Question about Panasonic Lands Phones
Speaker Phone on Kx-tga660 phone stopped working
Speaker on the phone stopped working. How can I fix it?
SOURCE: panasonic kx-tga561az code less phone speaker not working
Constant background fuzzy noise and poor sound quality
Posted on Jan 20, 2011
SOURCE: Handle Speaker phone stopped working
I'll assume this is on the base station portion. You can try unplugging the power while the phone is in the base, wait a minute, then plug back in. If that has no effect, I'm afraid you either have a failure in the keypad or in the electronics. To diagnose a keypad failure in the base, you'll need to disassemble the base. You'll find each of the rubbery keys momentarily connects two traces on the keypad circuit board when you press a button. You may also find the keypad fouled with dirt, liquid, etc, which could be a likely cause of failure. You can try manually shorting the two traces where the SP/Phone button would press and see if you are able to activate the speakerphone/dialtone. If that works, then carefully clean the keyboard circuit board and the rubbery keys. If that does not work, I conclude you have a bad keyboard circuit board or other electronics in the phone are bad.
Posted on Jan 06, 2008
SOURCE: caller id
the digital answer machine did not torn on? Why?
Posted on May 08, 2008
  • 15 Answers
SOURCE: Panasonic kx-tg1100
STEP1:
On the handset you want to discard go to "SETTINGS HS" -> "REGISTRATION" -> "CANCEL BS"
This will discard the registration of the handset to any base.
STEP2:
Using the handset you want to register go to "SETTINGS HS" -> "REGISTRATION" -> "REGISTER HS"and select the base you want (i.e. BASE 1, BASE 2, ..., BASE n).
NOTE:If you do not get access to the BASE you are looking for (STEP 2) then you have to cancel the registration of the new handset to any base. Therefore, follow STEP1 for this handset as well and then follow STEP 2.
After you finish all the above, hold down the "PAGE" button for about 5 secs.
You are now done!!!
Good luck
Simos
Posted on Nov 23, 2008
  • 37 Answers
SOURCE: Panasonic kx-tg5839al cordless phone on base set #1 button only works intermittently. Is there an easy fix for this (out of warranty)
No, the keypad is worn out. The electronic need to be replaced. Could be more costly to have repaired.
Posted on Apr 29, 2009
Does it need to be cleaned and if so, what do I use?
Just wipe it down with a damp cloth. If you need to remove built up grime, use a cloth with a gentle cleaner, and then wipe down again with damp cloth. No spraying or dunking.
Mar 23, 2015 | Panasonic Kx-tga660-b Additional Digital...
Our answering machine no longer works on our home phones. callers are directed automatically to leave messages in our voicemailbox instead. we used to be able to hear the callers messages out loud as they...
It's not a problem with your answering machine, you telephone carrier has enrolled you in their voicemail system. You need to contact them and have it removed.
Dec 22, 2014 | Panasonic KX-TGA660B Cordless Handset -...
Kx-tga660 drops calls
The main unit has a problem and the secondary unit only replicates the same problem. It is not the second phone.
Dropped calls can be from a bad connection from the source (wall plug) to the input port on the phone. Get a new wire and see if that helps with the problem.
Jul 29, 2014 | Panasonic Lands Phones
KX-TGA660 handsets - 3 of 5 wouldn't ring (no sound)
sounds like who ever installed your service was an amateur, all points should be gone over by a senior tech, piece by piece!!
Nov 14, 2013 | Panasonic Lands Phones
Speaker not working on panasonic kx-tga410
*** This phone is a POS ***
I've had three of four handsets stop giving audible feedback when a button is pushed, and 2 of 4 speakerphone stopped working.
Apr 03, 2012 | Lands Phones
No dial tone - I have to dial using the speaker phone
sounds as if this phone will need to paired with the base again.
May 30, 2009 | Panasonic KX-TG5632 Phone
Dec 16, 2007 | Panasonic KX TC1713 Cordless Phone
Lands Phones Logo
102 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
