Question about McCulloch 13HP 338 Cc Portable Generator # FG6000MK
Engine quit 54generator mcculloch 13hp 5700 watt generator model number FG6000MK SERIAL NUMBER JF182FPH0508040729 ENGINE CHANGED SOUND FOR A MINUTE AND QUIT. COIL SEAMES TO BE SHORTED OUT. WILL A HONDA COIL WORK ON THIS ENGINE? TRIED TO REPLY TO YOUR E-MAIL QUESTION. JOEL KING
  • Thomas F. Schneider May 11, 2010
    I believe No to the Honda coil question.
mamicheddy
  • 79 Answers
SOURCE: McCulloch fg6000mk: generator motor runs, no power.
You need to trace out the power wires the come out of the genset. They will end up on a breaker. With a volt meter measure both sides of the breaker. If one side has voltage and the other side doesn't, then your breaker is opened. Press the breaker in closed to see if it actually closes. If it don't then you will need a breaker. However, if no voltage is being produced, it is possible that the voltage regulator let go.
Posted on May 09, 2009
mamicheddy
  • 79 Answers
SOURCE: mcculloch generator 5700W 11 hp
Sounds like your choke is not closed correctly when you first start the genset. Remove the air filter and look at the throttle plate. It should be closed with a hair line gap. With your finger you should feel very little play on the throttle plate. As you open the choke, you should be able to open it all the way once the engine has reached a hotter temperature. If the engine is still cold and your opening the choke all the way, it will try to die out.
  • 23 Answers
SOURCE: shorted out generator??
they do smoke if its petrol lol joke sounds like a short circuit check the connections
Posted on Jun 08, 2009
  • 142 Answers
SOURCE: McCulloch Generator model FG6000mk 11hp run good
I did not understand how you turn on generator, as it is always turned on.
If you use the ON/OFF switch it is stopping the prime mover.
If you reset the AC breaker without load, and it stops - it means that you have short circuit after the breaker. Check the output receptacles.
Try this link:
http://weborder.husqvarna.com/order_static/doc/MOUS/MOUS2008/MOUS2008-FG6000MK-7096FG6024-966991401.pdf
Posted on Jun 14, 2010
  • 4345 Answers
SOURCE: I have a Mcculloch 5700
Take the make and model #s to a lawnmower shop, they can get what you need, if they do not have it in stock. Also remember to check in tank strainer for restriction.
Posted on Mar 04, 2011
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
What spark plug does a mc collough 5700 11 hp generator take?
The manuacturers part number is: 030506Q01F910
Manual:
http://www.mccullochpower.com/ddoc/MCCO/MCCO2008_USen/MCCO2008_USen_FG6000MK-7096FG6024_966991401.pdf
Is there a brand.... on your current spark plug?
Most generators will do just fine with an NGK BPR5ES spark plug in most any environment.
Thanks for choosing FixYa,
Kelly
Aug 23, 2011 | McCulloch 13HP 338 Cc Portable Generator #...
I need a spark plug for a 5700 watt 11 hp generator, which one do I need?
Hi and welcome to FixYa. I am Kelly.
The standard plug is an NGK "BPR5ES" or Denso "W16EPR-U" There are a number of alternate plugs out there if you use the number above in a cross reference book.
One thing to note... the generator has a "Low Oil" sensor and if the oil level is low you will not see any spark. If after you install a new plug and you still do not have spark... un-hook one wire from the low oil level sensor and check spark again. If you unhook the sensor wire knowing full well the oil level is full.and have spark; the sensor is either dirty or bad.
Kelly
Feb 19, 2011 | McCulloch 13HP 338 Cc Portable Generator #...
My 5700 watt 11 HP McCullough generator wont start. I'm getting good gas to the plug but no spark.
The spark coil is bad if you have no spark
Small engine repair. Part is expensive.
Have you checked spark for sure?
1) Spray WD-40 directly into carburetor
If machine has spark, it will fire
2) Is exhaust port clogged with carbon and dirt?
3) Get new spark plug
Pull out old spark plug
Put spark wire on plug
Hold spark plug wire with fingers
Put spark plug threads against metal opening where spark plug came out.
Metal to metal
Pull cord or push starter
Look for spark between metal
No spark, then spark coil is bad.
Oct 25, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
Spring on recoil starter broke after using generator third time. now mcculloch says recoil starter is not available.have to purchase entire starter housing assembly for $105.00
Generic version of your starter is most likely available from small engine shop. Look for model and type of engine itself. Briggs stratton, honda, etc. model number if engine is usually on starter cover or stamped on block or tag attached. If the recoil part is riveted to housing you may need to either re-rivet or use screws to attach new rewind. Used parts are also available at small engine shops. Just take in the starter housing only for match-up. Good luck
Sep 13, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
I have 5700 Mcculloch generator and when I open the fuel line it starts leaking from a hard black rubber next to the carburator
remove the filter and look down the tube if the carb is filling with fuel then the float needs adjustment or replaced from sinking the tube if it is the one that attaches to the side of a plate on the engine block then replace the oil do to your filling the case with gas this ia is vent tube that attaches from the plate to the carb just under the filter you may have to rebuild the carb about $20.00 for the kit and $6.00 for a float. hope this helps
Aug 21, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
My fg6000mk 11 horse had valve break and ruined the head. where do i get parts
I am pretty sure that is a Honday 11 Hp engine. The part number for the head is
030730Q01F000 (CYLINDER HEAD ASSEMBLY)
Most lawn mower parts supply places can have your part in hand in a couple of days. I was not able to find a price for the head but I know they are not cheap.
When you call or visit the lawn mower parts store make sure you have the engine model number with you. They amy even ask for a serial number. The numbers are near the oil drain plug toward the bottom of the crankcase but under the starter.
Let your fingers do the walking on the phone first... you could drive about for sometime before finding the shop that can help you. (i.e yellow pages Lawn mower repair)
Thanks for using FixYa!
Kelly
Feb 19, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
McCulloch 5700, 11 HP Starts easy with 2 pulls and begins running fine. Then it start dying and back fires,revs up and down, back fires. Then will run normal for a few minutes and will start revving up...
Sounds like you may have a wire shorting out. Check all ign wires and make sure one hasnt rubbed through. Maybe take off your front cover and make sure something isnt shorting out your coil contacts. Hope this helps
Nov 02, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
Shorted out generator??
Jun 08, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
Mcculloch generator 5700W 11 hp
Feb 09, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
McCulloch 13HP 338 Cc Portable Generator # FG6000MK Logo
140 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
