Question about NetGear WGR614 Router
Wgr614 disconnect Hi, I am using this netgear WGR614 N150 router with my reliance Broadband connection. Recently it has started getting disconnected frequently from internet. All devices attached to this get disconnect once this issue happens. I am using 2 machines mostly: 1. Windows XP desktop (wired) 2. Samsung S3 Android phone. (wireless) I contacted my ISP and they are saying its not their fault which seems to be true since internet is working fine when PC is directly connected to modem w/o router. I have hard reset the router and have applied many troubleshooting steps mentioned on various tech websites but nothing seems to help. Please help me in this regard. Other Information: 1. IP and DNS provided by ISP are both dynamic and hence assigned to automatic. 2. Even at the time of disconnection I am still able to open router home page and can browse around different settings. 3. there is no change in the way lights blink on router even at the time of disconnection. 4. Problem gets solved when i use opendns instead of automatic but only for 1 session. After that its not even able to connect once and i have to again switch to automatic dns settings to connect.
  • NetGear Master
  • 15,478 Answers
  • 14 Answers
SOURCE: Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Posted on Dec 06, 2007
bee2busy
  • 51 Answers
SOURCE: Netgear Router WGR614 will not connect to internet
Looks like when you reset the router you have lost all yur configuration and back to the default factory settings.
Bridge the 5100 first.
1. In your web browser browse to »192.168.0.1 This address will be located on a yellow sticker on the bottom of your modem.
2. The first screen will ask you for your Modem Access Code. This also will be located on the same yellow sticker.
3. Select Advanced from the blue buttons on the left.
4. Click the PPP locations button.
5. The modem may ask your for the Modem Access Code again. If so type it in again and click continue.
6. Select the radio button labeled, "Bridged Mode (PPPoE is not used)"
7. Click Save Changes.
8. A "PPP Location Warning" page will come up. Click "Change PPP Location."
9. A "Restart Needed" page will come up. Click "Restart"
10. Reboot your computer and and then connect the router
11.Configure the router for PPPoE using your ISP uid/pass
12.Configure your wireless using WEP
13.Desktop : Using Dell wireless client configure the client using the same SSID ,wep as configured in the router
Laptop : follow the same as desktop
(by default dell wirelesss client takes over the wireless configuration in dell pc.to disable it and use windows wireless client..control panel ->administrative tools -> services -> enabl2 wireless zero configuration)
14.after all configuration shut the desktop,laptop,router,mdm and pwr them in seg..first modem and then router and then your desktop or laptop
Cheers !!!
Posted on Feb 26, 2008
redhaze89
  • 854 Answers
SOURCE: Cannot get my Netgear WNR834B router to see the 'net
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
Since your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on May 02, 2009
redhaze89
  • 854 Answers
SOURCE: Netgear WGR614 connectivity issue w/ Time Warner Cable modem
If your Internet Service Provider is using a cable connection, please follow the steps below:
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
5. Power cycle.
Posted on Jun 16, 2009
anandg27
  • 1272 Answers
SOURCE: PS3 NAT type 3 issue
HI, Upgrade the firmware on the router and then forward ports on the router for the IP Address of your PS3.
Let me know if you need any further help.
Posted on Sep 06, 2009
NETGEAR N150 WIRELESS ROUTER STATIS IP ADDRESS CONFLICT WITH DSL 502T MODEM
Change the ip address of the router to 192.168.5.1 and power cycle.
Dec 21, 2012 | Computers & Internet
Cant hook up my ps3 to my netgear wgr614 n150
need to get ps3 component cable that can hook directly to the router,if it is a wireless router goto ps3 setup menu,then turn on network discovery on ps3,then will ask for password from router fill password in,it will hook up.
Dec 21, 2012 | NetGear WGR614 Wireless Router
I dont have the drivers for NETGEAR 54 Mbps wireless Router WGR614 v7. I want to connet my BroadBand connection to my Router I want to use my LAPTOP without wireless. kindly assist me about the...
Hello, I dont think you need the drivers for Router. And first of all you need to connect your modem to your router through ethernet cable. And after connecting your modem, configure your wireless router by typing this IP address in internet explorer: 192.168.1.1 The user id is admin and the password is password. Then detect your broadband connection by using the option in the router. Try connecting your Laptop to wifi after setting the connection.
Nov 02, 2010 | NetGear WGR614 54Mbps Wireless Router...
Could not make router to work, Netgear modem adding router.
i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
Nov 10, 2009 | NetGear WGR614 Wireless Router
Internet connection disappears.
You may either need to do a firmware update, or reset it back to factory default, you can download the firmware from the netgear site, or you can log onto the router and do a reset of the router.
Hope this helps,
Daid
Mar 15, 2009 | NetGear WGR614 Wireless Router
Internet access not working on desktop thru Netgear WGR614 router
Make sure your desktop doesn't have static IP address. Go to Network Connections, Properties of Local Area Connection, Internet Protocol > Properties. Select Obtain IP Address Automatically and Obtain DNS Servers Automatically. Apply the changes and restart the computer.
Jan 18, 2009 | NetGear WGR614 Wireless Router
NETGEAR WGR614 Wireless Router keeps beeping
try by upgrading the latest firmware version from netgear website
Dec 15, 2008 | NetGear WGR614 Router
Netgear
There are two things involved in getting disconnected either your comp is getting disconnected or your router.
Instance 1
Computer getting disconnected connect your comp and router with ethernet cable if using wireless. Because at times it's not router but the wireless connectivity that gets loost.
Instance 2
Router getting disconnected...
Reset your router by holding the reset pin at the back of your router for 15 secs and lights will start flashing on router wait for 1 min you'll have router reset to default settings and now check that dsl or internet light on your router is flashing or static if flashing contact your isp issue with the line if static run the disc for router installation again and it'll remain connected after successful installation.
Apr 22, 2008 | NetGear WGR614 Wireless Router
NetGear WGR614 Router Logo
35 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
