Question about Locks & Locksmithing
HOw to change battery and reprogram unican locks?
2 Suggested Answers
  • 963 Answers
SOURCE: Need to know how to reprogram the code on a
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE
DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE
O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE
THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS.
REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a
maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND
CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH
SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59
CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the
Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.
aspx?id=13
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Good Luck!
Posted on Mar 06, 2011
How to Change Batteries in a Unican Door Lock
Are you sure that your lockset takes batteries. Most Simplex brand locksets are mechanical and don't require batteries. Take a picture and post it on here and I'll be able to tell you.
Feb 26, 2013 | Locks & Locksmithing
How can I put a new code in a unican 7000 when I dont know the original code
You will find a link to download the manual for your model on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Go to the grid that the highlighted link above takes you to, then go to the far-right column for 7000/7100 " Tips" and click on PDF, which will download the PDF file of the reprogramming instructions that you need. Again, you will need Adobe reader to view this file.
Jul 26, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I changed the batteries then initialized it and it won't work. I can access it with the emergency card. I tried to reprogram it and it always says can't establish connection with the lock. It has...
The Unican 1000 locksets are pushbutton locks and do not use a card for access. I think you may not have referenced the proper model that you are having problems with.
I'm including a link to Kaba Ilco products page where you can research your model of lock:
http://www.kaba-ilco.com/access_control/products/eplex.aspx?id=6
You may find that your lock is under the E-Plex series, which use card access.
Also to be found on that page is a link to "Literature and Support" which you can expand to take you to the proper information grid for your model of lock.
The Literature Grid contains links to PDF files which have headings for the Manual, Parts List, Instructions Charts, etc. The Instructions Charts may be of most interest to you because they contain troubleshooting information.
In order to view these PDF files,, you will need Adobe Reader installed on your computer. There is a link on the Grid page to Adobe Reader if you don't already have it installed.
Near the top of the Literature Grid page you will find a link called "Contact Us", and under that link you will find links to Customer Service and Support and Technical Support which will allow you further assistance by Kaba Ilco support, either by email or by calling them toll-free.
I hope this information helps. Good luck!
May 20, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I changed my combination and dont know what i set it to
If you forgot the combo you will need to reprogram it. If you can not get in to open the door to reprogram you can email llco at info@lilocksmith.com for an override code.
Good Luck
Dec 28, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
How to reset codes in Kaba ilco Unican 4000 access control
I have a Unican 4000 series door lock and need to find code for it
Dec 20, 2009 | Locks & Locksmithing
I need to change the code on my unican ll1011
Copy this address into the address bar on your web browser http://www.tharstonconsultancy.co.uk/html/body_code_change.html You will find detailed instructions for the change. Please rate this answer,thanks.
Apr 11, 2009 | Simplex Kaba Ilco Unican 1011 keyless...
Unican keycard door locks at hotel
unican card machine its keep giving a invalid card error read on main card but bellman card works though
Jan 14, 2009 | DG Gold / Brass 98 Biometric Keyless...
Locks & Locksmithing Logo
47 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
