Question about Maytag Washing Machines
Maytag washer series 4000 f32 error code
Got a f32 error on my machine
  • 1122 Answers
SOURCE: washer machine maytag neptune front load
take the back panel off,see if the belt has broke if not,check your motor control board for burn spots ,front bottom right inside washer,if not that then your motor has gotten weak and will not turn the drum,let me knoe what you find-mike
Posted on Jul 12, 2008
SolutionGuy
  • 331 Answers
SOURCE: LD error code appears on maytag nepune washer
Roz,
You have some kinda something stuck in your drain pump. The computer that controls your washer has detected that it's taking too long to pump out and therefore refuses to spin.
Now this will take alot of work, but it'll save you a couple hundred, OK? First you have to get as much water out of the washer as possible. Fortunately on the Maytags you can do this fairly easily. Use a garden hose and connect it to the end of the drain hose (from the washer)... use duct tape to secure it. Then run the garden hose outside and make sure it's downhill. Now take the corrugated drain from your washer and lower it below the base of the washer. This will drain it completely.
After the water has drained, pull the washer away from the wall... enough for working space. AND DON'T FORGET TO UNPLUG IT! Remove the rear panel (4 screws) and you'll see a big pulley in front of you.To the lower left, you'll see the drain pump. It's mounted to the base of the cabinet. Use a 5/16" to remove the hose clamps then remove the hoses. Then remove the wires that feed the pump. When that is done, you should have the pump in your hand.
Now that you have the pump in hand you'll see the pump housing (it's white). There are three screws holding the pump housing to the motor. Remove them and separate the 2 parts.Now you'll see the cause of the problem. Some trash got pulled into it. Probably a rug bottom or a dog bed....
Remove the stuff and rebuild the unit in reverse order and you're good to go.
Don't forget to rate my solution!
SG
Posted on Apr 10, 2009
  • 6 Answers
SOURCE: F32 - Kenmore Elite Front Loader Washing Machine
These codes means that the CCU and the CMU are not talking to each other. have you moved lately or some how disrupted the connections from these modules? I don't believe your modules are bad but you'll need to have a technician check and re-secure the connections to your modules and this should solve your problem.
Posted on Jan 19, 2010
livewire874
  • 618 Answers
SOURCE: maytag 3000 series washer f70 error code only the
If you unplug the M13 connection from the ccu (main control) and the error goes away then replace the MCU (motor control unit) if it does not go away then replace the CCU
Posted on Nov 20, 2010
richroth
  • 9472 Answers
SOURCE: My maytag clothes washer Bravo quiet series 300,
What does the Sd code mean?
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Use only HE High Efficiency detergent for BravosTM washers.
Is "Sd" displayed and the wash cycle dial is flashing?
This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent.
Is "Sd" displayed and the wash cycle dial is not flashing?
If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds.
Is the drain hose kinked or clogged?
Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start/Pause.
NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
Posted on Dec 27, 2010
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
I have F32 in maytag 4000 series??
I seem to recall that this is a fault for the pressure sensor. Check your pressure hose by taking it off of the pressure sensor and blowing into it and making sure it's not clogged. If it's clear, change the pressure sensor along with the hose (just in case the hose has a small hole in it somewhere along the tube). That should do it.
Oct 23, 2014 | Maytag Washing Machines
I have the maytag series 4000 and got the f2 code. I have cleaned the.hoses and wven replaced the drain pump. Is thete a rest button? It is still not working and.shows the same code
F2 code is water level to high
Washer Error Codes
Below is a list of washer error codes for HE & conventional top load washers and front load washers. As more error codes are found or published, we will add to the list. Right now you will find error codes for Asko, Fisher & Paykel, Frigidaire, GE, Kenmore, LG, Maytag, Samsung, and Whirlpool. This list might not be complete and should be used for reference only.
Asko Washer Error Codes
• F1--Water supply/low water fill.
o 1. Check water supply to machine.
o 2. Replace water inlet valve.
• F2--Water level too high.
o 1. Plugged/Bad water pump.
o 2. Faulty water valve.
Sep 19, 2014 | Washing Machines
Error Code F24 Maytag 4000 Series Front Load Washer
This video will show you how to open your Maytag 4000 series washing machine door that is stuck shut
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 04, 2013 | Washing Machines
Maytag 4000 get a f71 error code
Is this for real! My 2 year old Maytag 4000 series washer that I paid over $600 for needs a new $300 + part to fix it! It's so pathetic how things are made these days.
Jun 08, 2012 | Maytag Washing Machines
What is a F32 error code on a maytag 3000 series
Error Code F3 E2 is a temp system error. This error is displayed if the water temperature sensor value is out of range (23°F to 217°F [-5°C to 103°C]). Correct ohm reading should be 500-100K ?.
Jan 28, 2012 | Maytag Washing Machines
There is an error code comming up it is f32
The F32 error code is a pressure switch failure error code, this error could be caused by several different reasons.
More than likely the pressure switch has malfunctioned. Be sure you are using H.E.(high efficiency)detergent. Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains you will need to call for service. This type of repair will require accessing the inside of the cabinet area to make some checks. This will require a service technician to diagnose & repair.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
227 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
