Question about Canon Pixma MP450 All-In-One InkJet Printer
Ink is completely out. have I ruined my printer?
Before I purchase new ink cartridges, I want to know if the printer head is ruined and whether I should just get a new printer.  I want to be able to install pigmented ink and am not even sure if this type ink is available for this printer.  any suggestions?
  • 1 more comment
  • jamazam Jan 11, 2009
    Apparently the cartridges that are available do have pigmented ink in them verses dye type ink.  I was getting warned that my ink was low, then no warning and then no print.  I just assume I'm out of ink.  I want to print on fabric sheets and want ink to be as permanent as possible to last through washing.  I understand that pigmented is best and most waterproof.
  • jamazam Jan 12, 2009
    I thought ironing the printed project once on the cloth, would "heat set" it for more permanence but my tests have proven to have no added effect in that regard.  I am so confused because some of the ink cartridge descriptions I have found (even Canon's) have conflicting information.  In both the pg-50 and plain 50 cartridges,one states that it contains pigmented ink and another description at another web site states that it contains dye based ink.  Maybe they contain dye based, pigmented ink?  Thanks for everyone's feedback!
  • Thomas F. Schneider May 11, 2010
    Maybe your answers can be found here. Why do you thnk you are completely out of ink. It is not possible to run completely out. The printer stops working before that happens?   Pigmented ink is the only kind I know of that exists?
  • 8,197 Answers
The printer is still good just put a new ink cartridge in. As for the pigmented ink I do not think they make for the printer.
Posted on Jan 11, 2009
  • 180 Answers
Just running out of ink won't ruin the heads so you're okay there. As for using pigmented ink, I wasn't able to find anything that says yea or nay so can't provide a definitive answer. Maybe someone else knows for sure but I won't buffalo you. I'm curious to find out though.
  • Bill Speer
    Bill Speer Jan 12, 2009
    Sounds like you know what you're doing. Just for my clarification, would running a low heat iron over your print job when it's dry help seal it to the fabric?
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
How can i refill my hp cartridge 802 , please tell me the procedure of refilling
The procedure is to go to your local supplier and purchase genuine HP cartridges.
Honestly, people think that ink is ink....and it's not!
A huge amount of research and development goes into the inks, and molecule size is actually important. Not only that, HP formulates it's premium papers to react specifically with their inks to provide quicker dry time and longer lasting color.
Getting an ink with too small a molecule will lead to leaking and bleeding, and too large a molecule will lead to head clogging and smearing.
Not to mention, it voids your warranty.
If you buy genuine cartridges, and have a print quality issue, even if the printer is out of warranty, you can still call HP for free troubleshooting as it will be treated as "Accessory in warranty".
Also, I have seen cases where when the molecule size is wrong, the cartridge just empties itself into the printer, ruining it, and also ruining the furniture the printer happens to be on at the time.
The pennies you save on refilling the cartridge won't buy you a new printer, tablecloth and table and it certainly won't un-poison your cat or dog!
Jul 19, 2011 | HP PSC 1315 All-In-One InkJet Printer
How to test the epson stylus color 440 printer wthout a ink cartridge
You cannot test an Epson printer without both ink cartridges installed with a good supply of ink in them. All the printer will do is turn on the power. Nothing more. There is no way around this problem. They are built this way on purpose. The print heads in the printer can be ruined by allowing the printer to sit without ink cartridges in it. If you replace them, you might find that it no longer works depending on the amount of time it has sat without ink.
If you are considering purchasing a used printer that does not have any ink cartridges to test and see if it works, then all I can adivse is to be careful. You can get refilled cartridges from a company who sells them professionally for about 1/3 of the cost of brand new cartridges from a department store. Be careful using refilled cartridges though. It may void the printers warranty with Epson.
Hope this helps?
Nov 11, 2010 | Epson Stylus Color 440 InkJet Printer
How do i install new ink cartridges in my mp190
Installing a new cartridge in your computer printer is quite easy. First of all it is recommended that you buy new cartridges every time you run out of ink instead of refilling it. Refilling cartridges will have negative impact not just on the paper but on the printer too. It has been reported that refilled cartridges have ruined many printers. After you buy the new cartridges, remove the old ones carefully.
Remember the printer should be turned off before going any further. Install the new ones in the empty slot and turn on the printer. Remove a test page from the printer and check whether the new inks work or not. The first one or two times the ink might be a little smudge but that's all right. It will become normal again after one or two print outs. If the problem persists, exchange the inks with your retailer.
Feb 19, 2010 | Canon PIXMA MP190 All-In-One InkJet...
I want to know how to refill original TO551,552,553 and 554 cartridges at home
My friend, in my experience, when you purchase these kits, they come with all the tools, ink and instructions needed to ruine (ops, sorry) to fill your cartridges.
I have never had any success with refilling these ink cartridges and in fact have ruined two printers with refilled units (A Canon and a Epson). I know the ink is expensive.
Listen, I have never had a printer go out of service by using the manufacturers genuine branded cartridges and I have never been disappointed with the results. If $ is a concern, you can set your printer to print in draft mode for most printing. Epson has other tips on economizing the printer cost at their website.
Thanks for your question at
Jan 01, 2010 | Epson Stylus Photo R200 InkJet Printer
Printer not printing black ink with new cartridge
You need to charge the printer head for the ink to flow. Check your printer for head cleaning option. This should fix it.
Sep 27, 2017 | Dell 926 All-In-One InkJet Printer
Compatible cartridges
you can take the risk of using those "compatible ink cartridges." although i'm not a big fan of purchasing those because what happens is that it drains a lotta ink and somewhat blots my printouts. it can also stain the print head which most likely cause a problem printing in the future.
Sep 16, 2008 | Office Equipment & Supplies
Does not print
The CX series printers use a pigment based ink, and if it dries it frms a semi hard gooy substance on the printer ink input pins.
Sometimes after the insertion of new cartridges (Ensuring the yello tab is removed) and letting them sit overnight (to soften the ink blob) and running several cleaning cycles can unblock the ink "jam". Note: Epsons printer head need ink to cool them when printing (Sort of like oil in a car) so don;t try to print withot having ink flowing to the heads. It can also ruin the print head by overheating.
If all else fails there are several companies that sell inkjet cleaning solution. You may need a couple of cartridges to flush blocked jets but if will most likey work if the print head is still functional.
Otherwise, the technican is correct, you may need to purchase a new printer.
Note; For the future... Never let the ink run out of any cartridge without immediately replacing the cartridge. Never remove an empty cartridge without replacing it immediately.
May 21, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Printer doesn't print even with new ink cartridges.
Take out the Cartridge & get a new one if the problem persists then get the printer software reinstalled & if still it is not printing then clean up the cartridge head with cotton swabs dipped in hot water!
This should clean the head & black will be on paper
If still its not working then there's some problem in the copper contact surface in the printer on the cradle so get a new Printer.
Mar 24, 2008 | Lexmark X1270 All-In-One InkJet Printer
Continuous aqua/turquoise color even with new cartridge
hey Karyn. The problem that I have experienced with printers with the same problem is a dirty head. Get the instructions on the printer and it will tell you how to clean the head. If after cleaning, still does it then you need to purchase a new head for the machine. Dont be afraid to tear into it. printers are pretty simple. Ink and ink head. If it prints at all it seems to be a dirty head. or worn out. Watch out using ink refills or off brands. Some inks are not very good quality ink and will ruin the head and void the warranty. Use the ink that the machine requests. Staples or Office Depot carries several types of printer heads. Good luck.
Sep 04, 2006 | Epson PictureMate InkJet Photo Printer
Canon Pixma MP450 All-In-One InkJet Printer Logo
65 people viewed this question
old marine
old marine
