Question about Pioneer Vsx-1022-k 7.1-channel 3d-ready Network Home Theater Receiver
Pioneer vsx 1022-k shuts off when volume is turned aboved 50
5 Suggested Answers
Gurudristi
  • 98 Answers
SOURCE: Pioneer VSX-D209 receiver shuts off when too loud
Dear Tabasco,
Your receiver is basically going into protect mode.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem.
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck! Thanks for using FixYa!
Posted on Apr 21, 2009
  • 14 Answers
SOURCE: Pioneer VSX-01 TXH receiver turns off
Sounds like the speaker circuit is overloading or the receiver is overheating.
Check to make sure all speakers are in phase. Pos to Pos. Neg to Neg.
Make sure receiver has plenty of cooling room.
Hope this helps.
Posted on Apr 17, 2010
  • 88 Answers
SOURCE: my pioneer vsx-519V-k amp keeps turning off
check audio ic & component like resistors & capacitors. good luck!
Posted on Apr 26, 2010
  • 11 Answers
SOURCE: Receiver shuts down when setting volume above certain range.
What ohm speakers are you using? this receiver doesnt work very well with speakers that have an ohm rating below 6
Posted on May 17, 2010
Pioneer tablet TBT-7R1-K
I had the same problem. Instead of scrapping it, I bought an extension cord to use it around the apt. I keep it plugged in as I use the tablet, and it charged fully!!! I've run the battery power down, recharged it, and it holds. I found a way to charge it by buying a $1.69 extension cord. Now it's working normally.
Mar 18, 2014 | Pioneer VSX-1022-K 7.1-Channel 3D &...
Pioneer vsx 822 k shuts down when i turn up the volume
Could be caused by a bad speaker, try disconneting speakers and see if it still happens.
Jan 10, 2014 | Pioneer Vsx-822-k 5.1-channel 3d-ready...
Overload pioneer vsx 808 rds
if it's shutting down when you increase the volume, this usually indicates a bad speaker.
Jul 03, 2013 | Audio Players & Recorders
I have a Pioneer VSX-1022 Reciever - I get no sound when it is on the "TUNER"
These models have a problem where it is very easy for the tuner pcb to become disconnected from the main pcb. About the only way I've found to fix it, is to take the back panel completely off and reseat the board.
Apr 11, 2013 | Pioneer VSX-1022-K Network Ready Receiver
Shuts off and on the tv
its your wiring in your house. the initial draw is to much for your wires. pplug the tv into a totally different socket and see if it fixes it
Mar 13, 2013 | Pioneer VSX-1022-K Receiver
My pioneer vsx-519V-k amp keeps turning off when I, turn the volume above 50 db
Apr 26, 2010 | Pioneer VSX-518-K Receiver
disconnect all your speakers and if it still does it, yes, take it to service. if not, check all your speakers and wires. good luck
Feb 09, 2010 | Pioneer VSX-815-K Receiver
Dear Tabasco,
Apr 19, 2009 | Pioneer VSX-D209 Receiver
Pioneer Vsx-1022-k 7.1-channel 3d-ready Network Home Theater Receiver Logo
356 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
