Question about Tascam CC-222mkIII CD Player / Recorder
How can I fix my tape player?
My cassette Tape Player on is not playing Correctly anymore on my Tascam cc-222 .When I go to play something on it the tape plays "speeded up " like Alvin and the Chipmunks
This unit has a variable tape speed adjustment ("pitch control"). Make sure this is set at the middle (neutral) position
Posted on Mar 07, 2009
1990 lexus ls400 cassette player will not read or play my cassetes. i put in my cassettes but my front tape flap doesn't close and it automatically switches back to the radio.
The player has to seize the cassette as it is inserted and seat it in the correct position to be played. Sometimes the manual eject linkage becomes defective or misadjusted, preventing the cassette from seating correctly. The eject button may depress fully without causing ejection or it may depress but not cause ejection.
Dec 03, 2013 | Nakamichi 90 94 Lexus Cassette Tape Radio...
Tascam 122MKIII Cassette player/recorder is malfunctioning.
I have one here at my shop that does the same thing almost. I found a gear broken in the mechanism system. The flashing LEDs tells you that the system control IC can not get the transport where it is suppose to go. The Gear C as described in the manual was the problem in the deck here. The head base was in the up position in this unit and thus would not eject. My E mail is skywavebe@sbcglobal.net. Due to the amount of dis-assembly to get to the transport control section this might be a job for a technician.
Feb 22, 2013 | Tascam Audio Players & Recorders
Tape heads are stuck will not disengage. transport will rew and fast forward but will not play or record. also could not eject tape. unit is a tascam porta one mini studio.
There is a cam system in the transport and they need to be lubricated. It might cost more than $100 to fix. Sometimes the gears have rounded off teeth that you can not get anymore.
Sep 24, 2011 | Tascam 302MKII Single Cassette Deck
Tascam 122 cassette deck the cassette player won't play
There is an idler wheel behind the platen ( black plate behind the cassette)..replace the idler wheel.
The guy in texas is Marrs communications
Mar 18, 2009 | Tascam 122MKIII Single Dual Cassette Deck
Recording Speed
the tascam 414 is a 4 track recording studio which uses standard cassette tapes- meaning they only play in one direction, because the tape is full. The 414 records at double speed so that recording fidelity is increased. When you have made a recording you want to mix you then dub your recording though the outputs into another standard tape recorder or whatever you have available, be it a cd recorder or your PC. So, when you listened to your recording on a standard tape player, you were not only hearing it at half speed but you were only listening to 2 of the 4 tracks. The other tracks would only be heard if you flipped the tape over, and they would be heard running backward. I would have though the 414 had a swich to allow it to also record at standard speed to but I guest it does not.
Jan 10, 2009 | Tascam Starter Pack for 4-Track Cassette...
IT PLAYS TAPES SLOW
can i buy your panasonic rx-dt75. i have that model almost 15 yrs to me made in japan. but this past few months cd and tape do not work... contact me here +639392859269
Jan 06, 2009 | Panasonic Portable Radio/Cassette Player
Cassette tapes
try firmly banging the cassette onto a table top(with reels flat) a few times, then ff right through and rew a couple of times. this will layer the tape more evenly and hopefully allow the mechanism to play it. the takeup reel or autostop mechanism may be failing if the deck does not have enough torque to carry the tape and may require belts replaced or dried grease removed in the transport.
Dec 07, 2007 | Tascam 202MKII Single Dual Cassette Deck
Tape witll not play
your tape player may be jammed up and not playing your cass.
Jul 04, 2007 | Sony Walkman WM-FS593 Personal Cassette...
Tascam CC-222mkIII CD Player / Recorder Logo
198 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
