Question about Kenmore 84052 Dryer
I have a Kenmore dryer model #84052/94052 the LED lights on the front panel (more dry, normal, less dry, damp) no longer light up. we click the start button and it sounds like it will start but then doesn't...please your expertise...thank you!
BerkelUSA
  • 24 Answers
SOURCE: Kenmore Elite HE3
Try this.. across the top rear of the dryer there is 3 gold screws (1/4" I believe) remove them and pull the top panel back about 6" inches then get a hair-dryer.. when standing back in the front of the machine there is now a black strip of sheetmetal you can now see that is right behind the control panel your pressing all the time.. there is a small gap about 1/2" between the black metal strip and the control panel that allows you to see a few green PC boards from the back side.. put the hair-dryer on high and work it back and forth in that slot pointing it at these boards... this will dry out the moisture back there on the boards and in the buttons themselves.. Give it a few minutes.. the beeping sounds like your timer indicator buzzer button is stuck ON so be sure to dry off the right area where those buttons are also.. once the beeping stops it should work.. Mine has done this 3 times and the hair-dryer has fixed it every time.. What's going on is because the buttons have been pressed so many times they have almost collapsed together and only a little moisture allows them to stick ON.. once the timer button does this you cant start ANY mode until it is cleared.. kinda like holding the channel button down on your remote to the TV and not being able to do anything else until you get it to stop...
Posted on May 19, 2008
  • 686 Answers
SOURCE: Kenmore Elite dryer heats but does not dry
Make sure that your vent tube is not kinked or crushed behind the dryer and it all this is ok then you need to change your cycling thermostat. is it gas or electric
Posted on Mar 12, 2009
  • 2699 Answers
SOURCE: Kenmore electric dryer, won't start and clicks by time dry knob
usually the thermal fuse goes and dryer dies part number 3390719 located in front of dryer on top of the blower wheel housing,when you read anything out you have to pull one of the wires off to get correct reading.also on some of the dryers there is a switch on the pulley that will kill the dryer if the belt breaks
Posted on Nov 06, 2009
  • 410 Answers
SOURCE: Kenmore dryer model 110 63032101.
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the dryer ID doesn't mean
anything to me. Over the years, I haven't had much trouble with my dryers. However I can suggest you go to www.applianceaid.com where they have very good trouble shooting and repair information on dryers and other appliances. I think you'll find what you need there. If you have an error code you can probably find the meaning of it there. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Nov 26, 2009
SOURCE: Kenmore dryer model no. 110.85087400 won't start
hello
i have a kenmore model 110.85087400 that will not heat up i just replaced the heating element and still have the same issue.what do you think it can be...when i open it to replace the element i notice some lint that was burnt...help please.miguel
Posted on Aug 07, 2010
I have a Kenmore Elite dryer. It has the electronic display on the right, dial in center. What I am trying to figure out is, when I turn the dryer on, the light at the top says 'cooling'...
wow did they see you as a sweet sucker . Have had the least expensive models of kenmore for 50 years and none ever didn't dry the clothes dry. I am a non electronic kind of person cause that is just more stuff to go wrong
Jan 25, 2015 | Kenmore Dryers
My kenmore elite #110.73012181 electric dryer with autonsense feature no longer sensing, keeps on drying for hours after clothes dry when on less dry mode or normal dry mode
The drying circuit has to have a sensor to control heat and the timer controls time (on timed drying). Often sensors fail "open" and dryers stop drying. This sensor or the circuit seems to have failed closed (runs all the time). I suspect the sensor has failed in the drying control.
Jan 02, 2014 | Kenmore Dryers
Green clean light is blinking
This machine was made by Whirlpool and the flashing clean light is a common error code for them.
If the clean light is the one flashing then your dishawasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has untill all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
Press the heated dry button followed by the normal cycle button, and then repeat once. You should see all of the lights come on for a second or two, and then the dishwasher will work again.
If you haven't already, take a look under the kick plate in front to see if there is a schematic tucked in there somewhere. Whirlpool has put their diagnostics for specific models on these.
I don't have the specific repair manual for you model.
So, if the above combination does not work here are two more that have worked for me.
HiTemp Wash + Air Dry + HiTemp Wash + Air Dry in less than 5 sec
or
Hi Temp Scrub/Scour + Air Dry + Hi Temp Scrub/Scour + Air Dry in less than 5 sec
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Read the Testimonial by the one of the Customer's who had the same issue :-
http://www.fixya.com/support/t3124974-clean_light_flashes_7_times_time
Dec 30, 2009 | Kenmore Dishwashers
Model # 11061082000 electric dryer....elite kenmore
you can't get any parts for this dryer the computer board is no longer available,must be old technology replace it.
Dec 28, 2017 | Kenmore Elite HE4 Electric Dryer
Dryer not drying
First thing to check is the vent. Make sure you have sufficient air flow to the outside. If you are not sure if you have the proper rate of flow, disconnect the vent from the dryer, turn dryer on and see if burner stays on longer. Do this with a couple of damp, spun-dry towels inside the drum. If the burner short cycles again, you need to replace the coils on top of the burner assembly. These are the two black round coils.
Sep 03, 2009 | Dryers
Kenmore model 66516352301 diswasher flashes Wash but won't start
I had a simular problem with my Kenmore. I unplugged it for an hour or so and it worked for a while. (Disconnect dishwasher from power befer attempting this procedure!) I ended up removing the inner door panel and removing the circuit board. I used a clean damp (distilled water preferred) paper towel and wiped down the entire circuit board surface. I paid special attention to the areas between the closely spaced component leads. I dried the board with a dry paper towel and re-installed the board. The dishwasher has preformed flawlessly for the past 4 months.
I believe that the mist and steam deposites a thin film of very conductive detergent and minerals on the board surfaces over time. The resulting electrical leakage paths "scrambles" the control's "brains".
I also noted that prior to my repair, most of the led cycle indicating lights were very dimly glowing with the room lights out. Also, the wash cycle ran for a much longer time.
Jun 16, 2009 | Kenmore 24 in. 17372 / 17374 / 17379...
Kenmore HE2 Gas Dryer Control Panel Does Not Work Properly
I have the same problem..really disappointed in this product. I bought mine in 07 as well..I found that if i hold all the buttons down and then hit start it (Sometimes starts), but after it starts it turns off after 10 seconds.
Mar 27, 2009 | Kenmore Dryers
Kenmore elite he4 dryer wont run
Hi! crystal2hd
My he3 dryer does not have a door lock. The door switch turns off the light and allows the dryer to start. Make sure this switch is not damaged. Unplug the dryer before removing the front cover.
InMrFixIt
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore HE4 no power to control, no sound, but the drum light bulb on when door opened
Another post reported replacing the power cord. I am trying to determine if this is a factory defect. Check the power at the power cord connections inside the dryer. You could have lost power on one leg and the other 120 volt leg is letting the light work. Let me know what the model and serial number is.
InMrFixIt
Aug 15, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer won't start
It sounds like you do need either the main computer or the the console electronics. Sorry there is no other reset of any type.
Oct 10, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore 84052 Dryer Logo
64 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
