Question about Sharp Office Equipment & Supplies
Sharp mx-3100n doesnt print from publisher
Can't print from publisher 2010. word prints ok.
SOURCE: MX-2300N Sharp Copier will not print
Do you have setup accounts on the copier?
Posted on Apr 02, 2009
tehnik_bdg
  • 91 Answers
SOURCE: sharp mx 3500 won't recognize custom paper
In the printing properties, on the paper select tab, change the paper tray from automatic to by pass tray
Posted on Jun 23, 2009
  • 120 Answers
SOURCE: hello i have copier machine sharp mx-450u,with
As a general rule, U machines are not designed to be turned into network printers, that's what the MX-M450N is for. You can put an MX-NBX3 on it, it might work properly and it might not.
The NBX3 can only function properly with a hard drive in the copier, otherwise you're outta luck!!
Your driver type may be wrong. If you are currently using PCL6, try PCL5e.
Other than that, try getting a new driver from the Business Copiers section of sharpusa.com. You may have to see which model will work for you. Look for the PCL driver for MX-NBX3, then look for MX-M450U, then MX-M450N.
Posted on Jul 09, 2009
nikeananth
  • 267 Answers
SOURCE: What is error code 5000 for sharp mx-3100n
HI,
this will help you out...
http://www.afoffice.com/sharperrorcodes.htm
thank you,
vijay(vote for me)
Posted on Sep 24, 2009
Testimonial: "Many thanks"
xptareq2000
  • 1447 Answers
SOURCE: how to print back to back pages on sharp Mx-2300N
Back to back mean duplex print .If your copier has a duplex cassette you can use duplex print before configure it see your user guide and follow this function.
Posted on Dec 16, 2009
What is the full meaning of ptc, mfp, scu, pwb,LSU,LCC,SRAM,SUM,CPT
LSU - Print Head which houses the (LASER)
LCC - Large Capacity Cabinet (Holds a Lot of Paper, more than a normal tray)
SRAM - Static Random-Access Memory
CPT - Toner Cartridge Code
PTC - Primary Transfer Belt Cleaning Unit
MFP - Multi- Function Printer Control Board
SCU - Scanner Unit
PWB - Printed Wire Board (Circuit Board)
Hope that helps
Oct 16, 2015 | SHARP MX-3100N
Will a maintenance required code FK1 prevent printing on a Sharp 3100N printer/copier?
Yes it will if SNMP is ticked in the Ports tab situated in the printer properties of the print driver. To check this open up Printers & Faxes on the PC, right click the sharp printer & select "printer properties" Click on the 3rd tab along(Ports) & on the lower left hand side you should see the SNMP box. If it is ticked then untick it, apply & OK. This should allow to print. If this box is ticked then when the copier displays any maintenance code it wiil allow copying but not printing.
Hope it helps.
Dave.
Sep 25, 2014 | Sharp Mx-3100n Color Copier Super...
Sharp mx 3100n
Sounds like PJL = Printer Job Language Set source Color Convert. whatever that means !!!!
Sounds basic but have you checked the Manual ? http://www.manualsprinter.com/sharp-mx-3100n
Go through sending test prints and go from there.
Aug 25, 2014 | Office Equipment & Supplies
What is maintenance code of DC on Sharp 3100N
This is a scheduled maintenance programmed into all of these machines. It pops up when the machine crosses a certain "milage." If your machine is still making nice copies and prints it's nothing to worry about.
Copier Collin Houston TX Copier and Imaging Expert
Jul 04, 2014 | Sharp Office Equipment & Supplies
Anything try
Which windows platform.
Jan 28, 2014 | SHARP MX-3100N
Will not print from Acer laptop
Is the copier locked, do you need to input a user code to use the copier?
If so, you need to enter that user number in the job handling tab of the printer preferences page.
Printing data light is blinking
Check if the machine print is put to paused, go to status and make sure you it is on resume not paused.
Dec 12, 2013 | Copystar Sharp MX-3100N Copier : Sharp...
SHARP MX-3100N CODE E7-06
MFP -Image data decoder error
Try to clear code. enter sim with program key- asterisk*-clear key- asterisk*(P-*-C-*) enter sim 14 print key execute yes clear all machine will reset. if code comes back it is not just not a fluke and you may have another issue.
Aug 28, 2011 | SHARP MX-3100N
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
