Question about Bosch Filtrino Fast Cup Hot Filtered Water Dispenser
Bosch filtrino fault
Not filling cup up
3 Suggested Answers
p4ul_hurst
SOURCE: descaling instructions bosh filtrino fast cup
From the manual, although I cannot get it to work.
-Turn the appliance off with the on/off
switch.
-Press and hold the start/stop button.
-Turn the appliance back on with the on/
off switch.
-Release the start/stop button as soon
as the DESCALE symbol lights up.
Running the descaling programme
-Remove the water tank, pour out any
remaining water, and reinsert it.
-Prepare the descaling solution according
to the manufacturer's instructions
and pour it into the water tank up to the
calc mark. A descaling agent approved
especially for this machine is available
from Bosch Customer Service (Article
No. 310967) or from specialty retailers.
-Place a container holding at least 500 ml
under the water outlet. The container
must fit the cup stand exactly and must
remain in place. Set the cup stand to the
lowest position.
-Press and hold the start/stop button for
at least 10 seconds to start the descaling
programme.
-The descaling programme will now
run automatically. The N icon flashes
while the programme is running. (The
programme runs for approx. 10 minutes).
The descaling solution is pumped
through the appliance in multiple phases
and then runs into the container until
the water tank is almost empty. A small
amount of solution is always left in the
tank.
-When the most recently selected
temperature icon lights up, the descaling
program has finished.
-Rinse the water tank thoroughly and fill
up to the max mark with fresh water.
-Now select and draw warm water three
times to rinse out the appliance. Do not
drink this water!
Posted on Nov 03, 2012
It took me ages to get his to work - seems that on the THD2023GB (Black) Filtrino, you push and hold the temp. set button for 10 seconds to get he descale programme running.
Posted on Dec 22, 2012
Tip
How does circuit breaker work?
In the circuit breaker there are two electrodes with space some distance.
There are many types of circuit breaker air blast,oil C.B, vacuum C.B etc.
Most probably oil circuit breaker is used. In the OCB, the transformer oil fill.
And these electrodes are submerge.
Now when the electricity flows from one terminal to another terminal, the arc is developed between terminals end inside the circuit breaker. This arc is quenched by transformer oil.And the electricity flows without any fault.
on Mar 04, 2010 | Bosch PowerStar AE125 AE125 Whole House...
Fill tank& descale keep flashing.
Fill the reservoir with white vinegar and run a cycle. Discard the vinegar and repeat the process a second time. that should remove the scale and reset the flashing light.
May 19, 2014 | Bosch TAS2002GB Tassimo T20 Hot Beverage...
Bosch silence plus 50 dba has error code h01
The statement below can be found at: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html,
The SHU4326 and 4326 models use "Regular Wash" and "Rinse Hold" to begin the test while the other three series in this section use "Scrub Wash" and "Delicate/Econo," but all use the same set of fault codes, shown not as lights but as numbers on the Cycle Countdown display. Here, 1 is an aqua sensor fault, 2 is a heating fault, 4 is a filling fault, 8 is an NTC fault and 0 means that everything is working as it ought. During an actual wash, when you aren't testing, the Cycle Countdown display may show the letter "F," which also signifies a filling fault.
Read more: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html#ixzz33JutQVQR
Apr 05, 2014 | Bosch Evolution 300 DLX SHE43P26UC Full...
How do you do the descalar cycle
Jan 17, 2013 | Bosch Filtrino Fast Cup Hot Filtered Water...
Descaling instructions bosh filtrino fast cup
Sep 30, 2012 | Bosch Thd2021gb Filtrino Fast Cup Hot...
Bosch GWH 715 ES flashing EA code. This unit was working fine for over a year so I am assuming gas pressure can't be the problem? The spark is flashing and the unit lights for about 2 seconds then...
http://www.digelair.net/pdfs/TECHLIT/BOSCH/MANUALS/Bosch-ProTankless_AM.pdf
http://www.bosch-climate.us/files/201009031238250.GWH715ES_English_12.2008.pdf
Above are the manuals required to diagnose and service your error code.
EA: No flame ionization detected with water flow.
Verify that all manual gas shut off valves are open. Check gas type. Reset error code and open a water tap to cycle the heater in an effort to purge air on new installations. Cycling hot water tap on and off multiple times may be necessary. If heater still faults with EA error code, have a licensed gas technician properly purge air out of the gas line leading to the water heater. Check three wire connections to ignition group on the lower front of the heat exchanger are secure. Check gas pressure. Check venting specifications are met. Improper venting may cause premature failure of the flame sensor rod. Check that the minimum power fan speed has been adjusted to the proper value. Observe inside the viewing window of the heat exchanger when a hot water tap is opened. Sparking should be followed by a steady blue flame. If flame is unstable or yellow with proper gas pressure.
Jul 07, 2011 | Bosch & Tankless LP Hot Water Heater
I have a Bosch 21e instantaneous water heater attached to a Hills evacuated tube system. On cloudy winter days when we use the washing machine on warm the heater has an intermittent fault for a couple of...
Wild guess, but washing machine use solenoid valves that turn on and off instantly, causing a great deal of hammering of the entire water system.
Regardless of whether or not this fixes your current problem, you really should install a large air canister to buffer the shock in the system. Normally I would suggest installing in the cold line just after it enters the house, but with your solar heating system, you need one after it as well, because there is quite a bit if switching going on. It is quite possible the switching is the problem and not the Bosch heater. Try bypassing the Hills system and see if that helps?
May 16, 2011 | Water Heaters
I have a Bosch GWH 2400 CTD EFS NG tankless water heater. It has been installed on operating for over a year in the last several days it has an error code A3. The first two times I was able to reset it....
Call qualified service technician, and ask that person questions about maintenance and tips.
Then keep service technician number in rolodex-wallet.
Resourceful do-it-yourselfer will find following links handy.
Tankless are maintenance heavy, and Bosch and Rheem etc say to call service technician for recurring problems. Especially when short-hand troubleshoot section doesn't solve problem.
People spend years learning how to service tankless.
Bosch has online tech support form:
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
BOSCH error codes online:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Bosch manuals:
http://www.boschhotwater.com/HelpfulResources/BrochuresManuals/tabid/354/Default.aspx
Bosch problems at Fixya:
Open following links and read about tankless problems to understand the field and glean useful information.
http://www.fixya.com/support/p949576-bosch_1600h_lp_liquid_propane_aquastar_a/solutions
Install DIY tank-type gas water heater and avoid the whole headache
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Post question on pro water heater forum: This is where I go to catch up on latest info in always-evolving water heater industry.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Pay for an answer at fixya:
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 17, 2011 | Bosch & Tankless LP Hot Water Heater
Bosch Filtrino Fast Cup Hot Filtered Water Dispenser Logo
79 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
