Question about Dell Computers & Internet
USB port dysfunction but when restart the laptop it function again for few minutes then dysfunction again
3 Suggested Answers
drifterK
  • 4924 Answers
SOURCE: my hp pavillion laptop is having a problem with a
It may be just a matter of a driver ...for example you have a 1.0 port and it need a 2.0 usb port ..so you will have to install the 2.0 usb driver ..if it is not installed...or maybe the laptop is not equipped with one ...but I doubt it ...Anyway ..first go to bios (press F2 on start ) and in there restore to optimal factory defaults ..and save changes with F10 ...
In this point you know for sure that your USB ports are enabled...Than run the driver for the mouse from the disk that came with it ...Usually it will be an Usb 2.0 driver too ..but if you have at least the windows XP on it ..this is already installed from the operation system ....
if all that are made..the only thing that remain to check and concentrate on is the pairing of the receiver and the mouse itself...just press that button ..and let them pair again ...
Posted on Jul 17, 2010
damnor01
  • 1179 Answers
SOURCE: My usb ports stop working and then are ok again?
Hello there, I am the computer technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Madgoody.
This is a software fault, specifically with drivers for the USB 2.0 controller of your notebook.
You will need to do the following:
1.) Right click My Computer and select properties.
2.) Click the Hardware Tab and clcik Device Manager.
3.) Find the heading: Universal Serial Bus Controllers.
4.) Click the + next to the USB heading.
5.) Right click on USB Root Hub and click properties.
6.) Now click the driver tab and click Update driver.
Select the option for this time only and click next.
A driver should be found automatically.
You could also go to your notebook manufacturers website, Compaq and search for drivers using your model number 6730b. Then download the USB drivers.
Take care!
Posted on Feb 03, 2012
Testimonial: "Thanks Norman i have tried this and hopefully it will solve my problems ;-)"
Laptop does not recognize usb connection to phone
The problem very well could be that it isn't connected fully (maybe not fully plugged in). or that the USB port on your laptop is dysfunctional. The charger could even be malfunctioned. Try to charge in another USB (as not all are powerful enough to do so). If that doesn't work, you could buy a new usb cord to try that, and then if that doesn't work you may just want to stick to using the wall charger.
Apr 15, 2014 | Verizon Communications HTC SMT5800 Cell...
USB PORTS NOT WORKING
try to update or download the usb cord of your laptop
Nov 27, 2013 | Toshiba Satellite C655-s5090
My two right hand usb ports won't work
Ist u check the BIOS Setup if the Usb port are enable then u r ports need to repair on shop
http://software1cracks.blogspot.com/
Oct 30, 2013 | Acer Aspire E1-571-6650 Laptop
Dell inspriation N5010 laptop this laptop all usb port is not working . laptop purchising in 3month and windows 2007 operating system instaled what is problem please sole the problem
If USB devices such as jump drives, digital cameras, or printers are no longer functioning properly when connected to your laptop, the USB ports may have malfunctioned. There are plenty of troubleshooting steps you can complete on your own to get the port up and running properly again.
1.Connect the USB device into a different USB port on the laptop or another computer to make sure the problem isn't with the device instead of the port. Check to see if the device has a "Write-Only" tab. Push that tab into the unlocked position if it still isn't working in a different port.
2.Click "Start" and then "My Computer" if the device works in another computer but not on your laptop. Plug a device into the port and wait to see if the USB port shows up in the list of drives. Click on "Map Network Drive" if the drive does not appear. Choose a drive letter from the drop down menu and then double click the location of the USB device. Click "OK" and try to use the port again.
3.Navigate back to the Start menu and then click "Control Panel." Double click on "Device Manager." Scroll down the list of options and click the "+" located to the left of the entry labeled "Universal Serial Bus Controllers." Double click the name of the USB port that appears in the new menu. Click the "Drivers" tab and then click "Update Drivers." Wait for the driver to finish downloading and attempt to use the port again.
4.Close the drivers tab and right click the name of the USB port. Click on "Properties." Click the "Power Management" tab and then un-check the check box labeled as "Allow the computer to turn off this device to save power." Choose the "Communications Port" tab and then scroll down to the box labeled "Resources." Click the "Enable Device" button and then click "OK." Attempt to use the USB port again.
5.Close the Properties tab and right click the name of the USB port. Click on "Uninstall." Restart the laptop and then plug a device into the USB port. Wait for a new window to pop up and follow the on-screen instructions to re-install the USB port software.
6.Restart the computer and press the "F1" button on the laptop's keyboard once the manufacturer's name appears on the screen. Scroll down through the list of options that appear and highlight the option labeled as "Advanced." Press "Enter" and then scroll down and press "Enter" on the "USB Support" option. Press "F10" to save the settings and finish loading the operating system.
7.Open your web browser if your laptop is running the Windows XP operating system. Navigate to the Microsoft website and download the Windows XP USB 2.0 driver (see link in Resources). Restart the computer and try to use the USB port again.
I hope you find it very helpful. Best regards.
Aug 18, 2011 | Computers & Internet
USB PORTS HAVE STTOPED GIVING ANY POWER TO DEVICES.
Go to the Manufacturer's website and download the latest drivers.
Aug 19, 2010 | Packard Bell Computers & Internet
The usb port won't work on my acer extensa 4630z laptop
Did you install any Anti virus . Check the USB port for any physical damage. Try connecting a mouse with USB port to check if its working. After all this then the issue remain the same then the USB port needs an replacement.
Regards.
Feb 08, 2010 | Computers & Internet
Hi, I have to notebooks...on one, the internet
give them static ip address. Most of time we use the dynamic address, but this can result to conflit with other device or other dysfunction.
let m know
Nov 15, 2009 | Computers & Internet
ONE OF MY USB PORTS STOPPED WORKING ON MY DELL LATITUDE D600 PC NOTEBOOK.
A shot in the dark here, but try this: Click Start>Run, type devmgmt.msc and press enter. Click the plus sign beside "Universal Serial Bus Controllers." Right click each listing that appears underneath "Universal Serial Bus Controllers" and click Uninstall. Click OK on the confirmation dialogs. After you get done uninstalling all of them, restart your computer and Windows should reinstall them. After it is done, try that USB port again.
Nov 11, 2009 | Dell Latitude D600 Notebook
Thinkpad T20 won't recognize usb port
You can get a PCMCIA adapter with 4 USB v.2.0 slots on eBay. It requires power from the USB port on the laptop, but the pigtail connector is included. Works like a charm! Comes from China just like everything else in this country.
Nov 16, 2008 | IBM ThinkPad T20 2647 Notebook
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
