Question about Car Audio & Video
Radio not playing
We have just installed a K-G396. When we turn the car on the unit turns itself on then straight off. The CDs will load and eject, and the time display is working however the unit will not turn on and play the radio or CD. What's going on?? Thanks! From Lisa.
  • 14 Answers
It sounds like you didn't hook up both your power wires on your cd player. there is a red and yellow power wire. one is constant power to keep memory and the other turns on the radio when the key is turned. check to see if both are hooked up
Posted on Jan 18, 2009
I have a problem with my JVC KD-R600. The radio turns on and then it shuts off the display and it won't do anything else. It takes CDs and it would display that is loading but then it will shut off. If I...
Hi have you solved this problem as I am now experiencing the dame problem after I havnt used the unit for some time now and installed into a different car and I am experiencing the same problem as you have mentioned
May 28, 2010 | JVC KD-R600 Car CD/ MP3 Player
The cd will not eject from the unit
you need to call radio shack or a stereo place to see if they can help if you take the loader out and bring in.
Jan 01, 2010 | 2005 Mercury Mariner
CD player not working correctly
Try turning off the radio and disconnecting the battery for 1 min and then reconnecting the battery. Turn on the radio and see if that reset the radio so you can get your CD out and try cleaning the CD player with a cd player cleaner. Note you have to make sure the radio is off before you disconnect the battery. Good luck and hope this helps
Jul 29, 2009 | 2003 Ford Escape
2007 Subaru Impreza, the 6 CD changer will not play CDs and the display reads "Push Eject", but when I do push eject the cd is not ejected. None of the CDs will eject and none will play.The manual says I...
are there any cd's with homemade labels ,how many cd's are loaded?the dealer will recommend to remove the radio and send out for repair costing you a couple hundo or more depending on the problem if you're out of warranty,you'll also be out a radio until its repaired,if your factory warranty is still in they will just order an exchage unit and call you for install when it arrives. hope this helps,good luck!
Jul 12, 2009 | 2005 Subaru Forester
A disc is in the Bose Wave system and will not play or eject
Unplug the system. Turn the entire unit upside down. The CDs will eject. After I tried this (found it online somewhere), it worked fine for about 2 months. Now it suddenly turns on by itself and ejects CDs (creepy). But at least the original problem was solved.
Apr 05, 2009 | Bose Wave Music System CD Shelf System
Monsoon raido Cd Error
just replaced my 2006 Pontiac G6 GT Monsoon 6 CD changer with an identical model pulled from a totaled car.How do I reprogram it so it works on my car.
Dec 14, 2008 | 2006 Pontiac G6
Failure to play CDs
my dads toyota 4runner was doing the same thing we found it easier to just drop in a new deck from canadian tire
Dec 11, 2008 | 2007 Toyota RAV4
Bose Lifestyle CD not eject
There are some repair instructions available at www.AnyoneCanFixIt.com in the electronics section that will show you how to release the CD magazine and fix the problem where the unit will not play the CDs (you will hear a buzzing, buzzing, buzzing, and nothing will load or play).
Oct 11, 2008 | Bose Lifestyle 20 Shelf System
Car Audio & Video Logo
74 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
