Question about Jacuzzi Home
Newly installed Jacuzzi Primo 7242 whirlpool tub will not come on, makes no noise at all.
PartsCenter
  • 125 Answers
SOURCE: jacuzzi tub makes noise but jets wont work
sounds like maybe the impeller is just spinning on the shaft of the motor.
Posted on Feb 24, 2009
  • 80 Answers
SOURCE: Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Posted on Sep 05, 2009
  • 491 Answers
SOURCE: water leaking due to faulty knob on jacuzzi whirlpool
replace rubber wasers
Posted on Oct 10, 2009
Mackmech11
  • 122 Answers
SOURCE: whirlpool jacuzzi tub is not turning on when power
there might be a fuse at the pump that has blown
Posted on Apr 19, 2010
uspartscente
  • 717 Answers
SOURCE: RapidHeat In-Line Heater U395000 [ Bathtubs and Whirlpools,: My jacuzzi tub jets run for ONLY about 5 minutes b...
you have a bad motor - when a motor overheats there is a sensor inside the motor that will shut if down so as to not damage the windings and such. once your tub has cooled down for 10 mins or so it will turn back on. the fact that you can push the button multiple times just means that you are turning the air switch on the back of the motor on/off until you get to the point where the motor has cooled down and will turn back on. if you do not push the air button after the tub shuts down and you finish your bath then when the pump cools down it will come back on because the air switch in the motor is latching i.e. it is either on or off. Since you left it in the on position the motor will come back on once the motor has cooled down.
Posted on Sep 06, 2010
Newly installed jacuzzi only has hot water for about 30 seconds, then water is tepid only.
This issue will have nothing to do with the jacuzzi tub. You will find the problem exists in the way your home was plumbed by the plumber.
Somewhere there is a clog in the water line going to the hot water faucet.
Find that and you will solve your problem.
Rod
US Parts Center
Mar 06, 2014 | Jacuzzi Home
I am missing the drain stopper for a Jacuzzi Signa 6 whirlpool. This is a round disc with a short metal stem on its underside.
Drain plugs on bathtubs are generic in size. Jacuzzi does not make them. They are made by other Mfg and installed by your local plumber when the tub is installed.
US Parts Center
Oct 28, 2013 | Jacuzzi Home
HELPED INSTALL A JACUZZI FOR MY FRIEND TWO MONTHS AGO. ALREADY THE AIR BLOWER MAKES THE PROPER NOISES BUT NO AIR COMES THROUGH THE VALVES. HELP PLEASE
Check the air intake and see if it is ok. Check the output side of the airpump too and also make sure that the nozzles in the tub are not screwed down to shut them off.
Oct 14, 2013 | Jacuzzi Home
Had turned on the jacuzzi tub and had power failure. Did not turn it off after power came back on. Pump ran without water for 6 hours. How do I test to see if this is now ruined?
Put water in as required, see if the pump leaks out. If not, turn on pump and see if it pumps water. Six hours is a long time, but I would check it before making an assumption that it is damaged.
If it is damaged, you will have to drain the water to repair/replace it.
Gary
Jul 02, 2011 | Jacuzzi DX50-959 Elara 7242 Salon Spa...
I have the Jacuzzi DX50 Elara7242. I plugged it in after not using it for 3 months and no power. Fuses, circuit breakers, power connection checked? Any help?
the only thing I can think of is checking all the power connections on the electonics of the tub. Making sure all those connections are snug
Jan 22, 2011 | Jacuzzi DX50-959 Elara 7242 Salon Spa...
We have a new Jacuzzi tub and went to turn it on
check to make sure the pumps on and that its wired correctly and that all valves are open.
Feb 22, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi Espree 7242 pump/motor will not shutoff. Manual says to reconnect tube to Magic Touch switch or to air switch pumpmotor. Do I have to pull the tub out? It sits in a tiled skirt.
There should be a removable panel either around the skirt or in the ceiling below the tub to access electronics and plumbing to repair.
Jan 09, 2010 | Tools & Hardware - Others
The Jacuzzi isnt recieving power
yes it could, it might even be the motor, take the electric suply and unplug it see if you can turn the shaft on the motor if not it froze up,, sometimes the get wet and seize, the you have to get a new motor
Feb 27, 2009 | Jacuzzi Allusion 7242 RH Whirlpool HTR...
Home Logo
75 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
