Clarisonic plus wouldn't charge
Even charge long time,green light stayed blinking,the unit don't work.
3 Suggested Answers
  • 6 Answers
SOURCE: first time charging up of archos 5,it has now been
@wilkerwkocer
On an Archos, battery is fully charge when the CHG LED light is flashing, while that light is ON all the time, the unit is still charging.
Now, in order to charge your Archos you must leave it on Suspended mode, by holding the Power button for about 4-5 seconds until it says "Suspending", DO NOT leave it on completely "Shutdown" mode, or your battery will never charge, and you are also risking the life of your battery by doing so.
So in other words:
1) On a PC via USB it should take around 8 hours to charge, while connected to an Archos mini dock, battery dock, or DVR Station, it should take around 3 hours to fully charge.
2) Leave your unit completely "Shutdown" (hold the Power button and wait 10 secs. or so until it says "Shutting down" and let it go off.
3) Connect it to your power source, either USB on computer, or external charging device as mentioned above, it will come back on, the two LED lights CHG and Power will come on, leave it like that, and after a few minutes the unit will go into Standby/Suspended mode by itself, and there is when you are charging your battery the right way.
3) Wait 8 hours if connected to your PC, or 3 hours if connected to an external power supply (as described above). If still after being in suspended mode (not completely off) your CHG light isn't blinking after the 8 hours on PC, 3 hours on external power supply, then suspect your battery is defective.
In that case, if the unit is still under warranty contact Archos, if it is out of warranty. If it isn't under warranty, you can buy a replacement battery on eBay and either replace it yourself, or find someone with the technical skill to do it for you.
I hope this helped you.
Posted on Mar 13, 2010
  • 10 Answers
SOURCE: My boyfriend and I purchased
ludovica_bar,
Thanks for contacting us and letting us know about this problem! I will happy to assist you in the problem you have with your SwiMp3 over at our support site and if you fill out a ticket I can further process your information. Please visit finisinc.com/support and Ill be happy to assist you. Thanks!
Posted on Sep 12, 2011
My clarisonic mia fell and does noit work anymore
hi there, this happened to mine too. have you fixed yours yet? i have no idea what to do. pls help :(
May 13, 2012 | Clarisonic Mia Sonic Skin Care System
Bought a Nikon Coolpix S3000 (orange) for my daughter after Christmas. It just stopped working one day; wouldn't charge, no lights or come on. The battery it came with is a Nikon lithium ION Battery...
Read page 16 of the manual. Do not use any other charger with this camera. Are you sure you have the battery inserted correctly? When trying to charge, does the green light blink? If so, when it stops blinking and turns off, the battery should be fully charged. Do not attempt to turn the camera on while the charger is trying to charge the battery.
Aug 17, 2011 | Nikon Coolpix S3000 Digital Camera
I've got a Bosch ps30 drill that uses bat411
Directions say green light indicates that the battery is fast charging only,it does not indicate at exact point of full charge. I let my batteries charge for 12 hours for the first time charging,found out myself the same way. Try that and you will notice the difference.
Jul 15, 2011 | Bosch PS30-2A 12-Volt Max 3/8-Inch Drill...
My hp elite won't turn on. it was running fine, and I left home for an hour, came back and it was off and wouldn't start. it's only 3 years old. The little green light on the back stays lit for...
The green power light will stay on after it is unplugged, as there is still residual power in the unit. The symptoms you describe point to blown main capacitors in the PSU, the only way to check is by fitting a new PSU (recommend one of 700 watts minimum). Not very expensive and as long as you are careful, easy to fit
Jul 02, 2011 | Computers & Internet
I just bought the bluetooth twin pack headsets and I can not get them to charge. I have tried the usb via computer and also plugging in to the wall through usb capable plug in. They will work and pair if...
It sounds like a defective unit, although I am not familiar with that model... If both charging methods don't work, I would recommend a manufacturer replacement.
Jun 29, 2011 | Cellular Innovations HFBLU1K Bluetooth...
Battery not charging. Orange and Green light on charger. 18V Plus one system
The air holes on the bottom of the batteries are there for the battery to vent. Downside is, these vents can also allow moisture to get in and prevent contacts from letting the battery charge and causing the "defective" display on the charger.
I work on pool and spa equipment and I had dropped my batteries in a small puddle of water where I was working, both went dead immediately and both showed "defective" on the charger even after drying them out for a few days.
Tried using a can of air and gave each of the vent holes several shots... The batteries charged and are now working perfectly.
I'm sure even overnight condensation could be the culprit for a charger to display "Defective"
Jun 24, 2011 | Ryobi Multi-Volt Battery Charger
When plugged in the hose light blinks
My spotbot lights would blink and it, for a time, only worked on deep clean even after unplugging and plugging back in. Finally it wouldn't work at all, only the hose light would blink. I unplugged the hose and plugged it back in and the machine started working as it should.
Apr 10, 2011 | Bissell SpotBot Robotic Wet/Dry Vacuum
I lost my manual to my duracell instant jumpstart . Just wanna know to properly recharge my unit.
I'm having the same problem where it won't take a charged. If you left it with a dead battery for say 6 months, it probably ruined the battery. You should have a charger for house current and car voltage charger. I guess your dead in the battery like me. I'm taking it to Battery Plus to check it out. It only had a 1 year limited warranty. Good Luck.
Oct 30, 2010 | Duracell ® Instant Jumpstart System
113 people viewed this question
 Grubhead
Grubhead
