Question about Bose Lifestyle V35 Theater System
Bose keeps shutting down
My music system works quite well, then suddenly shuts down and won't allow me to reboot. The light on the console flashes green for a while as it tries to restart, then goes orange
SOURCE: Bose Lifestyle 8 no display
I had the same problem and Mark Burgess at http://forum.ecoustics.com/bbs/messages/1/125990.htm helped me out, change the 4 capacitors in the lower board, lower left side and that will solve the issue.
regards
-Luis Carballo
Posted on Jan 15, 2008
otacon
  • 1944 Answers
SOURCE: Bose system (Lifestyle 50)
Did you try leaving it unplugged for a few hours?
Posted on Feb 24, 2008
SOURCE: system keeps shutting down
Hi, I have not been able to fix the problem myself !! : ( I am taking it to the place I bought it from as I am still under warranty. Will let you know what they come up with when I get it back. Regards jessiedog
Posted on Jul 08, 2008
taran_2005
  • 10515 Answers
SOURCE: I have a bose lifestyle
I realize you stated that you had everything disconnected and then reconnected it, but everytime I see this same issue- it's typically resolved by unplugging power to the main Bose unit for 60 minutes which resets the microprocessor.
This is a common problem on this set. If this would not resolve the problem, this is an internal problem and needs repair. Be advised that repair of this set needs a tech to have the complete knowledge of Bose products and would need to have an access to the service manual. Do not ever try to get the set repaired from local shops as they tend to make the situation more worse.Either contact Bose or repair center which knows about the same such as :-
http://www.myboserepair.com/
In the past, Bose does repair the units for flat $99.00, so worth calling and checking the same with Bose.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Mar 03, 2011
damneddle
  • 1607 Answers
SOURCE: I'm trying to connect a
Hello.
What is the other audio system you are trying to connect to your V35 system? You can only connect Bose Link compatible products (Bose systems) to the Bose Link OUT connector.
Posted on Aug 04, 2011
IMac G5 17" won't shut down
I have minor shutdown problem with mail, won't close or shut down. My ans top left APPLE drop down, force closure, turn of each programme listed. For me works a treat.
Jan 19, 2013 | Apple Computers & Internet
Quite suddenly it doesn't play. The ipod registers that it's charging, and I've checked the remote control on another Bose system I have and it seems to be ok.
I just had the same problem with mine - turns out the Bose docking stations are comlete and utter **** and if yours keeps working you're one of the lucky few. Mine only had sparodic use over a 3 month period and it stopped producing sound the other day. I took it to a repair shop and they've seen a lot of them with the same problem. The solution - dump it in the bin and get a logitec set of speakers & you'll have better sound. This was proven by attaching the iPod to each system.
Apr 14, 2011 | Bose SoundDock digital music system...
Conputer is shutting down but it does not shut down
Hold the power button until the computer shuts down.
Restart and press F8 key repeatedly until you get a start up menu.
Select safe mode from the menu.
After the computer boots up, and you are at the desktop, go to my computer and select properties of the C drive (your system drive). Select tools from the tabs, then defrag. When defrag finishes, select check drive for errors and select the box, to automatically fix errors, and then ok, and yes at next window, allowing the computer to schedule the error check at next boot.
Reboot and allow computer to scan the drive.
After it finishes, you will continue into windows. Allow windows to boot. After it finishes, attempt to shut down again.
If it works, you fixed it. If not, you have a driver or program that will not quit, and you will have to research further to find out what is running and why it won't quit.
Dec 16, 2010 | Acer Aspire 5735 Notebook
Turns off automaticly
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Sep 27, 2010 | Nintendo GameCube Console
    Bose Wave Music System - CD Says "Not Playable"
    I turned mine upside down pressed play and it started working.
    Turned it back over and it's working fine.
    Dec 22, 2008 | Bose & Wave& Music System
    Power Button Flashing Red
    Try unplugging the entire unit and letting it sit for 5 minutes. See if this helps. If not, you need to do a complete reboot, which will cause you to lose your settings, but will probably solve your problem. To do a complete reboot, you will need to hold down two of the front bottons on the front panel. I'm not sure which, so either consult your manual or see other posts here which describe the reboot process for Denons. Hope this helps.
    Dec 14, 2008 | Denon AVR-1908
    Power button failure
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    regards
    -Luis Carballo
    Nov 20, 2007 | Bose Lifestyle 8 series II System
    Bose Lifestyle V35 Theater System Logo
    55 people viewed this question
    Top Bose Audio Players & Recorders Experts
    Invebo
    Level 1 Expert
    Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
