Question about Magellan Meridian Gold GPS Receiver
Gps was dropped now backlight won't come on.
Where can i send it for repairs? thanks
  • 30 Answers
The LCD screen has Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} separated at the lower end soon the LCD will go dark blue and need to be replsced
Posted on May 18, 2009
The display is dim and hard to see.
First, make sure that your brightness is turned up. You can access this from the menu by selecting "Display" then adjusting the display between 50% & 100%.
If the brightness is at 100% and the display is still dim, this is an indication that there is a problem with the backlight that lights up the LCD display from behind.
The backlight is integrated into the LCD display, so the entire display needs to be replaced. Was the unit dropped? If so, perhaps the LCD flex cable pulled out of the connector, slightly from one side, disconnecting the backlight. We strongly suggest that you don't try to repair the unit yourself. Additional damage can occur.
More information on LCD repair can be found here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair
Mar 14, 2014 | Garmin nuvi 1300 Car GPS Receiver
My Garmin 296 beeps when the power button is turned on, momentarily the login screen flashes on with no backlight then fades away in about 1 second. Nothing appears on the screen and the unit behaves as...
If you have tried the master reset to no avail I recommend that you send your GPS in for repair. Once you open it yourself, the warranty is null and void. If it is under one year old, it is under a full warranty. If it is over a year old, Garmin will repair it for a flat rate of $296. You will have to decide whether repair or replace is the best option for you. That said, here is the link to their repair site http://www8.garmin.com/support/outofwarranty.html
Nov 20, 2009 | Garmin StreetPilot c340 GPS Receiver
My tomtomxl won;t turn on. the screen just has some lines on it. I have tried the reset a few times and still nothing
if it is under the 1 year warranty, send it in for repair....if not in warranty, you are out of luck
Jul 30, 2009 | Tomtom ONE XL GPS
MULTI DROP
Most GPS problems - Hangs, frozen screens, problems acquiring satellites, ETC, can be attributed to the device not having the latest firmware installed.
This firmware enables it to communicate with the satellites - but if they aren't speaking the same language they get confused easily. For Garmin GPS Automotive units, Garmin has you do the following before sending it in for repairs:
1 - SOFT RESET
2 - HARD RESET (CLICK HERE to see instructions for either reset)
3 - UPDATE the device using their WebUpdater software (CLICK HERE for that) Garmin is the only company that offers repairs AFTER the warranty has expired. They offer a FLAT RATE REPAIR service for units no longer in warranty. For Other GPS units please consult your owner's manual or their support site - as each model - and even manufacture dates - can lead to different reset procedures. TomTom
NAVIGON
MAGELLAN NEXTAR does NOT offer any types of Firmware or map upgrades or repair services. Instead - they have an exchange program to update to a new UNIT for around the same price as a repair would be. CLICK HERE for more on that. WARRANTY on most GPS devices is 1 year from the date of purchase. Broken screens are considered ABUSE - and not covered under warranty. Finally - If your unit is on the charger for HOURS, You've tried both the car AND USB type charger, and you turn it on... it stays on for a minute (or so) then powers down or never comes on at all - the battery has lost it's ability to hold a charge and must be replaced. Looking around YouTube - you can get a tutorial on how to CAREFULLY crack open just about any GPS. The tool(s) necessary typically are included with the battery purchase. Typically batteries run about $25 +/-. NiCd batteries are meant to be energized once a month so they keep active, and don't build up deposits that lead to their premature failure. I hope this was helpful for you. Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 29, 2009 | GPS
No backlight on my Garmin IQue 3600
Have you tried firmware update for your gps .
If you have not tried it try to update the latest firmware .
By updating firmware your problem can be fixed .
If your problem still continues then you need to take your gps to near by shop to get it repaired .
Feb 03, 2009 | Garmin iQue 3600 GPS Receiver
Broken Screen on Nuvi 260w
You can contact Garmin and send in the unit for an estimate, or
if it's not covered by your warranty, there is a site which repairsbroken screens on Garmin Nuvi's and their prices are VERY reasonable.They will also update your firmware for free while it's in the shop. Goto http://www.sharc.net/gps_repair.htm and click on the broken screenlink. You can see their charge for this service on the website.
I am not affiliated with this service centre but I understand they are very good, dependable and prompt.
Jan 31, 2009 | Garmin nuvi 200W GPS Receiver
No Backlight
my suggestion is send your P900 to SE's service center nearest you. but don;t forget to ask the service cost (sometimes it's better to buy a new unit than repair it)
Jan 02, 2009 | Sony Ericsson P900
Our Nuvi 200w was dropped and the screen is cracked. Suggestions and where to send it for repair .. thanks
i don`t know how true this is the guy at the source
told my wife that even if it get`s repaired under warranty if you live in Canada you have to send it to the U S for repairs when they ship it back you
are charged custom fees depending on how much
you paid for it probably not worth it, if you paid for
it with your gold mc card you are covered for damages good luck
Nov 27, 2008 | Garmin nuvi 200W GPS Receiver
I dropped my garmin nuvi and the power button is jammed in...am i hopeless?
Try to use a dental tool (small hook-pick) to pull it back out, otherwise send it back for repair.
Jan 27, 2008 | Garmin Nuvi 350 Car GPS Receiver
Magellan Meridian Gold GPS Receiver Logo
155 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
