Headset is not connected to Base
SOURCE: kx-tg1100
On your handset go to "SETTINGS HS" -> "REGISTRATION" -> "CANCEL BS"
This will discard the registration of the handset to any base.
Then go to "SETTINGS HS" -> "REGISTRATION" -> "REGISTER HS"and select the base you want (i.e. BASE 1, BASE 2, ..., BASE n).
After you finish all the above, hold down the "PAGE" button for about 5 secs.
You are now done!!!
Good luck
Simos
SOURCE: Hard reset of KX-TCD580 Base
Go to this link; http://panasonic.co.uk/customer-Support/download-centre.asp and input "KXTCD580" in the search box - after a few disclaimer screens you get to the manual for your phone. page 29 details reset for the handset Page 32 details base unit reset Page 48/49 details cancelling handsets to the base Hope this helps, please post again if you are still having problems with your phone :)
SOURCE: phone not connecting
I am having the same problem. Had it last year, too but bought new batteries for all the handsets and that fixed the problem. However, this year I can't find the batteries anywhere!
SOURCE: Phone says I am too far away from the base--panasonic kx-tg2356s
unplug the base unit and when you plug it
back in the handset should work
SOURCE: "no link to base" error message
Sounds like the antenna is not working, and signal is not getting to the cordless sets.
Try unplugging your base station (unplug everything; power and phone cable - the basestation were all the cords are plugged into) and leave it unplugged, pull out all the batteries in the phones, and then start by putting all the batteries back into the phones.
Once the phones are back and powered up, plug in the base station again, and see if that helps.
All this is doing is re-setting the phones and base station and forcing them to re-link to each other.
I hope this helps.
