Question about Pioneer PDP-6020FD 60 in. Plasma TV
Pioneer pdp-6020fd blue light blink 8 times - Pioneer PDP-6020FD 60 in. Plasma TV
  • 3 Answers
SOURCE: Pioneer PDP-5030HD power supply
click link -ebay shop selling power supply boards for 503hde/pe at 180 pounds you will have to contact him has he does not list them as pioneer are only ment to replace these boards or shops under contract with pioneer i changed mine and only takes min's when you have got the back cover off...
http://stores.ebay.co.uk/Plasma-Parts-UK
hope this helps mark doran
Posted on Mar 17, 2009
SOURCE: I have a Pioneer pdp-433 plasma with a media
Alas, the powerblock has gone.
Common problem on this model.
Only solution is replacement powerblock.
Pioneer used to repair this for nothing even out of warranty (they did for me), but they may not be so willing now, as your tele must be at least 6 years old. Unfortunately, it will be cheaper to buy a new TV than to pay for a contractor to fix it.
Brian
Posted on Jul 27, 2009
toolkits
  • 1099 Answers
SOURCE: my pioneer pdp-4270hd television wont turn on. i u...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Posted on May 23, 2010
SOURCE: I have a Pioneer PDP-R05G
This is a classic "Hic-upping" switchmode power supply problem. The protection circuitry inside the SMPSU, has sensed a severe potential problem, and is attempting the shutting of the set, down to avoid a fire, explosion, or both.
This set had developed a problem, that is so severe that the set must be shut down, (This set should be removed from the Power),
What is happening is the internal "Fault" that is causing the Protection Circuitry , to detect the problem and attempt to shut down the set, keeps restarting the set, because as soon as it shuts down, the "Faulty" component(s) cool down?, and the "Fault" ostensibly "Clears" so the PSU starts up again, only for the component(s) to heat up, whatever, again and fail, so it shuts down, and if left unattended, this would continue on until the part eventually failed. As related this is called a "Hic-upping Power Supply". Any fault that involves the power supply is usually quite serious, and needs a professional, usually, unless one is familiar with servicing current day, televisions.
And in my professional recommendation, you should get a "Quote" for repair, from, an, Approved Service Center. Now, this point is very important for a good result, Always contact, their "Local" or a, "Head Office" Philips in your case. Ask them, for a referral to an authorised servicing center, where you ask for a "Quote". Now, when you get the information you want, then you can decide as to repair of replacement.
The reason we want an approved agent, is that way, all the engineers are trained on their own brand sets, they have seen almost all faults, and will get the job done quicker, and for less cost, and usually have parts on hand, also sometimes, there has been a service bulletin in issued and the repair may be subsided or even free. There are many, many, many reasons that display this symptom, one must work through the troubleshooting steps to isolate and identify, the Cause and repair that and any damage done.
http://www.pioneer.owner-manuals.com/PDP4360HD-service-manual-PIONEER.html
service manual link above,
as an aside here, sometimes things in storage can quickly degrade especially big low value capacitors, these increase in internal resistance, and all sorts of problems ensue, this is why, say, military things are cycled at least weekly when in "Moth balls" to prevent exactly this.
Posted on Mar 12, 2011
eagle338
  • 4889 Answers
SOURCE: Pioneer pdp 5080hd plasma tv
I do not think 12 blinks is related to the power supply. Its a tuner issue as far as I know. Are you sure its the power supply?
Posted on Apr 10, 2011
I turn it on a blue light came blinking but no sound and no picture
The blinking blue light may be signaling power supply failure.
May 06, 2016 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Find activation code for pioneer
My pioneer 5020FD Kuro tv. when I plug power to the unit, a blue light blinks 8 times pause 2 sec. and blink 8 times repeating this and if i press power button it clicks red light and makes a clicking sound and goes back to the blue light blinking again, it did this once before and the picture came on fine until i turned it off and now it just blink the blue code.
Dec 10, 2014 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Pdp5080 pioneer blue light 8 blinks
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
May 19, 2014 | Pioneer PDP-5080HD 50 in. Plasma HDTV
For the last 24 hrs, our 50 in plasma has had no picture,no sound, but yet a blue light blinks 12 times, pauses blinks 12 times,what does this mean
Pioneer has this to say about the issue:
"On the models listed below, Engineering has determined this to be part of the normal operation, if the unit will power on.
If the unit does not power on, service may be required on the set.
Please contact our Plasma support at 1-800-421-1625.""
Elite models:
PRO-940HD, PRO-1140HD, and PRO-1540HD
Pioneer models:
PDP-4270HD, PDP-5070HD, and PDP-6070HD
Good Luck
Thomas
Dec 02, 2013 | Pioneer Televison & Video
Blue light flashes 8 times no pic
This is an error indication of defects inside the TV and might need service.
Aug 28, 2012 | Pioneer PDP-4280HD 42 in. Plasma...
Problem with Pioneer PDP-6010FD
Hello
The set can be set right by repair. You must have through knoledge in electronics to do work with set. especially, plasma displays will have very complicated circuits. It Sustain-Boards suld be trouble shooted.
Feb 21, 2012 | Pioneer PDP-6010FD 60 in. Plasma HDTV
Pioneer PDP-r06xe 50 in. Plasma Television Problem. During a Rain Storm - a lightening strike in my loft - the save system it has protect several electronics, but when I try to switch on - the TV it turn...
when switch ON it blinks 7time blue led - then switch OFF by SELF and blinks 8time blue led. Of-course when it switch off by self the TV swap the led from blue to red but the blinking Blue led is on the Receiver (The switcher on the TV is never blinking)
May 22, 2010 | Pioneer PDP-4350HD 43 in. Plasma...
Black bars on top and bottom when watching movies on plasma will it hurt tv
Your refering to the widescreen cinema mode.This will not affect plasma.Only still pictures with colour retention will do it but even then it would take many hours to take effect if at all.
Jan 01, 2010 | Pioneer PDP-6020FD 60 in. Plasma TV
Media Receiver Shut-down, Blue LED Flashing for Pioneer PDP-R06G
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty.
May 10, 2009 | Pioneer PureVision PDP-4340HD 43 in....
My 60''pioneer plasma blinks 12 times after i turn it on
looks like 12 blue blinks is a communication with the Digital tuner error. pioneer had a software upgrade/fix for this in some cases, others might need a new digital tuner pcb. I would unplug all power, wait 5 min, plug in (wait1 min) and try it again. If it is software, it should hopefully work. Make sure you pull your cable card if you have one. If it still won't turn on, you probably need the digital tuner board = $200-500 repair. Pioneer is usually very helpful, I'm really surprised they didn't help at all.. They'll want model #, serial # and date of purchase.
Jan 31, 2009 | Pioneer PDP-6070HD 60 in. Plasma...
Pioneer PDP-6020FD 60 in. Plasma TV Logo
865 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
