Question about Garden
One of the "prongs" broke off my electric Toro leaf blower. The plug is a "defond SA965" male plug. Does anyone know where I can find this part??
5 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: Toro leaf blower has spark but will not start
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
Just let me know if you need further assistance.
Jim
Posted on Jun 21, 2009
  • 211 Answers
SOURCE: toro gas leaf blower erratic engine performance
hi
change the sparkplug or seals.
bye
Posted on Oct 07, 2009
rwvanlue
  • 486 Answers
SOURCE: Toro leaf blower Model 51591 from 2003 has started
Sounds like a piece of wood is caught under/between the impellor and the case/housing. When removing the impellor, you may find it has a left hand threaded nut.
Posted on Nov 13, 2009
  • 10 Answers
SOURCE: Where can I find brushes
True to an extent but not just any brushes, just be sure to find brushes with the same flex wiring connection and then shave away. You'll need to shave them into the original shape for the ends and length as well as the lateral dimensions, so the springs will fit right.
I had to do this for a Shop Vac, took a few weeks to locate some brushes that would work right with the springs and the wire connection once shaved.
The motor unit was all the OEM would sell, and for the price I could get a new unit. :) Don't you just love a disposable design ethic?
Posted on Jun 09, 2010
Who sells a Defond CYCM-1213-A rotary switch for a Toro Garden Blower/ Vacuum
Ebay has listing for Defond switches. Don't know if they carry that specific model number.
May 29, 2015 | Toro Garden
What is a Defond-2113?
Defond is a manufacturer of the Switch
Nov 15, 2014 | Garden
Why will my toro 5198 leaf blower not start?
If you're Toro electric blower is slowing down, throwing sparks, or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Jun 28, 2014 | Toro 51599 Electric Blower 12 Amp
Toro model 51575. Was using it as a vacuum and it just shut off. Checked breakers ...all ok. Plugged it in direct to outlet and still nothing. What might be the problem?
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower Vacuums)
Apr 06, 2014 | Toro Blowers Rake and Vac - Electric...
Snow blower shorted out
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
Feb 17, 2014 | Toro 51599 Electric Blower 12 Amp
Brushes on the motor are bad. where can I buy them
Sounds like the brushes are worn out and in need of replacement, if available.
Nov 04, 2011 | RTO Weed Eater Electric Barracuda 2595...
Problem is my hardly used Toro Blower Vac is getting no Power
If it has not run for awhile, check the brushes. they might need to be replaced. The plug is usually moulded right on power cord. That might have to be replaced because if there is a problem with a broken or disconnected wire right at plug there is no way to see it. Hope this helps.
Dec 07, 2010 | Toro 51599 Electric Blower 12 Amp
Plugged it in and it won't run but it was running fine when I put it away two weeks ago.
Check the plug for loose wire or at blower where wire it enters to make sure the wire was not pulled and disconnected inside. If after looking and it is not a wire, check the brushes on the motor. They could be worn out or not making a good contact. Blow out brush housing and re-install brush sometimes this works. That's about all I can think of unless there is a safety switch then check that. Good luck.
Nov 22, 2010 | Toro Craftsman 225 mph Electric BlowerVac
Nov 13, 2009 | Toro Blowers Rake and Vac - Electric...
Toro blower model 51591 electrical prong melted. help!
The answer is wrong. This model and other Toro blowers with the plug built into the body (as opposed to the new design with plug on cord) has this problem when the plug does not completely mate with the cord. This happened to mine too. Unfortunately Toro does not provide a replacement part. HOwever, perhaps the new designed cord will fit as a replacement, but I am unsure of this. When my plug melts completely I will try that.
Dec 22, 2008 | Toro Blowers Rake and Vac - Electric...
Garden Logo
118 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
