Question about Brother DCP-8060 Laser Printer
Brother DCP 7065 putting 3 black spots on left side of paper
  • 3 Answers
SOURCE: Brother DCP-7020 Drum problems
Open the front of the printer by pulling on both tabs at the finger grips on both sides of the front panel. The front panel will flip down. The drum and toner cartridge comes out as a single unit. It is black plastic within gray plastic and has a handle like grip in the middle. Grasp this grip and pull the unit up and out. It feels kinda funny the first time you do it and you may feel like it will break, but it won't. Pull it up and out in a kinda circular arc. Do not touch the drum. If you ever need to replace the toner cartridge, press on the blue tap and separate the drum from the toner cartridge. You will have to replace the drum after every five toner cartridge replacements so practice doing it now. Note the tabs and slots on the sides before separating the drum and cartridge. Align the cartridge into the drum carriage and slide it in until it clicks. To replace the cartridge assembly into the printer, angle the cartridge at about 45 degrees and rotate in while pushing. It should click into place. If the front door then closes properly, you should have it in properly. Practice a few times and you should be an expert. For paper jams, there are many places to check and they may not all give warnings. First pull out the paper tray and check for and remove misfeeds. Remove the drum cartridge assembly and described here and check for and remove any paper. Open the back cover and check for and remove any paper. Open the automatic feed and check there as well as lifting the cover where the scanning surface is. Look in the rollers for the automatic feed for paper pieces. The last place almost never gives you a warning. Reach into the slot where the paper exits after being printed and grasp the whole top cover. Lift upward and it will open about 4 inches. This is a good place where small pieces of paper or even whole sheets may get stuck. Clean out any dust while you are there.
Posted on Oct 04, 2007
frankzjm
  • 191 Answers
SOURCE: Dots on the left side margin
This problem comes from drum cartridge, you may try:
1) take out drum cartidge open drum cover clean the surface at leftside(using soft brush) and check drum surface at leftside, there is damage if you see the color surface appear a broken-ring at leftside(the color changed), you have to change new drum cartridge,
2) sometimes cause cartidge clean brush dirty can not do well cleaning job, just clean this parts at leftside well then turning drum a little there is no toner appear at surfac leftside if ok.
Posted on Dec 21, 2008
SOURCE: not printing glossy A4 paper / paper jam / no paper feed
dont use thick photo paper like 230 gsm up, instead use 180 gsm papers. but if you dont want to waste the purchased thick photo papers, you can open the back and manually insert the paper once the printing process started. i tried this as a trial & error basis until i had perfected it.... hope it works with yours.
Posted on Aug 17, 2009
n25an
  • 622 Answers
SOURCE: black lines down side of paper on HL-5370 brother laser printer
you have a bad drum... it needs to be replaced
Posted on Dec 27, 2009
  • 1382 Answers
SOURCE: I have a brother DCP-165C and it is not printing black.
The nozzle may be blocked. So take out the colour cartridge and place its nozzle in a bit of water for about 10 mins. Bring it out and dab the nozzle with folded paper. If the tissue is blotted with the three colour it means you have unblocked the nozzle. Try now to print after returning the colour cartridge. You may need to repeat to get good results.
Thank you!!
Posted on Jul 12, 2010
Unable to scan with Brother DCP-7065 DN with Paperport 14
You should first run the Scanner configuration for PaperPort.
Nov 19, 2013 | Brother Office Equipment & Supplies
How to reset toner end message on Brother dcp-7065dn
how to solve toner ended / replace problem on brother DCP 7065
Apr 25, 2012 | Office Equipment & Supplies
How to reffil brother inkjet cartridge printer DCP 165
Trust me, this is the BEST way and the EASIEST way to refill black and color LC61 or LC65 inkjet cartridge from Brother. See the pictures
1. cut the plastic part (see picture). You can use a utility knife or a steak knife (very easy to do)
2. make a hole on the left side (NOT in the midle) and do it straight and don't go deep (see picture)
3. poor the ink with your refill kit and do it straight and don't go deep because the inner side of the cartrigde is made of cheap plastic (like a plastic bag) and you don't want to perforate it
4. put your plug, tape, hot glue or what ever you have to seal the hole.
5. put the cartrigde back in your printer, do a print test and this is it.62663ac.jpg50fb605.jpg
Sep 19, 2009 | Brother DCP 165C Compact Color Inkjet...
DCP 8065DN
please print option paper source setup mp tray and setup page size then solve your problem
mp tray is copier front side open it and insert paper or print source lower casset
i pray you wiil success
Sep 03, 2009 | Brother DCP-8065DN Black and White Copier
Hi, my Brother DCP-115C Brother printer keeps telling me my black ink is empty despite putting brand new cartridges in, can you offer any help. Thanks.
Black electrical tape is the answer and it’s because the tape is BLACK. Even if u put black tape on an empty cartage the printer will still try to print.
The tape goes on the side of the cartage that faces the back of the printer (where the sensor must be).
Dec 11, 2008 | Brother DCP 115C All-In-One InkJet Printer
Brother DCP 330C
This COULD BE that there is some paper stuck in the dcp. Open cover and try to see if there is some paper left in the machine. I ve noticed, that -seeing from behind!- on the right side paperpieces are stuck and disturb the disk (foil) which give the printer info what to do. Open cover and try to look into the edges (seeing from the front: its the left side -where the modell name is printed) In some cases this means that the purgecamshaft is defective.
Aug 17, 2007 | Brother DCP-330C All-In-One InkJet Printer
Brother DCP-8060 Laser Printer Logo
71 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
