby.
2. Unplug the power lead.
3. Connect HDMI cable to HDMI out on PS3 and HDMI in on TV
4. Connect PS3 so that the red standby light is showing
5. Hold down the On/Off button until you hear a second beep. The PS3 will try and detect the display output settings on your monitor.
Dec 02, 2015 | PS4 Video Game Consoles & Games
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
My ps3 work fined at first with the three prongs cable then i used the HDMI and it work fine but when i go to a different tv and use the three prong it wont show nothing, it only works if i uses the HDMI...
Aug 23, 2010 | Sony Playstation 3 (PS3) Console
Unable to use PS3 on HD channel
1. Connect PS3 to your TV
2. Select the Correct HDMI input on your TV
3. Press and hold the [power] button on the PS3
4. perform setup.
These are the steps to setup the video output for the PS3, It is possible that it is set to a resolution that your TV does not support.
If this doesn't work, you may want to contact Sanyo to ask if they have some protection circuit for the HDMI input. Some manufactures TV's will deactivate(turn OFF) the HDMI input under certain conditions. Unplugging the TV or some other procedure usually turns it back ON.
Apr 29, 2009 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
42" Sanyo HDTV with 3 HDMI Inputs
Everybody is having problems with sony products and HDMI cables. It's on a lot of forums. So, your not alone.
Most of the solutions are:
1. Unplug your TV for 30 mins.
2. Plug TV back in and put it on HDMI for PS3.
3. Hold down the power button for 10secs on the PS3
That should solve the problem.
Feb 17, 2009 | Sanyo DP42746 42 in. Plasma Television
JVC LT-32DS75SJ issue with HDMI
Try this
1. Turn ON TV
2. Connect PS3 to TV HDMI input
3. select TV HDMI input for PS3
4. turn OFF PS3 if it is ON
5. Press and hold the [I/O]Power button until the PS3 until you get the "HDMI Detected" message.
Also, this TV has a circuit that deactivates the HDMI if the rear cover is removed. It is possible the HDMI may have been turned OFF. This is reset in the service menu of the TV.
Dec 17, 2008 | JVC LT-32X575 32 in. HD-Ready LCD...
I have just bought a Sony DAV-dz260 home theatre system. I connected it viz HDMI to my 1080p tv and it works fine. I also have a Sony PS3 connected via HDMI to my TV and this works fine too. I have...
i have the same dav dz260 and all my stuff works on mine. this is how i set it up i have conected y dz to the tv via scart and my sky and ps3 via hdmi cable. to get sound from sky and ps3 i conected a optical cable from the dz260 to the tv and when i want sound for sky or ps3 all i did was change the function on the dz260 to tv and the tv setting to the hdmi im using and hey presto sound hope it helps
Nov 11, 2008 | Televison & Video
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Televison & Video
Yamaha DSPAX761 no s-video to HDMI
S-Video and Composite are analogue and HDMI is digital. Your receiver dose not have the capability to convert from analogue to digital and hence you are not not getting any video.
Feb 28, 2008 | Televison & Video
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Video Game Consoles & Games Logo
24 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
