Epson stylus NX625 printer keeps going offline, sometimes goes back to ready than goes offline again
Sometimes turning printer off and on works to bring it back online
dominusnex
  • 15 Answers
SOURCE: HP Photosmart C6180 goes Offline in Vista
Solution A:
Download and install this Critical Update for your printer directly from HP.
Solution B:
There have been cases where if the PC is turned off or goes into hibernate this can occur. To work around this issue the "HP CUE DeviceDescovery Service" must be disabled:
1) Click on the "Start Menu" icon on the bottom left corner of the screen, type "services.msc" in the "Start Search" edit box, and hit enter. This will trigger Vista to pop-up a "User Account Control" dialog to prompt for permission to continue. Click "Continue" to allow Vista to open the Services management console application.
2) The Services management console application is made up of 2 panels. The right panel contains a list of all services available on the system. Scroll thru this list and look for a service called "HP CUE DeviceDiscovery Service".
3) Right-click on "HP CUE DeviceDiscovery Service" and select "Properties" to open the "HP CUE DeviceDiscovery Service Properties" dialog.
4) From the "HP CUE DeviceDiscovery Service Properties" dialog, click on the "General" tab. If the "Service status" shows that the service has started, click on the "Stop" button to force the service to stop.
5) Change the "Start type" to "Disabled" and click on the "OK" button on the bottom of the dialog to apply the changes.
Solution C:
1. Set the printer to a static IP address
2. Logon to the machine as the administrator or with admin rights.
3. Remove/Reinstall the printer using the IP address
Posted on Dec 14, 2008
  • 3 Answers
SOURCE: printer online then offline
My first solotution was to reinstall the printer as a new printer. But that is uncessary. The fix is as easy as changing the IP address the in Port.
The problem is the the IP address for your wirelss is not static. and when it changes, the printer does not recognize the new IP address. When this occurs. go the the printer folder ( in the control panel) and click on 'add new priter'. Then select 'add a network wirless printer . NO NEED TO INSTALL THE PRINTER...you just want to see the IP address.
Note the IP address.
GO to the printer, click on the right mouse and select 'properties'
Click on Port
You will see the current port already highlighted.
Click on ' configure port' and change the IP address under "printer name or IP address.
Click OK.
Problem solved
Good luck.
DeniseA
Posted on Mar 21, 2009
SOURCE: Once my Deskjet F380 goes Offline (which it does
Unplug the USB connection in the back of the printer.
Then go to Start. In the "Start Search" box type "services.msc. Hit Enter.
The Services window appear.
Scroll down to "Print Spooler". Right click and select "Restart".
After a few seconds reconnect the USB cable.
You can also access the Services box by going to Control Panel>Administrative Tools>Services.
You may require administrative rights to do this
Hope that helps
Posted on Apr 10, 2009
seanpwright
  • 2030 Answers
SOURCE: Epson Stylus TX100 printer Woeks but scanner not
It is a scanner as well, but you have to access the scanner through the software that came with it
Posted on Aug 27, 2009
cns assoc
  • 677 Answers
SOURCE: Epson Stylus PHOTO RX500 - PRINTER ERROR message
keep pressing the button, until it stops where you want.
good luck
Posted on Mar 23, 2010
Printer offline
try to go in and mark the printer as online and the printer should come up as in ready state
Mar 16, 2014 | Epson NX625 AllInOne InkJet Printer
Message error queue says printer is offline
Try turning it off, pausing for a minute, and turning it back on again
Jan 08, 2013 | Epson stylus nx110 All-In-One InkJet...
Printer is offline
Hi, turn it's power on. be sure the usb/data cable is connected to the cpu, if still not, remove the printer's adapter and connect it again, power it up again. if not still online, restart your pc.
When you want to print a document, you choose print and select your favorite printer but nothing happens. You look at the printer menu and see the pesky printer offline message and instant frustration. The task of the moment is going from offline to online. With creativity and patience, you'll have your printer back online in no time.
Instructions
Attempt to set the printer to online. This may not often work but it's the first action to take. Go to "Settings" and then "Printers". Right click on the "Printer" and select "Use Printer Online". Test the printer to see if it now prints.
Clear any print jobs. Double click on the "Printer" after performing the above step. Go to the "Printer Menu" and select "Cancel All Documents". There could have been a stuck print job that would cause the printer to go offline. Try once again to set the printer back online and try printing a test page.
Turn on the printer. Make sure the printer is turned on and turn it off, wait a minute and then turn it on again. Check to see if the is jammed. Check all the network connections to make sure none are loose. Repeat the above steps again if necessary.
Restart the computer. If this doesn't work, you will have to reinstall the drivers. Go to "Settings" then "Printers" and select the printer. Right click on the printer and choose "Properties". Under the "General" or "Details Tab" look for the driver button and select it and choose the driver again. You may also have to download the driver from the printer manufacturer website.
Reinstall the printer. Under "Printers" in the "Settings" menu, go back and select the printer, then delete the printer and reinstall the printer through the add printer wizard. Use the latest printer driver from the printer manufacturer's website.
Hope it helps.
Thanks for using fixya.......
Dec 06, 2010 | Epson Stylus NX100 InkJet Printer
good luck
Mar 21, 2010 | Epson Stylus Photo RX500 Printer
Long Lag between Print and Printing (sometimes)
Hi ,
Please perform this below trouble shooting steps:
1.Check whether printer icon is in Online or Offiline If it is Offline right click on it and select Use printer Online. then try to print your issue should resolve.
2. On computer Click on Start >> Run >> type cmd >> then press enter black window appears.
now type as below
net stop spooler
net start spooler
now try to print.
if issue still there perform next step
3 Right click on the printer Click on Properties >> Advanced >> Select Print Directly to the printer your issue should resolve.
Feb 18, 2009 | Epson Stylus Photo R300 InkJet Printer
Epson 2200 going back and forth forever
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | Epson Stylus 2200 InkJet Photo Printer
Paper out indicator
I do know what's going either, but to get around this I have to keep paper in the loaded position. So turn the printer off, put a letter size sheet of paper in (as though getting ready to print), turn printer on again, and now the printer gives the "press pause" msg, press it, the paper will load up, and then the printer reads again, "Ready".
The printer just seems to want paper in it or else it won't read "Ready".
Nov 13, 2007 | Epson Stylus Pro 9600 InkJet Printer
Epson stylus c86 series-paused
Go to your printers/faxes folder and right click on your printer and see if it's offline or similair. If no joy, right click on it and uninstall printer. Re-start your PC and let Windows find it again, but make sure the manufacturers driver automatically installs and not a Windows generic driver.
Dec 01, 2006 | Epson Stylus C86 InkJet Printer
94 people viewed this question
jasbo
jasbo
