Question about Fargo DTC550 Thermal Card Printer
Head lift error fargo dtc300 - Fargo DTC550 Thermal Card Printer
  • 8404 Answers
SOURCE: Fargo DTC400 is giving me "INVALID RIBBON" error
I think you or your machine have answered your own question. The machine said it isn't going to use the 300 ribbon and that is that.
I dont have experience with your particular model but I can tell you a Ford starter will not start a Chevrolet automobile.
I think you should take the 300 ribbon back and get a 400. If they wont take it back, trade somewhere else.
So, what do you say?
a
Posted on Sep 23, 2009
SOURCE: printer prints card with red on the id badge (Fargo DTC300) (xp)
Cleaned printer and new ribbon
Posted on Dec 02, 2009
  • 1121 Answers
SOURCE: Fargo DTC300, prints yellow and magenta, stops at cayn
is a printer thermal head dirty on same position. clean with a clean dry cloth, and special cleaner (see on manual)
Posted on Jul 15, 2010
SOURCE: HEAD LIFT ERROR ON FARGO DTC500
where can i go to solve this problem of printheadlift?
Posted on Oct 23, 2010
SOURCE: i am using fargo direct
In this problem , first check the front side head lift gear and gear belt.
solution : Gear or gear belt may be broken.
by
LAKSHMI KANTH,
CHENNAI.
Posted on Sep 05, 2011
Solution to head lift error problem on my Fargo printer
You don't mention which printer model you have, but we mostly see that error on old DTC5xx printers. It is usually caused when a rubber o-ring within the printer has failed (broken), and the head-lift motor no longer has the necessary connection to the head-lift mechanism.
Jul 20, 2017 | Fargo Office Equipment & Supplies
Fargo dtc 550 head voltage error
Fargo DTC550 Head Lift Error - YouTube
? 4:46
https://www.youtube.com/watch?v=1MCO3wHmLgE
Jan 8, 2015 - Uploaded by Alfonso Terrazas L
Fargo DTC550. Head Lift Error. Este error se origina porque el O-Ring que hace girar el engrane que ...
Mar 22, 2017 | Fargo Office Equipment & Supplies
HI I HAVE A FARGO DTC300 AND WHEN IT PRINTS OUT THE CARDS IT HAS MAJOR DRAG LINES DIRECTLY THROUGH THE CENTER OF THE IMAGES... IS THERE ANYWAY TO ELEMINATE THIS ISSUE WITHOUT HAVING TO COMPLETELY REPL
Pls completely uninstall printer driver using printer disk, disconnect the printer, download compatible full driver from website and install it according to instruction....
Thanks,
Nov 11, 2014 | Fargo DTC300 Monochrome Card Printer
Jul 15, 2010 | Fargo DTC-300 Thermal Card Printer
Panel Searching
Common problem with the DTC300, C30, DTC400. Upgrade the firmware and printer driver from Fargosupport.com. Then calibrate the ribbon sensor through the printer driver calibrate tab.
OnlineIdTech
Feb 06, 2010 | Fargo DTC-300 Thermal Card Printer
a
Sep 23, 2009 | Fargo DTC400 ID Card Printer Package
The printer shows head lift error ...so ..how can I solve this problem ?
I had the same problem with my fargo dtc 550.
I changed the "O" Ring rubber attached to the printhead and that solved the problem. No more head lift errors.
Jul 02, 2009 | Fargo DTC550 Thermal Card Printer
Dtc300 is stuck in "replace ribbon" mode n there's nothing wrong with it.
are you using a ribbon made for the dtc300? there are some ribbons made for the other unit that look the same.
also, you might want to try updating the firmware.
Oct 26, 2008 | Fargo DTC-300 Thermal Card Printer
Fargo DTC550 Thermal Card Printer Logo
27 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
