Question about Hampton Bay 54 In. Flemish Pewter Ceiling Fan with Heater
I need the wiring diagram
I need to know which wires supply power to the fan and which ones supply power to the light in the remote control receiver UC7058R Hamptom Bay
Buffalo12980
  • 625 Answers
SOURCE: Installing ceiling fan with two switches AND a remote
in your ceiling box should be three wires. a red goes to the three way switches, a black goes to the hot and the white is the neutral. the fan wires are black, blue and white. since you have a remote, connect the [fan] blue & black together with the [line] black. connect all white wires together. the remote will now ramp up your lights from off to full on and the fan remote will let you choose lo med high and off. just tape up the red wire in the box.
Posted on Aug 22, 2007
SOURCE: Hampton Bay Classic Collection 52" remote ceiling light/fan
rechecked wiring, but blue with blue, white with white, etc., now lights work with remote,but fan only works with wall switch - so why doesn't fan work with remote,if lights work the remote & receiver must be ok?
Posted on Jun 04, 2008
  • 726 Answers
SOURCE: hampton Bay fan wiring
this is everything u need to no
'http://www.ceiling-fans-n-more.com/ceiling-fan-wiring.php
it has all the colors and a diagram for you
Posted on Sep 29, 2008
  • 37 Answers
SOURCE: How to wire a remote control ceiling fan, without using remote.
If you don't want the to use the remote you don't have to, but you don't have enough wires to switch the upper light, the lower light, and the fan. You can, however, switch the upper and lower lights together if that's okay. In order to do that you'd connect the white from the ceiling box to the white (neutral) on the fan, then the green from the ceiling box to any green(ground) wires on the fan, then the black from the ceiling box to the black(motor) from the fan, then the red from the ceiling box to the blue and orange (lights) from the fan. I'm assuming that the black and red in the ceiling box are also in the switch box where the fan/light control switch is going. Those are the ones you'll connect to the controller.
Posted on Jan 27, 2009
moel64
  • 18 Answers
SOURCE: Need instructions to fix ceiling fan - Hampton Bay 55295 + remote
if you tell me what colors of the wires you have on the fan y what colors of the wires on the ceiling may be can help you here is my E-mail: mhernandez781@hotmail.com.
have nice day
Posted on Jul 15, 2009
Lights come on at random .has a remote how to fix ?
The fan remote control receiver used in the Hunter 25730 model fan (see picture) is not available from Hunter. Remove the fan from the ceiling. Remove the receiver and take it to recycling. It can be replaced using a readily available and inexpensive replacement universal remote and receiver controller. There are limitations though. The Hunter receiver provided fan reversing functions. The universal controllers do not. You therefore have two options.
Option 1: The universal receiver can be installed such that the fan direction is fixed, either up or down, all other functions operate normally.
Option 2: A reversing switch can be purchased from Radio Shack for about $4 and installed in the fan. This does require cutting a square hole and drilling two bolt or rivet holes in the side of the cylindrical housing which previously housed the Hunter receiver. I'd suggest the Radio Shack DPDT slide switch part number 275-403.
Refer to the wiring diagrams and connector pinout diagram for connections. Please note that the connector pinout diagram is the connector that is soldered to the circuit board as shown in the photo of the Hunter receiver. If your motor wire colors are different then with the connector unplugged from the receiver use a multimeter to probe all the motor wires in order to identify two pairs of wires that indicate approximately 70 ohms each pair. These will be the motor windings. 6b0a1409-5a20-4efe-a059-c600652e9512.jpg 5da8e4ef-1b54-40d0-a8a4-21d4608b1d23.jpg 9fc8772d-3ac3-41b7-aa55-78ccc6e5ea00.jpg 0759e340-6464-4c4b-90f5-6d9926e74e42.jpg
Jan 23, 2014 | Hunter Ceiling Fan Light Remote Control
Connecting wires
You are just missing one wire to all the circuits. The ones that work are good ... add the one wire that is not hooking up to the others to complete a serial circuit.
Mar 30, 2017 | Hampton Bay AC434-WB 52'' Ponte Vecchio...
We just bought a house that has 3 of the same fans. THey are hunter with remote and no pull cords. The master bedroom fan doesnt work. We tried to rewire it and the only way we could get anything to...
Hi Leanne,
Most fans have green, white, black and blue wires. Green is earth or safety ground, white is neutral, black is for the fan and blue is for the light fixture. Some fans may deviate from these commonly used colors in which case you should consult the instructions. Below are links to instructions for different Hunter remote fans, additional instructions for Hunter remote fans or you can look up your fan by model number or use. It appears that the built-in remote Hunter fans have no provision for controlling a light when the fan is wired from a traditional switch instead of using the included remote, as they have only a green, white and a single black that remains powered constantly to supply the remote receiver. The hand held remote transmitter tells the receiver to switch power to the fan motor and light bulbs as needed.
It is possible that the transmitter or receiver you're using in this room is not working. Try using one of the other remotes with the non-working fan by matching the code of the remote to the fan. If it doesn't work, try selecting a different code on the fan and match it on the remote (in case there's a problem with that particular code in this location). Try all (or as many as you care) codes to see if any codes work with this remote.
By this time, you should have either found a working code with this remote and are all done, or still have a non-working fan. Since you have tried more than one remote - and know that one of them worked in the other room, suspicion falls on a faulty fan or integrated remote receiver. You can replace the fan if you like with a traditional fan and light and purchase an after market or third party RF remote control if you no longer wish to get an integrated remote receiver.
I hope this helps and good luck. Please rate my reply - thanks!
Apr 19, 2011 | Dryers
Need diagram for hunter fan with light kit. Three
Black to black. from fan
Blue to Black and white. from fan
White to white. from fan
The input is from ceiling supply
the black wire from fan is for motor.
the black and white is for the light.
Jan 02, 2010 | Hunter 52" Ceiling Fan With Light And...
Nee to know how to wire a ceiling fan remote to the ceiling box please. Wires coming from box are: black-hot, bare-ground, and white-?. Wires coming from fan remote unit are: black labeled wire to black in...
Try this, connect green wire to bare wire. Connect both black (power) wires to black wire in the box. Connect the blue wire to the button for the lights, and the red wire with the strip to the button for the fan, and the common for the buttons to the white wire.
Oct 03, 2009 | Hunter 52" Ceiling Fan With Light And...
Need a basic diagram to wire a ceiling fan.
Depending on how your place is wired will dictate the solution here.
The light box in your ceiling should have two or three wires. Black and White, or Red, Black and White.
If you have two wires (one switch to control everything):
Black is power - hook this to the fan's power wire (and the fan's light wire if applicable)
White is neutral - hook this to the fan's neutral wire.
If you have three wires (two separate switches):
Red is power for the light - hook this to the fan's light wire if applicable
Black is for the fan - hook this to the fan's motor
Sep 18, 2009 | Hunter 52" Ceiling Fan With Light And...
Hunter Ceiling Fan 25885 remote won't turn off light
I have this fan model. The RED is a common wire. Wire it in with all the white wires. Better yet why don't you just bypass the module for the light. You could buy a more up to date Lutron wall switch W/remote control. The Black wire W/White stripe coming from the module is the light control. Cut & cap this with a wire nut. The same wire coming from the fan motor Connect it to your new wall switch. Now heres the tricky part. You have to run a new (Non switched) hot wire to your fan this will connect to the module normally. This is the new power for the fan. The remote that comes with the fan can serve as the On/Off 1,2 & 3 speeds. You now have two remotes. One for the fan the original and one for the light control w/wall switch. The new Lutron model will give you full dimming capability for incondesent bulbs. It is much less noisy when you are dimming the light down.
Jul 24, 2009 | Hunter 28486 Ceiling Fan
Hampton bay fan with remot problem
You can try the universal receiver. The white, black, and green wires are the house wires. The receiver must match to these on one side. The wires on the other side go to the fan/lights. It is possible that one of these has come loose. If you try the universal, make sure the dip switches are in the same positions on both.
Or,
Take the fan down, and remove the receiver completely, from house wires and fan. (Make sure the breaker is off first!) Then wire the fan directly to the house wires. The blue wire on the fan is for lights. Wire it with the black wire in the same wire nut.
I'm assuming you have a wall switch that powers the wires coming from the ceiling.
By the way, I have never seen anyone control two fans with lights with one receiver. Usually each fan has its on.
Feb 09, 2009 | Hampton Bay 52 In. Ant. Brass Redington...
Hampton Bay ceiling fan remote control
i have a problem with remote ceailing fan and light i tried push on light key - dim light low to high working but fan isnt working hi to low. i checked the supply wire red, white and black so i have a installing receiver and receiver have red receiver wire to black supply wire, white receiver wire to white supply wire , but what i do with red supply wire to QQQQ
Jan 25, 2009 | Universal Remote Control Hampton Bay...
Hampton Bay 54 In. Flemish Pewter Ceiling Fan with Heater Logo
27 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
