Question about BenQ 19" FP931 Flat Panel LCD Monitor with 250 Brightness, 450:1 Contrast, 16ms Response, DVI, VGA (...
Samsung syncmaster 175v
I turned on my monitor and it came on and could see my desktop, then it was gone a few seconds later. It still has power and if you turn it off then back on it shows the display then it gone again.. any suggestions on what may be causing this problem.. all help appreciated. thanks
  • BenQ Master
  • 12,061 Answers
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps.
Posted on Jul 24, 2007
Why can I not turn my Visionquest monitor back on with the power button?
SOUND LIKE YOUR POWER SUPPLY. OPEN THE SCREEN AND LOOK FOR ANY BLOWED UP CAPS. AND REPLACE WITH SAME
Sep 07, 2012 | Computers & Internet
The monitor startup and few seconds later it turn
You are going to have to open up the monitor, please read below if you are going to DIY.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 21, 2010 | Samsung SyncMaster 216BW Monitor
Soon as ssoon as i turn on the computer the monitor flashes the the logon screen; two seconds later the display is gone. The monitor indicates that it is still on but no picture. I turn the monitor off...
Here the monitor does not have any problem.Initially test monitor by removing the monitor cable from the cpu.
you can see small boxes moving in the screen this ensures your monitor is ok
Here he problem is with Ram in the cpu .Just remove the ram and clean the ram slot and ram and then fix it tt will work fine
May 21, 2010 | Computers & Internet
Monitor starts, about three minutes no picture but
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | Proview PL926WBi 19" LCD Monitor
Dell OptiPlex GX260 PC Desktop keeps switching its self on, can any one help, i click start - go to turn off computer - then turn off, the pc then shuts down, then a couple of hours later i hear the fans...
Have you gone into the BIOS to make sure there aren't any power managment features? Do you get the same thing happening if plugged into a different wall socket? Sometimes bad power surges can cause this problem. Other issues have been known to arise from motherboard problems. Or NIC power settings...strangely enough...a quick way to test if it's NIC related might be too unplug any cables from the NIC to see if it stays on or not? There are power settings on NICs in advanced settings. Let me know if any of that helps and remember to rate the solutions. Thanks!
Mar 31, 2009 | Dell OptiPlex GX260 PC Desktop
HP desktop monitor problem
hi try this ,,,
  1. Ensure the video cable is connected (and connected to the correct video port).
  2. Turn off the monitor using the monitor's power button and then restart the monitor.
  3. Cycle the power on the monitor as follows:
  4. Turn off the monitor. The power light on the monitor should be off. Leave the computer turned on.
  5. Unplug the power cord.
  6. Wait 5 seconds.
  7. Plug in the power cord.
  8. Press the power button on the monitor to turn on the monitor. One of two things happens:
    1. The image from the computer displays on the monitor and you can use the computer again. This indicates that the monitor was unable to detect that the computer had awakened from suspend mode. Turn the monitor off when it is not being used or disable suspend mode. For some computers, updating the BIOS corrects these types of suspend problems.
    2. The power light on the monitor comes on but the screen displays one of the messages again. The monitor is not receiving a video signal from the computer that it can detect and use. Continue using these steps to adjust the Windows display resolution to the Monitor's native (default) resolution
    3. Connect the monitor to another computer that you know is working to determine if the monitor should be serviced or replaced:
      • If the monitor displays an image from another computer, you know that the monitor works. Troubleshoot the video connection and graphics adapter on the computer.
      • If the monitor remain blank when connected to another computer, the monitor signal processing hardware may be bad. The monitor should be repaired or replaced.
      hope it will work for u .. little_angel
Apr 30, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Monitor is on when computer boots up , then turns off
You can email rhartze@key-services.com and provide your telephone number... he will call you to assist.
Dec 13, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
RE:monitor goes black
Monitor going black after a few seconds can be causd by a faulty power supply or inverter. Some monitors have both as one unit.
Sometimes it is basic failed capacitors, After that then I would look at transistors.
The average monitor from 17 to 20 and sometimes the 22s have usually 4 bulbs in them. One bad bulb will also cause the inverter to not fire up.
Bad bulbs usually show pinkish tint, or flickering or are dark at center top or bottom of the display.
ebays bammbammfran
Sep 21, 2007 | Acer AL2017 20" LCD Monitor
Computers & Internet Logo
Top BenQ Computers & Internet Experts
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
