Question about OCE Office Equipment & Supplies
What causes Im3511 black line across copy - OCE Office Equipment & Supplies
  • 134 Answers
SOURCE: BLACK LINE ACROSS THE COPY CANON IMAGE 2200
Most likely your drum unit is worn out. If it reaches the yield of 50k or more, it starts to develop grooves in the drum and toner gets stuck in the groove and is applied to your pages. If you have a service company, they can change it for you. We sell the drum for $220.
Posted on Jun 30, 2008
Cogz
  • 1326 Answers
SOURCE: black lines across copies
Question dose it only show up when using the adf/ doc. feeder? Also, dose it show up on both the copy board glass and adf? If it is just the adf, you need to clean the adf slip glass. The small piece of glass next to the copy board glass. If that is not the fix, it could be the Drum Unit or the Fixing unit..
Posted on Aug 20, 2008
SOURCE: Sharp AR-207 copier puts .5 inch black line across entire bottom of copy
does the line only show up when making copies from the adf or both when you put it on the glass. if only when thru the adf the **** glass is dirty. that is the glass that is only about an inch wide. be carefull of the two pieces of tape that are on both the front and back of that glass they fall off easly.
Posted on Nov 12, 2008
SOURCE: Black line across page when printing or copying
Did you try wiping clean the glass? also wipe the strip by the scanner glass?
Posted on Jan 09, 2009
leroyal
  • 2120 Answers
SOURCE: I get a black line across document copy when using top feeder
Open the document feeder and clean the scanner glass
Posted on Feb 21, 2009
Replacement ink
clean touch point of cartridge both side
Mar 31, 2014 | Pitney Bowes IMAGISTICS OCE IM3511,IM4511...
Thin vertical line on copies
Tara, if the ink levels are ok, try clean and allignment functions from the tool menu. Use CLEAN UNUSED PAPER.
Mar 24, 2014 | Canon PC-940 Black and White Copier
The transfer assembly is causing a black line across top of image
Have you done any of the PM kit recently? Has the OPC & fixing unit been replaced recently???? They could be causing lines on copies, there are roller inside the transfer belt that may have toner build up on them...
Jun 06, 2012 | Sharp - AR-M550N copier - ARM550N
Black line on copies when automatic feeder is used
The problem is most likely cause by ink, correction fluid or lint blocking the scanner pickup. Check out the tip we have posted here that should get you back going again.
http://www.fixya.com/support/r3639811-black_lines_faxes_or_copies
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Apr 03, 2010 | HP Officejet 5780 Printer
Imagistics im3511 copy problems
There are several things that can cause this. The easiest thing that you can fix is to make sure the presuure is on in the fuser. Open the left side door. The fuser is the hot part at the top.right. There are two tabs, one at the fron and one at the back. Make sure these are LOOSE. If they are locked down it removes pressure from the fuser and it will smear the copies. The other things that can cause this are drum wear, bad or worn developer, etc, but those need a technician to change.
Dec 08, 2009 | OCE Office Equipment & Supplies
When printing dark line down copy
A line down the copy can come from a dirty document scanner lens.
Usually white out or wet ink will smudge on the document scanner. Opening the document cover check the scanner for a dirty glass. Some document feeders have the white roller on top of the small glass window. They have delicate plastice retainers that hold the roller on both ends. Extra care needs to be taken if this roller is removed.
Clean the roller and the glass with wet towel. Shine a flashlight on the glass to see if there are anymore black marks on it.
Use the finger-nail to run across the glass and make sure no debris is on it. Even a spot can make a line on the copy.
Also, a bad fuser roll can cause a black line on the copy. A defective drum unit can cause a line on the copy as well.
If all else fails place a Xerox service call for this problem.
Oct 22, 2009 | Samsung Office Equipment & Supplies
Printer is printing black lines across all print jobs
Every print job, copy, and fax have the solid black line across the pages. I have changed the drum and the cartridge and even tried cleaning mode. Please help!!! I have a HP Laser Jet 2840 All in One
Mar 24, 2009 | Office Equipment & Supplies
I have a dark line across copies
Whats the make and model of the copier?
One culprit might be the drum.  If you can take a look at the drum from your copier and you see black lines on it.  It could be scratches on the drum or it may need a new cleaning blade to clean the toner off the drum.
Nov 11, 2008 | Office Equipment & Supplies
Oct 18, 2008 | Sharp AR-207 Copier
44 people viewed this question
Top OCE Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
fares
Level 1 Expert
Are you an OCE Office Equipment and Supply Expert? Answer questions, earn points and help others
