Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Hi, I have a new Lenovo Y530-4051 Laptop. The problem is that Bluetooth is not working. It does not even show up in the device manager. I have ran the DPInst in the BRCM Folder but nothing happens. Even when I press FN-F5 the only thing that shows up is Wireless card. My Wirelss network is functioning just fine. Can you assist please
  • i_masoud Jan 12, 2009
    Thanks for the feed back however the specifications metioned in the link do not match the actual specifications of my laptop despite the fact that I have double checked the model number of the laptop. It is Y530-4051. the following items don't match. RAM memory, CPU and Hard drive.. I have purchased my laptop from the states at the end of Oct-2008 but now Im over seas otherwise I would have went back to the store I have purchased it from.
    One last thing to mention is that I have checked other sites in which people mentioned they had issues with the bluetooth on the same model but they have XP. then they were advised to run the driver in the bluetooth directory which has worked.
    Please advise if anyother options are available to resolve this issue.
    Many thanks in advance.
    BTW I looked at the box and it has this model number Y530-405143U
  • Lenovo Master
  • 787 Answers
Are you sure this model actually has bluetooth?
The manufacturers tend to sure the same case for similar models, for example Y530-4051 and Y530-4052 may be identical except that slightly different features.
I have a Acer that does NOT have bluetooth but there is a on/off switch for it on the case.
The Lenovo specifications for this model mention nothing about Bluetooth.
https://www.directlenovo.com/public/public/products/details/dsp_product_note.cfm?product=40512SU&ecim=N&config=N&os_depend_stat=%20&avail_status=%20&establish_cookie=true
If you need Bluetooth, consider something like this:
http://www.usbgear.com/USB-Bluetooth.html
It is a lot less expensive than finding, buying and then paying for a tech to open up the system and install the card - not to mention that anybody opening the case other than an authorized service center (can we say expensive) would void the warranty.
Posted on Jan 11, 2009
Hi i Have a Lenovo 3000 N200 769 laptop. I reinstalled Vista. I cannot acces the internet (ethernet and wireless wont work) I tried installing the drivers but it won't work I do not even see the...
Go into Device Manager and Disable/remove the ethernet. Then reboot and let it detect it as a new device then put the driver in for it. Then do the same for the wireless. It should have picked it up when you reinstalled Vista but sounds like something glitched. If you have something else to get online with you might want to go to Lenovo's site under Support and download the drivers you'll be needing and have them ready to install.
Jul 29, 2011 | Lenovo 3000 N200 Notebook
M using windows 7 ultimate..i cannot start my bluetooth on my laptop lenovo g550.....an error appears dat no bluetooth device detected
Welcome to Fixya
There are lenovo G550's that doesn't have bluetooth capability. Check your computer is you have bluetooth module installed. Go to control panel then Click system icon. Go to device manager and check under the list of devices if you have bluetooth installed.
Thank you for using Fixya!
Jun 08, 2011 | Lenovo G550-29583AU Notebook
My laptop is lenovo y 410. Ever since i installed windows 7 bluetooth in laptop is not workin. I installed a driver manually but still the problem persists. it is showing icon but there are no options...
Hi raj,
I see that you are having a Bluetooth issue finding he option sending and receiving Bluetooth transfer options.
On your system whichever windows you may have you can see Bluetooth,
  • Click on Start then click on All Programs, look for accessories
  • Click on accessories it should show you the Bluetooth icon under Accessories if you click on it it will give you the option to send and receive using Bluetooth.
I see that you installed the driver for your Bluetooth to see if it installed properly check device manager, you should see Bluetooth under Network Adapters, if it's not there then the installation was not successful or maybe it just did not install correctly, try reinstalling again.
  • You can also try download an application that can utilize your Bluetooth device for example Blue Soliel that is a good Bluetooth Application that I personally use, you may just need to purchase the program online to be able to use the full functionality of the application.
I hope that his will be helpful regarding your concern, have a nice day.
Feb 09, 2011 | Lenovo 3000 Y410 Laptop
Hi , I have lenovo y500 laptop it is not detecting the blue tooth device
make sure you have bluetooth device and plug in to your laptop
see the device manager and try to refresh to find new device if theres no new device maybe your bluetooth was damaged
try to replace it and start all over again
Jan 14, 2011 | Lenovo 3000 N500 Notebook
Inbuild bluetooth device not working even driver has installed IN3BTH46WW1
Hi
Have you checked that the switch is not push to the off position ( usualy on the front or side )
Also that it is not disabled in device manager
You could also try uninstalling it in device manager then restarting laptop and windows should either reinstall it correctly or give you an error warning telling you that it cannot start or install
If so try to update the driver normally if that dont work down load driver again
Nov 13, 2010 | Lenovo G550-29583AU Notebook
Bluetooth problem in lenovo 3000 G430 laptop
i am using lenovo 3000 g430, and i am fall in problem about bluetooth,
i am already install xp and vista, but when i install the bluetooth driver
one warning message show me "bluetooth device not detected"
my bluetooth device switch is on but indicator led light still off,
please help me , how can i use bluetooth in this laptop.
Dec 13, 2009 | Lenovo 3000 Y410 Notebook
A problem regarding bluetooth
You need to install the bluetooth software, if you have a disk, install from there. Otherwise look on the manufacturers website for the drivers and other software you may want. the bluetooth device itself is just the hardware, you need both the software and the hardware, good luck,
PS, also mention what operating system you have, because XP doesn't support it even though it will work on XP, that's a MSFT thing,they would rather say they don't support something than have it work properlly with their software
May 14, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Can't use bluetooth in lenovo g430 laptop
UNINSTALL ur bluetooth device through
"ON" ur bluetooth through the switch
Control Panel->System-->Hardware-->Device Manager-->Select ur Bluetooth device--> Right Click select uninstall...
Then download the latest driver from
Lenovo Y410
http://www-307.ibm.com/pc/support/site.wss/MIGR-68104.html
Mar 17, 2009 | Lenovo 3000 Y410 Notebook
Lenovo Y5230 Bluetooth
The easiest way for you to find the correct driver is to find the name of your Bluetooth device through your ystem information page. Click on start>programs>accessories>system tools>system info.
Then go to the original manufacturers website and download drivers. This will activate your Bluetooth.
Don't forget to rate this solution.
Jan 11, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Cant use bluetooth on my lenovo 3000 Y410 laptop....
go to the lenovo site and search the model of your lenovo and download the bluetooth driver.. your bluetooth driver might not installed on the laptop..
Sep 08, 2008 | Lenovo 3000 Y410 Notebook
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
94 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
