Question about Samsung N150 Netbook
Why my samsung laptop n150 plus is only charging 80% still i put on charge after 80%?it only show green light after 80% which means that laptop not going to charge after 80%...WHY?
  • Samsung Master
  • 32,281 Answers
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Posted on Dec 04, 2012
  • 2567 Answers
SOURCE: samsung r60 plus does not recognise a/c power,i
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Posted on Sep 18, 2010
  • 2567 Answers
SOURCE: My Samsung p400 laptop won't power on. There are
1. Take the battery out of the laptop & try to turn on the laptop using power
adapter only. If the computer turns on, then the battery is defective & needs to be
replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the
power adapter using a voltmeter. Compare the voltmeter reading to the nominal value
written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re
-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try
swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced
  • 2567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
6. The motherboard could be defective & needs to be replaced.
Testimonial: "thanks for the answers. "
aexl
  • 212 Answers
SOURCE: samsung n150 laptop will only
Hi there, it sounds like your battery is no longer functional. You will have to replace your battery in order to get this working again. Before you replace it, ensure that the contacts on the battery and the laptop are clean and connecting - the odds of this being the problem are slim, though. -Alex
Posted on Aug 15, 2011
pooh2baby200
SOURCE: i have a samsung netbook
I dropped it and My samsung n150 wouldn't come on at all!! Basically i had to disassemble the back and that is when I noticed the switch was a little broke. So i removed the switch and put it back together. Now im using my laptop and have to manually reach in the area the switch was located and turn it on by hand, but atleast it works!!! Hopefully this helps
Posted on Aug 30, 2012
I have a Samsung N150, it will not switch on even even I put in the charger, it shows no light.
  1. pull out the battery after that u put the charger
  2. if the you have the same problem change the charger
  3. if still the same problem see the charging port of laptop
  4. if the problem is not solve check the power ic on mother board
Jun 13, 2014 | Samsung N150 Netbook
Samsung notebook N150 Plus has gone completely dead
Try another AC outlet, try another cord/charger of the EXACT same power spec. Has the AC jack in the computer been damaged by pulling on the cord? Power surge? With a multimeter, verify DC volts at ac cord plug. Is the Laptop usually left plugged it when not in use? Do you shut it down and unplug when not in use?
Jan 20, 2013 | Samsung N150 Notebook
Samsung n150 charger light blinking green
This might mean low charge current. Try replacing the charger. It worked for me.
Aug 04, 2012 | Samsung N150 Netbook
R60 Wont Charge
What's the make and model of your laptop? Most times the flashing lights will tell what the issue is.
If the laptop will not boot up so you can use it then the things below applies.
Sounds like your power cord is bad. Or the DC Jack is not soldered on good. Just because the power cord is new does not mean it works. Some Power Cords have a little green light on the adapter to show that it is plugged into the wall and getting power, check yours.
Anything ever post to the screen when you hit the power button? Do the fans start up, the hard drive spins? If not, maybe your power cord has enough power to emit a light but not enough to start the fan or disk drive.
If it's not the power cord or dc jack, then you have a Memory or Video Card issue.
OK after reading your post a 2nd time I think your only issue is that the battery is not charging, correct? If that is true the things below applies:
Either the battery is bad or the power cord is bad. Just because they are new don't mean they work. See if the Adapter portion of the power cord has a green indicator light that comes on when you plug it to an outlet. If it does, and that light is not on the power cord has issues. Also I hope you did not buy one of those one size fits all power cords from the big box stores where the end has a bag of different interchangable parts until you find one that fits into the laptop. If so, buy a power cord off ebay that is made for your laptop.
The battery might be bad and not hold a charge. I have seen new batteries that did not work.
May 16, 2012 | Computers & Internet
Samsung n150 laptop will only turn on when plugged in the wall. the charge light flashes green and orange repeatedly , when moving cursor over battery it says 0% battery remaining !! this just suddenly...
Aug 15, 2011 | Samsung N150 (36725723009) Netbook
My samsung n150 plus is although plugged in, the battery information describes that "plugged in but not charging"
my samsung n150,although plugeed in charging port displaying not charging..what is the solution for this problem..reply on vvvswathi@gmail.com
Apr 19, 2011 | Samsung N150 Notebook
Need to know what the lights mean on a makita dc24sa charger
• When the battery cartridge is inserted, the charging light color will change from green to red and charging will begin.
The charging light will remain lit steadily during charging.
• One red charging light indicates charged condition in 0 – 80% and two red ones indicates 80 – 100%.
• With finish of charge, the charging lights will change from two red ones to two green ones.
• The charging time is as follows:
Battery B9017A, BH1220, BH1420, BH9020A: approx. 20 minutes.
Battery B2417, BH1233, BH1433, BH2420, BH9033A: approx. 30 minutes.
Battery B2430, BH2433: approx. 60 minutes.
Nov 20, 2008 | Makita DC24SA 24 Volt Makstar Battery...
Samsung N150 Netbook Logo
353 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
